The Netherlands, NH, Zandvoort
Joined Mar 2011
Has anyone used the mCPx lipo mod yet? I have a ton of those 1cell lipo's. I just ordered this.
http://www.rc-connectors.com/index.p...roducts_id=251 Now i can use the 300Mah Nanotech's |
Well,
The MiG is a lot easier to fly than a deep-freeze, and it doesn't need anywhere near as much runway! On the other hand, the MiG is a bit shy on cubic footage to serve as a small deep-freeze, and you'd have to make a door for it. I'd go for the MiG. ![]() Joel |
Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Both packs fit fine, but they do protrude a couple millimeters or so below the belly. In my hand-launch video, I was flying with a TP 325. Belly-landing was no problem. No grass-stains or debris on the pack, so I don't think it'll be an issue - provided that one uses proper attitude management during the landing. If I remember correctly, someone (Nitro?) mentioned that there is room to make the slot deeper. If so, it may be possible to recess the Hyp 320 & TP 325 packs. I mounted the packs as far aft as possible, and the CG seemed to be OK. Maybe just a tad nose-heavy, but not enough to negatively affect flight-performance. BTW - others who have watched my battery comparison video also thought that the TP 325 had the edge in vertical performance over the Hyp 240 & 320 packs. Also - the TP 325 has a distinct edge over the others in the Gee Bee. It even out-performed the Hyp 450 in that app. I'll be flying the TP 325s in the Mig, CC, Gee Bee, and Blade 130X. Just ordered an additional 6 TP packs from RCBabbel. ![]() Joel |
They fit well in the CC as well or do I have to enlarge the slot at the bottom? Regardless I think I'll be ordering a couple for the Mig. Have you seen erkq's Post? I bet this would fix your Mig for 3S performance!! -Brian |
The TP 325s fit the CC's battery compartment without modification. On my airframe, they end up just a few millimeters from the rear of the compartment to get the CG right. Yes, I read Erkq's post with keen interest! Given that there is no airflow to the MiG's brick, one would be essentially relying on radiant cooling effects. Not sure if that would be enough - considering how quickly mine went into OTP, even after a part-throttle takeoff. I might have to try the heat-sinks just to see if they work. I'd really like to fly the MiG on 3s, but I am not willing to give up AS3X to do it.Joel |
Good points - thanks! Erkq also put a heat-sink on the regulator, as he ran into full brick shut-down after heat-sinking the ESC. I thought about using an external ESC on ch 5, but I was concerned about the additional weight & getting the CG right. How much does the 10A ESC that you're using weigh, and do you think there's room to mount it where it won't affect the CG too much? I was wondering about how the MiG's gains would work out at higher speeds. When I switched to 3s on my Beast 3D, I had all pushrods in their innermost holes. I observed some gain-induced aileron oscillation @ WOT. I moved the aileron pushrods out one hole, which effectively reduced the gain enough to solve the problem on my airframe. The aileron pusrhods are already in the outermost holes on the MiG, but the rudder & elevator pushrods could be moved out one hole, which would effectively reduce the gain. Hopefully, one of the downloadable generic programs will have gain settings that are better-suited for high-speed flight. Something like 'pylon racer', perhaps? ![]() Joel |
![]() Even though they are small I'm hoping that with the ram air style scoops and the hole for the motor wires being behind the fan acting as suction, there will be better cooling on the brick. Quote:
-Brian |
![]() Has anyone tried the skylipo 250mah 25C? Those look good at $4.86 each! |
Canada, QC
Joined Oct 2009
Flew the Mig again this morning. First thing I had to do was re-bind it since it did loose the bind overnight, in the box... Very scary, it does look like the CC too much. But hopefully, it's only something that is happening with DSM2 Tx only... After binding, no problems flying it, non-stop through 16 batteries!!!!
No more flutter on the rudder, but the ailerons flutter was still there every now and then, even with a good C.G.... It's minimal, but the Mig look so good/scale in the air, the last thing you want is some wobbling. After all, one of the goal of AS3X is to make it look even better, scale wise, so I'm not too keen about this. But over all, still like it a lot. Come to think of it, my usual spot may not be even long enough for take-off!!! (and I was worrying about landings!) Out of those flights, I spent some time doing high speed passes while doing some video. Just did a RC Speedo on those videos, and here's my finding: Mig 15, with wheels, temperature 70 degre F (21C). Just a couple hundred feets above sea level. Going both ways to eliminate wind, but there's wasn't truly much wind, so results were pretty much the same both ways, which is good. Used RCSpeedo, which I normally don't like, but results were very consistent, even with my relatively quiet Mig. With stock E-Flite battery that came with it (only 3 cycles), I got seven very good passes, that gave me an average of 30.5mph With Hyperion 240mah (not home made packs, straight from factory), about 30 cycles, I also got seven very good passes, that gave me an average of 35.3mph (passes were a bit less consistent, but still good) With NanoTech 180mah, getting close to 100 cycles, and using two differents packs, I got 11 passes, which gave me an average of 33.1mph. One pack gave me slightly better results than the other, but those packs have been to war and back a few times and abused too many times! So, the E-Flite pack is really good. Yes, it's the slowest, but with only 3 cycles, it should still improve and should get closer to the other two. WTG E-Flite!. The Hyperion gave me the best results, but those packs are almost in their sweet spot. 30 cycles, and never abused. The NanoTech did pretty good, and for the price, I still think it's a great deal. So, overall, about 33mph for the Mig, with wheels, and in relatively typical conditions. I believe I can trust RCSpeedo on this one (I may check it with better doppler software later on). I usually don't trust RCSpeedo much, but the results were so consistent, I'm suddenly liking this app VERY MUCH! . No wild speed recorded ever. I'll have to use that software more often from now on.Next step: Removing the wheels.... It's against all fibers of my body, but this will allow me to fly it in my usual park, so, afterall, I may like this! I'm expecting quite a few more mph without the wheels. It's very windy right now, so hopefully, tomorrow morning. Currently charging my batteries, almost one by one, so I can get some accurate data. All my flights were 3 minutes pretty sharp. So, more data to follow! |
Hamilton Ontario
Joined Oct 2005
To enter bind mode it only takes a few seconds with the transmitter off.
If you do not have your transmitter bound and ready before you plug the plane in, it will re enter bind mode. Simply unplug the plane and plug it back in as it will not release the bind. |
The Mig turns better because the airfoil is so much more efficient than that under-camber on the F-86. RG: Looking forward to see how many mAh you put back on all those packs. This is making me really want to get some BB TP 325 65C packs. Just hope the CG doesn't move forward to much. Also I'm guessing at least 6mph level speed increase with the gear off, probably 10 out of a dive. Pics of my cooling mod: -Brian |
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16659 | Today 04:33 PM |
| Discussion Hobbyking Lancaster official owners thread | Tartago | Electric Warbirds | 942 | Today 03:30 PM |
| Discussion UMX Mig-15 DF Mod Thread | NitroCharged | Micro EDF Jets and Power Systems | 908 | Mar 28, 2013 08:53 AM |
| Discussion E-flite UMX MiG 15 DF SNEAK PEEK! | D PAYNE | Micro EDF Jets and Power Systems | 2210 | Dec 19, 2012 09:29 PM |
| Sold Eflite F-86 Sabre 15 DF NIB! | blue7.62 | Aircraft - Electric - Jets (FS/W) | 1 | Apr 05, 2012 01:35 PM |
