Finally had a chance to see your maiden Eastcoast, congrats and nice video! You've logged a lot of flights already! I like the carbon tow you added as well! Are you going to go with servo covers since she's a belly lander? I think I'll put the micro Stryker covers on like AL1EN, the red looks cool. I have yet to try a flight without the gear though, instead of tape on her belly I was thinking a few coats of clear foam spray like what I put on the Radian Pro and big Stryker & I think Nitro did 5 coats??
Dyess AFB
Joined Apr 2009
Anyone else have a rudder servo DOA? My first one the rudder didn't work out of the box, local hobbytown exchanged it and the second one is fine for the 4 flights I have on it now. Nice litte plane but I did have to rebind it once already, oh well.
Glad you caught it on the ground! A buddy of mine had his ELE servo freeze on his 7th flight (landed safely, failed in the neutral position). The servo is on it's way to NitroCharged for a thorough exam and hopefully we'll know more in two weeks which is when Dave is scheduled to receive it.
Always investigating and learning.
First of all thanks to Brian for the heads-up on the new biased long throw servos. I was familiar with the linear long throw servo SPMSA2030L and the 1.9-gram linear long throw BB servo SPMAS2000LBB, but the 2.3-Gram linear long throw offset servo SPMSA2030LO was new to me. It’s a pretty useful servo if you do not have a programmable radio or if you are producing a BNF that uses a low end radio.
Regards, Eric. |
Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
After Brian’s post on dual ailerons I went and did my homework assignment. There are three AS3X receivers available. The DSM2 6 Ch Ultra Micro AS3X receiver BL ESC (EFLU4864), The DSM 6ch UM AS3X RX BL-ESC: HT (EFLU4751) and The DSMX 6Ch AS3X AS6410NBL receiver (SPMAS6410NBL).
I am working from/on the manual that covers the AS6410NBL, not the MIG manual. It clearly states and shows you how to get flaperons with this RX if you have a computer radio. The manual talks about changing channel-6 to a reversed aileron channel-2 in the receiver. This gives you two independent channels. You then have to tell your TX to use channel-6 as the second aileron. [I said “In the receiver”, because you can also reverse the servo itself with the supplied servo modifier lead and also with a programmable TX. Neither of these reversings gives you flaperons with the AS6410NBL receiver.] It does work and you do get two aileron channels that you can program with end-points, sub-trims and that can be reversed individually. You can then set up an AS6410NBL to give linked elevator to ailerons e.g. flaperons. You can also use the computer radio flap system operation to drop or raise both ailerons. Just like any of the prior AR6400 RXs. So why would HH say that it does not work? The answer lies in the roll axis gyro implementation in the RX. What I tested for and found out was that the gyro will only operate/correct channel-2 when dual aileron channels are selected. What you see is only the channel-2 driven aileron reacting when you roll the airplane from side to side! Now the question is “What will that do in the air?” My theory is that gyro-roll-correction/stabilization on only one aileron will still have the desired effect, but will be slower than before. I based that last conclusion on aileron servo failures on larger aircraft and of course it is only a theory until I fly my MIG again. So there you have it. If you want dual ailerons (flaperons etc.) you can have them, BUT you will lose the AS3X gyro efect on the channel-6 driven servo. I'll try and post a video as soon as I can. Regards, Eric. |
This stuff is old-hat for those of us who have been flying AS3X-equipped planes since the Beast 3D came out last November. Many people have tried dual-channel ailerons on the other AS3X planes. They always go back to single-channel ailerons, as the results are always poor. With AS3X active on only one aileron, the plane flies poorly due to adverse yaw, and becomes prone to tip-stalls. Plus, the gain is only half what it should be on the roll-axis. Joel |
Tow would of been imposable to feed threw the small hole. So i skivered off a piece of cf from the odds and ends i have laying around. just used a #11blade and cut the 3mm in half. once you start your cut, you can run the blade threw easy as pie ![]() . Just finished remaking the nose LG. Used a paper clip and followed the bends of the stock lg. But i added a coil mid way up. ground tested it on the Kitchen floor works great. yea diff going to get the servo covers. that clear should work great. But i like the tape, as over time im guessing tape or clear the grass well stain. So with tape you can easily remove it and apply more. I'm looking for a a decent parking lot for some pavement flights. Wind has dropped and its a day at the field tomorrow. cant wait to run a few laps. |
Joined Jun 2007
A little bit of help please guys.
I noticed today an awkward line on my transmitter when flying the mig. It's only there when I power up the mig and only the mig, tried on another DSM 2 rx and the MCPx. The plane seems to behave fine, though I can't test it at the field yet. Could it be a faulty unit? I haven't hat more than 4-5 flights (got the plane on Wednesday. I tried binding it again, tried creating a new profile... Pic attached: |
Joined Jun 2007
Well the transmitter seems ok and the voltage is (still) fine for the d7s (4.8V pack).
I'll charge it but the awkward thing is the line is MIG (DSMx) only and I had a nasty crash too. I just don't remember seeing that line before... I took the mig for a short flight and it seems ok. In DSM2 mode there is no line. If any Dx7s or Dx8 owners can check theirs I'd be grateful. I'll report it as bug if others can confirm. |
Canada, QC
Joined Oct 2009
But basically, I think this little line has something to do with telemetry. With the DX7s, I believe you have to scroll to another menu to verify/check telemetry. As usual, I may be totally wrong, but hey, it's something worth checking!
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16700 | May 24, 2013 01:33 PM |
| Discussion Hobbyking Lancaster official owners thread | Tartago | Electric Warbirds | 942 | May 22, 2013 03:30 PM |
| Discussion UMX Mig-15 DF Mod Thread | NitroCharged | Micro EDF Jets and Power Systems | 908 | Mar 28, 2013 08:53 AM |
| Discussion E-flite UMX MiG 15 DF SNEAK PEEK! | D PAYNE | Micro EDF Jets and Power Systems | 2210 | Dec 19, 2012 09:29 PM |
| Sold Eflite F-86 Sabre 15 DF NIB! | blue7.62 | Aircraft - Electric - Jets (FS/W) | 1 | Apr 05, 2012 01:35 PM |
