Old Jul 20, 2012, 10:38 AM
Elisecat is offline
Find More Posts by Elisecat
"Add Lightness"..Colin Chapman
Keystone State, USA
Joined Jun 2007
Originally Posted by Spitfire22 View Post
Hey guys,
Just had kinda a fast landing that ended me up smacking into a car tire on when it was rolling, the plane is completely fine there's just some ugly damage to the nose (which i find to be the weak spot on the plane), is there an effective way of reshaping the foam?
The hot water trick DOES work on this plane and the foam. Boil some water, let it sit for about a min to cool and then dip in the nose or just pour water over the spots that are damaged. Foam will expand back to normal. If you DIP it in the water only do it for about 10-15 secs at a time. Too much exposure will over expand the foam cells and it will look like alligator skin!
Elisecat is offline Find More Posts by Elisecat
Old Jul 20, 2012, 11:26 AM
WBKelsoe is offline
Find More Posts by WBKelsoe
WBKelsoe's Avatar
Canada, ON, Ottawa
Joined Mar 2012
Damping
Yup, I understand damping, and this is what I interpreted the system to be. Meaning that the attitude of the aircraft while initializing should not really matter. It should watch for uncommanded accelerations and correct accordingly.
I have to re-look at the manual then, you point out that it says the orientation is not important.
What happened: It was the second or third flight of the day. When flying, it tended to roll left, I had to trim right 3 or 4 clicks right (it did not have this problem previous flights).
After landing I checked the ailerons and when unpowered, they did not need mechanincal trim... Both were flush with the wing.
So I guess it was probably initialized improperly. Somehow it must have moved during initialization. I'll experiment on this..
After thinking this through, it should have been obvious. The initial attitude should not be considered by the system. Not because it can't remember it, or the trouble of confirming up/down (ie additional sensors) but because you don't want the aircraft to fight to go back to the initial conditions. Or else the aircraft would not let you manover, it would fight every attempt to move it from the origial initializing attitude... Meaning no turns, rolls flying upside down, etc.
Gods! It would be like.... a transport or maritime patrol aircraft... with a coffee maker and a crapper. Ugh...
WBKelsoe is offline Find More Posts by WBKelsoe
Old Jul 20, 2012, 11:42 AM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
No my sabre has more power than my buddies mig!
Razors edge 29 is offline Find More Posts by Razors edge 29
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Now that was funny! And you're right. There are systems (such as Eagle Tree's Guardian 2D/3D) that can be switched between auto-level mode (where a given stick-angle commands a particular attitude & the plane returns to level flight when the sticks are released) & a mode that behaves like AS3X.
BTW - wind can affect initialization if it's strong enough to wiggle the plane slightly during the process.
Joel
turboparker is online now Find More Posts by turboparker
Old Jul 20, 2012, 12:15 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Joel
I've flown is such windy conditions I have to shield the plane with my jacket to get it still enough for initialization. I stop flying when my eyes are watering too much in the wind. Funny... AS3X planes can fly in conditions I need goggles for!
erkq is offline Find More Posts by erkq
Old Jul 20, 2012, 12:17 PM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
This is my first (toy) aircraft
That is a model aircraft sir, and will be referred to as such!
Did you check the rudder? Some people had loose attachements between the upper and lower rudder halves.
xmech2k is offline Find More Posts by xmech2k
Old Jul 20, 2012, 12:27 PM
WBKelsoe is offline
WBKelsoe's Avatar
Canada, ON, Ottawa
Joined Mar 2012
It's good
The aircraft is good. It was windy when all of this happened, I guess the wind moved the aircraft a bit when it initialized. ...and yes, by jove, it is a remotely piloted aircraft, Sir, I misspoke.
Old Jul 20, 2012, 12:28 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by Razors edge 29 View Post
Yeh but his one aileron doesnt have barely any down deflection! Servo works fine
Its weird
But
It flies okay
Heres a few pics of mine on H/R's and L/R's
If its this amount its normal... deferential
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Jul 20, 2012, 12:29 PM
erkq is offline
Joined Dec 2010
Har... now that is the correct technical term. It also makes my wife laugh. She doesn't get it.
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
WBKelsoe,
Many of us have been flying AS3X-equipped aircraft since the mCP X came out, and we know how the system works. As PawnBoy noted - AS3X is simply a 3-axis gyro-based damping system - nothing more. It is impossible for a gyro to have a sense of up or down. Sensing orientation requires a 3-axis accelerometer or magnetometer, and AS3X doesn't have either one. Therefore, AS3X does not have any means of "knowing" the orientation of the aircraft. As it states in the manuals, orientation is not important when initializing AS3X-equipped planes & heils. The only requirement is than the aircraft remains motionless during the process.
BTW - you're supposed to trim AS3X planes mechanically, as AS3X interprets anything more than about 3 clicks of tx trim as pilot input, which will screw-up the system. I'm not sure what caused the behavior you observed, but it is not in any way related to the orientation of the plane during the initialization process.
Joel
Joel et al. -
I've read this here and in the manual, but on my MSRX I've found that if it is not initialized level, it's flight characteristics reflect the angle it was initialized on. I may VERY well be imagining this (and I don't have it here with me to test it, unfortunately), but does AS3X work differently somehow on the MSRX/helis? I've never noticed this with the Gee Bee, just the MSRX. Having said that, I'm not a big heli guy, and the little bird leaves me generally confused, terrified, and often ducking, so this may all be in my head. Perhaps it's just a way to rationalize my poor heli piloting skills.
whichwaysup is offline Find More Posts by whichwaysup
Old Jul 20, 2012, 12:37 PM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
That looks just fine. Exactly how aileron differential should work!
I looked several times at each and on low rates there may be slightly more down on port than starboard, certainly within limits though
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jul 20, 2012, 12:39 PM
erkq is offline
Joined Dec 2010
Originally Posted by whichwaysup View Post
Joel et al. -
I plug in the battery on the mCPx with it on it's side because it's easier for my big fingers. It flies fine.
Old Jul 20, 2012, 12:54 PM
Joined Apr 2012
Shoot. And all this time I had a perfectly logical excuse for looking like I had no idea how to fly it. Now, it's clear I just have no idea how to fly it. Ignorance was bliss.
Old Jul 20, 2012, 01:01 PM
TurboRacer is online now
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
I'm missing my Mig
Sent it to HH because of faulty rudder servo and losing bind. I hope they can fix it quickly and send it back - I'm having withdrawals!!! hahaa
TurboRacer is online now Find More Posts by TurboRacer
Old Jul 20, 2012, 01:57 PM
BMFA 190658
Joined Mar 2007
Got my Mig
Forgot to take my Tx to the shop so I asked if we could trial bind it to one of their Tx's. No problems!
Took a look up the pipe. There is room to tidy the wires a bit but nothing major to report there either
Can't wait for the maiden!
As much as I would prefer ROG for the maiden my local field is belly land only. Do you need to leave the cannons off for belly landings? Also I've seen pics of the belly scuffed up so tape is going on there first.
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19352 Jun 16, 2016 01:08 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
