Old Jul 16, 2012, 01:58 PM
awacsCZE is offline
Find More Posts by awacsCZE
awacsCZE's Avatar
Joined Aug 2010
So I also joined Mig club today
Bad weather rules here now, so only static impression now. I look fantastic, much better feeling, than when I unpacked UM Mossie. Fal clear of wires, no problem so far
Looking forward to the maiden
awacsCZE is offline Find More Posts by awacsCZE
Old Jul 16, 2012, 02:24 PM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Originally Posted by TurboRacer View Post
Eastcoast - my rudder servo also started sticking. About the same time I started to have to re-bond every pack or two. Called HH and they sent me a UPS tag to send back to them to check out.
Mine still holds a bind,other then the time i put a dead battery in.
HH is sending me anew Ail servo. had a few flights and got some cleaner ,now the Rudd is moving nicely. Cycled it for a few mins non stop and it never locked up once.
If it starts losing the bind, then ill be looking for a UPS tag
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Jul 16, 2012, 03:58 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Well, I had to do it -- I grabbed the 3S Babblebatt from my box, and threw it on the Mig... just slides in!
Ran it up in my hand and all seemed well -- even at screaming full throttle.
Took off and flew a lap at half throttle, and except for feeling a bit more plesantly 'planted' due to the extra weight, nothing other than normal. I then gave it the beans, went vertical... and after 1.5 seconds, hit OCP.
Dang.
Hammerheaded out, and while gliding, reset throttle to bottom, tried again... was able to fly just like normal, but at full throttle it cuts out... then I had to deadstick it on the side of the hill.
So it's no worse for wear after the little experiment, and of course, it goes like a banshee at full tilt, but unless I maybe change my throttle travel in the radio down to 90%, I just can't use the 3S on the Mig, as I can't trust myself to stay out of OCP range.
Ambient temp was about 79 degrees F, elevation 100 feet ASL.
tracknoob is offline Find More Posts by tracknoob
Old Jul 16, 2012, 04:11 PM
rcoconut is offline
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Awe man Easter, now your RUDD is acting up. Good luck with that fix! Nice nose gear mod as well! I know it's a matter of time for me before the nose gear gives. Although I have only 2 flights, 1st RTO in the parking lot & landing in the baseball in-field & the 2nd flight off RTO & landing on in a dirt field. All good so far.....
rcoconut is offline Find More Posts by rcoconut
Old Jul 16, 2012, 04:45 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Dang.
Remember, another way to limit the current, is if you don't charge your battery to a full 12.6Volts.... Since you have no way to monitor low battery voltage anyway, a solution could be to stop charging your battery at a lower voltage. With the other AS3X airplanes, some guys were stopping the charge at 12.0V. You could probably even go a bit lower than that and still get a decent flight (let say 11.75V).
RealGambler is offline Find More Posts by RealGambler
Old Jul 16, 2012, 04:57 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Thanks Dave - so it could also be a board contact issue.. sheeesh... the list grows...
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 16, 2012, 05:05 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Dang.
Have you done anything to aid the cooling of the board ?
John
pmpjohn is offline Find More Posts by pmpjohn
Old Jul 16, 2012, 05:06 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Dang.
I highly doubt it was OCP. Most likely it was the OTP. Adding airflow to the brick will probably solve that. erkq had a great idea over on the Sbach thread of adding a very small heatsink to the FETs. It solved his OTP problem. I had the same experience on 3S, and a quick feel of the plastic canopy right above the esc confirmed it was hot!
This would be completely impractical on the mig. It eats through a 200mAh battery in 3 min, even if you have a 320 mAh 3S pack charged to 12.0v you'll only have about 155mAh to work with. This would lead to prohibitively short flight times of about 2min tops. And as you mentioned there is no LVC to save the pack!
-Brian
kalmon is offline Find More Posts by kalmon
Old Jul 16, 2012, 05:08 PM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
John
Nope. Just wanted to check it out stock. To be honest, I'm perfectly happy at 2S, and only wanted to know if it would work as-is. As I reported, it almost does, which is fine, but I am just not likely to mod myown Mig with a heat-sink, or use a partially charged battery to make it work.
