Old Jul 19, 2012, 08:07 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Originally Posted by rcoconut View Post
Here's a good laugh for you guys. You can fast forward to 2:11, that's where I begin my approach....
Love your camera fixture! Seeing the side of your face add a very nice perspective to the flight.... For some reason, it gives that "hey, I have the impression I'm flying this aircraft" instead of the usual other type of videos where you simply get the feeling of "I'm watching a video of an airplane in flight". That's a keychain and velcro strap? Do you always get good videos with that setup, or do you get many videos with the airplane out of frame? If you don't mind, I would like to see a close-up picture of the camera "stand".
Thanks!
RealGambler is offline Find More Posts by RealGambler
Old Jul 19, 2012, 08:10 AM
kalmon is online now
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by GBLynden View Post
That is a nicely trimmed bush!
And half of our wives just blushed....
-Brian
kalmon is online now Find More Posts by kalmon
Old Jul 19, 2012, 08:45 AM
WBKelsoe is offline
Find More Posts by WBKelsoe
WBKelsoe's Avatar
Canada, ON, Ottawa
Joined Mar 2012
[So when you get a chance, it's dead easy to both check and to fix that little obstruction if you have it -- no splitting of fuse or adhesive, etc is required.[/QUOTE]
Originally Posted by Colbyntx View Post
OK, this is a serious question and i'm not trying to be a smarta#*. Why take a brand new plane that is a great flier and rip it apart, change everything up and try to push it beyond it's tiny limits? I could understand if it's a cheap Dynam or FMS that you have to mod to get it to fly right but an e-flite UMX? I didn't even have to touch a trim button from the first flight. Wouldn't it make more sense to get a cheap airframe and build it up yourself? Just asking.
+1 On the chopstick fix.
Mods: It's human nature for gearheads/aviation people. No car is fast enough, no plane is fast enough. Even in real life, as soon as a plane comes out, engineers work out the bugs, design improvements. They stretch it, give it more range, more thrust, etc. And it goes on until the day they retire an aircraft.
Some guys are happy with stock planes. Others not. I'm in the middle, I do small mods. But it's our planes, so we can do whatever we want with it. It's relatively cheap to tinker with them. And it's one of the few things you don't need a permit, FAA licence or that gubmint regulations haven't spoiled yet (within limits).
WBKelsoe is offline Find More Posts by WBKelsoe
Old Jul 19, 2012, 09:41 AM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Another Maiden.....
Just maidened mine.
Can't believe it's 'big plane' feel.
Love it!!
Goody63 is offline Find More Posts by Goody63
Old Jul 19, 2012, 10:17 AM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Thanks!
LOL, I actually thought the side of my noggin would be in the way, but I didn't think about it the way you stated it. It's actually the Contour Roam HD camera with the Head Strap Mount. I had a hard time choosing between that or the GoPro & for "aerodynamic" reasons for the Radian Pro I decided with the Contour:
https://contour.com/products/contour-roam
And here's the head mount strap:
https://contour.com/products/headband-mount
p.s.- I got mine off Amazon.com, $165 brand new & free shipping, Contour Roam is also cheaper than the GoPro
rcoconut is offline Find More Posts by rcoconut
Old Jul 19, 2012, 02:59 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Originally Posted by kalmon View Post
The brick in the mig IS programmable, USB programmer here. That said I fixed my tail wag at high speeds. It took some manual trimming and trial and error but now even on a 3S pass there is almost no noticeable tail wag. Also moving the CG a bit more forward helped too.
I almost think that the ailerons are causing some of the perceived wag. The rudder just isn't that effective.
-Brian
Thanks for correcting me if I was wrong about progammability...I thought that the programming wasn't control surface specific but changing the parameters for the entire unit???...For example, inserting a Beast program instead of the MiG---So on and so forth but not being able to change the individual surfaces...If individual surface programming is available this will definately change my mind about owning one due to me being a tinkerer......
