Old Mar 15, 2013, 01:20 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by grovey View Post
Hi all
I bought the plastic nose cone cover and wing tip covers from Parkflyer plastics which I really want to try out, but I was curious as to how y'all are mounting it, do you place it on with CA?
I put a drop of white silicone on the bottom of the wingtip then slid the cover in place. Once the silicone cures it'll be easily removable if I ever want them off but strong enough to hold the tips in place.
The nose is a pure friction fit, no adhesive needed.
-Brian
kalmon is offline Find More Posts by kalmon
Old Mar 15, 2013, 01:24 PM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
-Brian
Thanks Brian, well... the thing about my nose is, uhhh it has seen better days!
I will check it out and see if the fit will still be ok, if not I will glue it down.
grovey is offline Find More Posts by grovey
Old Mar 15, 2013, 01:30 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
but what about the plane's nose?
-Brian
Old Mar 15, 2013, 02:07 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
-Brian
Touché! Lol
Old Mar 15, 2013, 07:41 PM
impmotor is offline
Find More Posts by impmotor
Horsham, PA
Joined Aug 2007
Originally Posted by xmech2k View Post
Your link isn't working, impmotor. (Looks like an extra 'http://' at the front.)
I found the site that had the X-32 I was thinking of, but looks like they don't sell it any more.
Air Hobby
It's obvious what many people think of the X-32 when you do a Google search and as you type in 'X-32' the word 'ugly' auto-fills to the end of it, but I like it. Well, there was that one flight where they put a special intake on it for hovering, and that was ugly, but I liked the normal one! Being a huge wing like my 64mm F-4d Skyray, I think the X-32 would make an awesome flyer. Fast jet speeds and can almost hover down to a landing! Wish one of the modeling companies would stick their neck out and make this one...
OK sorry for the departure! And now back to your regularly scheduled MiG-15 programming...
Sorry about the bad link. It is corrected now and is for the plans only and not the kit. All you need is a bit of 2mm depron and the plans.
impmotor is offline Find More Posts by impmotor
Old Mar 16, 2013, 01:50 PM
helijamie is offline
Find More Posts by helijamie
helijamie's Avatar
Canada, BC, North Vancouver
Joined Jun 2011
MIG rebuild
Hi everyone
I love this little EDF. I hit a tree the other day during a particularly lively session and the patient (airplane) is listed as critical. We are making arrangements...
The electronics are fine.
I have ordered a replacement airframe and pushrods but I am unsure of the glue to use. I am thinking foam safe ca for wing, tail and carbon reinforcement attachments with silicon for servo and electronics install. I found the original quite delicate and am going to beef it up with some fine flat and round carbon rod.
How is the canopy attached? How are the pushrods glued? It looks like heat shrink and thin ca.
I am also thinking about a ring of light fibreglass around the nose about 1cm wide held with laminating epoxy. I will not install any landing gear or guns.
I am curious what everyone's thoughts are.
Thank you.
helijamie is offline Find More Posts by helijamie
Old Mar 16, 2013, 03:09 PM
DennyNC is offline
Find More Posts by DennyNC
DennyNC's Avatar
United States, NC
Joined Jan 2013
Who can tell me how many AMPs stock ESC can provide?
And is it posable use different EDF ?
Thank you.
DennyNC is offline Find More Posts by DennyNC
Old Mar 16, 2013, 03:10 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Originally Posted by helijamie View Post
Hi everyone
Thank you.
Parkflyer plastics makes a plastic nose and wingtip reinforcement kit.
The horizontal tail needs the CF reinforcement to perform well. There are many pics in the thread.
The plastic top piece including the canopy is attached by double sided tape.
Servos and electronics by non-acetic cure silicone (automotive RTV for electronics works well)
Wing by double sided tape, however foamsafe CA/UHU/foamtac will all work
Fuse Halves by regular clear tape along the seam, very important not glue these together!
-Brian
Old Mar 16, 2013, 04:56 PM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
Okay, this isn't an entry for the limbo contest (yet). I haven't had much of a chance to fly it outdoors, so I've taken it indoors. It's about a tight a space as I'd want to fly it - perfect for the swarm of Champs that usually fill that airspace - but not much room for a jet. After most of the Champ jockeys clear out (I try to thin them out with my UMX Spitfire), I like to warm up the Mig-15 for a few laps.
E-flite UMX Mig-15: Indoor Insanity! (1 min 51 sec)
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Mar 16, 2013, 06:37 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Thank you.
From the brick manual:
Max continuous current: .................................4.9A
Overload protection current: ...........................5.8A for 1ms
BEC continuous current: .................................1A
BEC overload protection current: ...................1A, 4.2V
Low-voltage cutoff: .........................................At <6.3V, the motor begins to pulse. At <6.1V, the motor cuts off and the LED flashes.
Over-current protection: .................................At 5.8A, the motor cuts off until the throttle stick is pulled down to idle.
Temperature protection: .................................At 120°C, the motor cuts off.
The ESC also supports three PWM frequencies & five timing settings. See the manual for details.
Joel
turboparker is online now Find More Posts by turboparker
Old Mar 16, 2013, 11:16 PM
DennyNC is offline
DennyNC's Avatar
United States, NC
Joined Jan 2013
Joel
Thank you .
So it possible to use other edf fan.
Old Mar 17, 2013, 12:47 AM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
http://www.youtube.com/watch?v=RSpdeD6obpg
I don't remember anything in the contest rules about the MiG itself having to limbo under something... I believe the pilot combing his hair in a semi ducking/limbo position with the MiG should score you at least some points
Aphro is offline Find More Posts by Aphro
Old Mar 17, 2013, 02:50 AM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Well great then! I was worried that I wasted my time.
Site Sponsor
Old Mar 17, 2013, 05:01 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Nice! that's a really small area there! How wide is that?
-Brian
Old Mar 17, 2013, 05:11 PM
Joined Jul 2009
Bwoollia,
That was gutsy! Sorta reminds me of the Cup race @ Bristol today.....
Joel
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19222 Feb 03, 2016 03:36 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 03:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 07:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 05:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 02:35 PM