Cheers to all of those out there that ARE going to push the envelope, though!
Old Jul 16, 2012, 07:50 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Thanks man! i had 2 more flights today to test the rudder. Which is 16 now. It was my own doing, i think the stock LG should hold up. But be very carefull when bending it to straighen up the nose wheel. Needle nose pliers may be best!
Just a after my 2 flights today i headed to the local Speaciality Electronics store. Was going to try The Source, But they have gone to crap down this way! Much better when they were radio shack!
I ended up getting the only thing they carry which is called Clean and Lube by DEX Canada. As i was walking out of the shop, i was reading the back and it said...good on most plastics.. haha!!
So i got home and tested on the side of the servo first..."great it works"!!...So i sprayed the rudd and took the Ail part again.
Man those screws are small. So i scrubbed the 2 pads with a Q-Tip, noticed on the end where i have the jitter, the silver track was pretty dirty! i managed to get 98% of the mark off. I also noticed the little eyelash's I guess thats what you call them?
The one on the far right was bent in quite a bit and was Prob not making contact!
So i bent it back out like the others
Put it all back together and fired her up...Perfect!!I cycled the rudd for a few mins, and it never frozze once. and no more jitter on the AIL. So I'm Happy
Also made a new Nose LG this time with the stiffer wire. I like it more then the softer wire.
So im super stoked that all is in order.
Shame its on a Brand new 200 dollar UMX, but hey thats what i like about the hobby. You alway learn something new!
Also buying from a company that you know, if theres something wrong they well take care of you also!
Heres a Few Pictures
Old Jul 16, 2012, 08:09 PM
Jabberwocky_ is offline
Find More Posts by Jabberwocky_
Jabberwocky_'s Avatar
Montreal
Joined Aug 2009
Originally Posted by pugsam View Post
My MiG had a sticky gear in an aileron servo. Felt like there was a burr, or a piece of grit -- but even with magnification I couldn't spot anything to clean out or scrape down.
I applied a tiny bit of DeoxIT, worked the gear with my finger a few more times, and went to bed.
The next morning, the stickiness was gone.
Dave
DeoxIT huh? I had never heard of such a product but I looked it up and it sounds quite fascinating. Sounds like a very useful product indeed.
Jabberwocky_ is offline Find More Posts by Jabberwocky_
Old Jul 16, 2012, 10:46 PM
Left Coast DJ is online now
Find More Posts by Left Coast DJ
Left Coast DJ's Avatar
Joined Jan 2012
I just saw this Mig at my local hobby shop. It sure look purty! But is it worth $160?
And finally, what would be the closest competing Mig 15 to this?
Left Coast DJ is online now Find More Posts by Left Coast DJ
Old Jul 16, 2012, 10:51 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
I've been brain storming the last few days on how and what to use for servo covers.
I could order some.But then i thought of something everyone should have, if not...grab a hand full next time your at a fast food resurant!
Plastic spoons. It worked perfect. just be mind full not to have them touching the gears.
First i placed them over the servo and fitted them, and pushed in a touch, enough to make a little indentation, and give me something to go by once its ready to be glued.
I added clear tape around servo and used CA.
Mine were a bit flat so i warmed them (hold in your hand is enough) and gave it a bit more curve. I also used a blade to flatten/scuffed the edges to help fit and make a good glue joint!
I think there very profile
Old Jul 16, 2012, 10:56 PM
Dixie Normious
Can A da....Ehh!!
Joined May 2010
Yes its worth it, I love how Big it flys.
Great PlanesŪ F-86 Sabre...
Old Jul 17, 2012, 06:08 AM
Canada, QC
Joined Oct 2009
They must be a bit heavy though (thick plastic), but wow, do they look good. I love the very profile look (and they are white...). Great job!
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19423 Aug 15, 2016 09:37 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
