Old Feb 12, 2013, 08:38 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
I think it says on the charger what the colour codes mean.
I've not got mine with me but that sounds about right.
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Feb 12, 2013, 08:51 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Originally Posted by Go Pens View Post
Just pick up the mig @ lhs, flew great but my charger that came with the kit will not charge. Power on-green led flashes, plug lipo in-green still flashes, push start and red and green blink but not at the same time. any thoughts? I do have a thunder charger for other lipos I could use but I like the compact size of the stock one.
SilentPilot is right.
Green Blinking: Power and battery connected
Red Blinking: Charging
Red and Gread Blinking: Balancing
Solid Green: Full Charge
Both leds flashing rapidly: Error
If you think it's an error, check your power supply. Should be 12 Volts. Do not use a 6 volts adapter (Eflite use some with single cell charger)
RealGambler is offline Find More Posts by RealGambler
Old Feb 12, 2013, 12:20 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
Foam "filler"?
Had a little mishap a couple days ago, trying to avoid a garbage can while landing...
A marble sized chunk of foam was broken out, right at the top of the nosecone/intake. I have a large section of it but the rest was basically dust and blew away. Is there a good product to use for filling gaps in the foam when repairing?
I still need to hit it with hot water to see how much expansion I can get out of what's left, but I'm sure there will be gaps.
habitforming is offline Find More Posts by habitforming
Old Feb 12, 2013, 12:40 PM
BMFA 190658
Joined Mar 2007
I use gorilla glue to fill gaps.
Wet one surface, touch together, add the gorilla glue and tape over it. The glue expands and fills any gaps. Be careful though, you don't want it expanding into the air ducting...
Tony
Old Feb 12, 2013, 12:49 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Gorilla glue can be a pain to sand off if you use to much. I prefer to make the repairs with Foam-Tac and fill any voids with light weight spackle. much easier to sand.
16000kv motor ???
Dr John
pmpjohn is offline Find More Posts by pmpjohn
Old Feb 12, 2013, 06:57 PM
Valkpilot is offline
Find More Posts by Valkpilot
Valkpilot's Avatar
Joined Mar 2012
If you are using the stock charger that comes with the MiG, this is the wall
adapter you should be using:
http://www.horizonhobby.com/products...upply-EFLC4000
Valkpilot is offline Find More Posts by Valkpilot
Old Feb 12, 2013, 08:12 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
My MiG now has its "water wings"...Those that have been keeping up with this thread knows what this means......
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Feb 12, 2013, 08:47 PM
LowlyElevated is online now
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
finaly met the pond, eh?
LowlyElevated is online now Find More Posts by LowlyElevated
Latest blog entry: More Miniquad FPV!
Old Feb 12, 2013, 08:56 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
floats?
jim350 is offline Find More Posts by jim350
Old Feb 13, 2013, 07:14 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Kevin
So, how big was the rooster-tail?
Hope she survived her first (and hopefully last) bath!
Joel
turboparker is offline Find More Posts by turboparker
Old Feb 13, 2013, 06:25 PM
orbit_01 is offline
Find More Posts by orbit_01
Australia
Joined Jun 2009
Hi all, well after many flights and no crashes, the Mig has proven to be a fun reliable little edf :-)
However, the front bottom foam section of the intake on my Mig is becoming a little 'mushy' from the constant sliding on grass (it has always been a belly lander).
So, a while ago I was reading this forum and someone had made a clear hard plastic 'shroud' to fit over the nose of the Mig.
I can't remember who it was that made it, or what page it was on, so I was wondering;
1. Does anyone know if these shrouds/covers ever became commercially available?
2. If yes, can someone please direct me to the page and/or member that had the covers?
Thanks for any help as I would like to protect the Mig from further wear on landings before the airframe fails.
Cheers
orbit_01 is offline Find More Posts by orbit_01
Old Feb 13, 2013, 07:16 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
Just one page back...
http://www.rcgroups.com/forums/showp...postcount=3002
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Feb 13, 2013, 07:32 PM
orbit_01 is offline
Australia
Joined Jun 2009
Hi RCBABBEL,
Well that wasn't the post that I remember, but it will do very nicely.
Thanks very much :-)
Old Feb 14, 2013, 05:58 PM
Joined Mar 2007
Joel
Yep---She took a bath!!!...I had a cross wind and was trying to spot land the MiG...The wind blew her over towards me---I would have hit myself had I not ducked......The MiG flew over my head and I attempted a forced landing before reaching the pond...No dice!!!...I went to power up and gave up elevator...I was too low and too slow...Snap left, correct, snap right, try to correct and SPLASH!!!...The plane was floating upright with the intake above the waterline...(It is strange to talk about a jet being above the "water line"!!!)...I fished her out with a fishing rod...
So far, all checks out well after a good drying out...
Kevin
Old Feb 14, 2013, 06:06 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Kevin
Thats good to know... If the intake was above the waterline and the motor was also above the water you might have been able to water taxi it back!
-Brian
kalmon is offline Find More Posts by kalmon
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19303 Yesterday 10:00 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