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Jul 19, 2012, 03:06 PM
makg is offline
Find More Posts by makg
ISP Supervisor
makg's Avatar
United States, AK, Fairbanks
Joined Jan 2006
Guys how does this compare to the Great Planes Sabre? Really thinking about getting one...
makg is offline Find More Posts by makg
Old Jul 19, 2012, 03:19 PM
SLK Count is offline
Find More Posts by SLK Count
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
Originally Posted by SLK Count View Post
Hi all,
read something about heavier 2S Packs 300mAh and up or 3S packs---what about your CG ???
Wondering because my Mig is with stock 200mAh pack backwads in best CG position and don't need elevator for horizontal flight.
I also use 240mAh packs which are 5g heavier in the backwards positon...little nose heavy CG but still o.k without trim.
Therefore,if you use heavier packs you have nose heavy and have to trim elevator-bad for flight performace !!!
hmmm, no reactions concerning my doubts ?
Did anybody modified the battery box by cutting foam backwards ?would it be possible ?
SLK Count is offline Find More Posts by SLK Count
Old Jul 19, 2012, 03:22 PM
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
next HorizonEDF plane
..looking in the future...
maybe a double 2S EDF plane would be the next HH plane (Me-262)...
Old Jul 19, 2012, 04:11 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Originally Posted by Eastcoast78 View Post
off pavement is awesome. it was a bit old and bumpy though, hit a small divit and bent back the home brew Nose gear. bent back in shape no Problem.
have a blast with the mig and Geebee. Uploading another with us flying in formation.
Well trying to anyways
Got the canopy of now, trying to figure out whats causing my Rudd servo to freeze up.
going to clean the tracks with some alcohol. All wires etc seem to be in good order!
http://www.youtube.com/watch?v=W2cehw5vrkw
Okay - I'm like 10 pages late on this, but GREAT video East Coast. I got a MIg Video fix AND a Gee Bee fix in one vid. Great camerawork by the way. Thanks for the post, East Coast!
Just a note - I noticed the Gee Bee had a hard time taking off the first time. In the very last frame, it looks like the wheel pants are pidgeon toed - were they fixed? Could just be the camera angle, but, might want to mention it to your buddy, that thing likes to nose over bad enough, pidgeon toed landing gear will only encourage the behavior!
whichwaysup is offline Find More Posts by whichwaysup
Old Jul 19, 2012, 04:14 PM
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Kevin
I don't think it will be that programmable out of the box, however it wont be long before the tinkerers here will figure it out to make it that way Even it not just pick the programming for "pylon racer" and that will dampen the gyros.
Very similar in most respects except stability. When stock they are almost the same speed. Mig has a very slight advantage in maneuverability and Sabre had a slight advantage in vertical. Mig blows the sabre out of the water in stability with the AS3X system. Look back a couple pages, One of the guys at my local field and I had a dogfight with his sabre and my Mig.
-Brian
Old Jul 19, 2012, 05:21 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
The programming feature will only allow you to drop in THEIR file.
Programming the AS6410NBL
1. Connect the battery to the AS6410NBL.
2. Start the AS3X Programmer software.
3. Select the desired AS3X set-up file.
Having said that - if the code isn't obfuscated - we should be able to tweak it using an editor.
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 19, 2012, 07:08 PM
Spitfire22 is offline
Find More Posts by Spitfire22
Winter Flyer
Spitfire22's Avatar
Yukon, Canada
Joined May 2008
Hey guys,
Just had kinda a fast landing that ended me up smacking into a car tire on when it was rolling, the plane is completely fine there's just some ugly damage to the nose (which i find to be the weak spot on the plane), is there an effective way of reshaping the foam?
Spitfire22 is offline Find More Posts by Spitfire22
Old Jul 19, 2012, 07:11 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by Spitfire22 View Post
....smacking into a car tire on when it was rolling.....
Which was rolling, the MiG or the car tire???
Either way, a pretty picture!
pugsam is offline Find More Posts by pugsam
Old Jul 19, 2012, 07:12 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Is there a way to reset the throttle on this bird? My buddies spools up slower now and doesnt see to have the power it did before?
Also one aileron servo is acting weird - wont go down on one side almost like end points are off. Tried rebinding on level ground ect.
Razors edge 29 is offline Find More Posts by Razors edge 29
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19352 Jun 16, 2016 01:08 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
