After checking the plane at home I walked to the park, 300m or so, and went for a flight. Upon my preflight check I noticed both ailerons working the same way! I'm pretty sure the problem was that when I put the plane upside down on the grass to place the battery in some moisture from the grass worked its way into a servo and shorted it, causing it to reverse. It was easy enough to sort out and shows how important it is for a quick, but thorough preflight check every time, but definitely after a battery change. Tony |
Latest blog entry: Maybe my fleet is too big...
-Brian |
Just to add a little to my previous post on the crash. She nosed in from about 20 feet with a good little thud onto the grass, but since i had the little plastic nose cone the damage was minimal. Only noticable damage was a crease on the horz stab...
Cudos to Park Flyer Plastics! |
"The 2.3-gram Linear Long Throw Offset Servo is a special use servo designed for modelers without computer transmitters who would like to add aileron differential to their ultra micro aircraft. It comes programmed with a 70/30 offset from center and can be used with any Spektrum AR6400-series receiver." soo, to get them to work you need to attach a reversing cable to one of the offset servos and cycle the power in a special way to reprogram it. here is the "Ultra Micro Linear Servo Reverser" cable/lead http://www.spektrumrc.com/Products/D...ProdID=SPM6825 i did it with some help, but can't seem to find the setup procedure online. anyone know the link. |
http://www.spektrumrc.com/ProdInfo/F...NBL-Manual.pdf |
LOL, I had no idea there was an extra cable in the package until I took a closer look?!?!
Hey FoamJunkE, since I'm repalcing my RUDD servo looks like I wont need the cable, if you need it PM me with your info & I can mail it to you. But you may be like me & impatient, just wanna fly right now, so you may have called your LHS to see if they have the reverser cable in stock & your on your way right now to pick it up, LOL!! Good luck. |
So if you want to fly right away just make a tiny jumper and connect the two points on the servo together when powering on and it'll reverse. -Brian |
But thanks, I'll make sure I do the above process. Appreciate the explanation. |
-Brian |
found this in the beast thread, use at your own risk:
![]() http://www.rcgroups.com/forums/showp...ostcount=16324 |
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16608 | Today 05:24 PM |
| Discussion Hobbyking Lancaster official owners thread | Tartago | Electric Warbirds | 930 | Today 11:22 AM |
| Discussion UMX Mig-15 DF Mod Thread | NitroCharged | Micro EDF Jets and Power Systems | 908 | Mar 28, 2013 08:53 AM |
| Discussion E-flite UMX MiG 15 DF SNEAK PEEK! | D PAYNE | Micro EDF Jets and Power Systems | 2210 | Dec 19, 2012 09:29 PM |
| Sold Eflite F-86 Sabre 15 DF NIB! | blue7.62 | Aircraft - Electric - Jets (FS/W) | 1 | Apr 05, 2012 01:35 PM |
