Old Feb 06, 2013, 07:18 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Originally Posted by Doug Sipprell View Post
Reference is made to the "parkflyer nose ring" for the MiG. I recall seeing photo's of it. Can anyone advise where to got one or more of these,
Parkflier Plastics
Dr John
pmpjohn is offline Find More Posts by pmpjohn
Old Feb 06, 2013, 08:44 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Reference is made to the "parkflyer nose ring" for the MiG. I recall seeing photo's of it. Can anyone advise where to got one or more of these, or is it a DYI affair?
Thanks.
FWIW: I am coming up on 100 flights with the mini MiG, and the nose is still............recognizable!
RD
Link:
Parkflier Plastics
-Brian
kalmon is offline Find More Posts by kalmon
Old Feb 06, 2013, 09:50 PM
AustinG is offline
Find More Posts by AustinG
United States, FL, Eustis
Joined Oct 2012
Still having a real problem getting as much thrust as I used to. I believe that the airplane is making a quite a bit more noise than it used to. It is now so loud that I worry about disturbing the neighbors while inside my house and testing it. That wasn't the case before.
I have cleared everything out of the airflow so that isn't the problem for sure. Not sure what to do with the engine to check it. The blades looked fine. So I don't really think it is a balance issue. Though I haven't tested it I would think that I would notice a difference since it was fine at one point and I assume it would need to have been damaged to not be balanced now.
AustinG is offline Find More Posts by AustinG
Old Feb 06, 2013, 10:53 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Dr. John, Brian..............thanks for the info.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Feb 06, 2013, 11:17 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
It's possible that it injested something which damaged the fan, so it's worth closer inspection. My top suspicion is that one of the motor's bearings has let go, which would be very uncommon but it matches your symptoms pretty well. Have you been flying 3s or any other modifications?
habitforming is offline Find More Posts by habitforming
Old Feb 07, 2013, 05:42 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
I completely agree, most likely a bearing else you sucked something in and it nicked/bent a fan blade. At these RPMs it doesn't take much even a slight bend will throw it out of balance.
-Brian
Old Feb 07, 2013, 08:50 AM
impmotor is offline
Find More Posts by impmotor
Horsham, PA
Joined Aug 2007
I no longer have the power that I used to, however, my motor is not as loud as it used to be after hundreds of flights. There does no seem to be any bearing noise that I notice. I wonder if it is possible that the bearings slowly start to have more and more drag. Has this happened to anyone else?
impmotor is offline Find More Posts by impmotor
Old Feb 07, 2013, 08:57 AM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Originally Posted by kalmon View Post
Link:
Parkflier Plastics
-Brian
Thanks! I was looking into this myself, ordered!
grovey is offline Find More Posts by grovey
Old Feb 08, 2013, 09:40 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
more likely the battery is getting worn. This little edf take a large draw from the batteries. I'd strongly recommend getting a lightened TP325mAh 65C pack from RCBabbel. It is simply the best performing pack that can be had for the little mig.
-Brian
Old Feb 08, 2013, 10:16 AM
impmotor is offline
Horsham, PA
Joined Aug 2007
-Brian
I doubt that this is a battery problem only because I have 10+ batteries and the problem does not seem to be dependent on any particular battery. I went flying yesterday morning and was unable to keep the MIG in the air due to what seemed to be a lack of power. However, the same battery in another EDF with an E-flite power system flew fine. Admittedly the second plane was a lighter profile EDF, but not by that much. I am ordering some new batteries, but would appriciate all advice.
Old Feb 08, 2013, 10:21 AM
impmotor is offline
Horsham, PA
Joined Aug 2007
Does anyone know of a good battery tester or a way to test the quality of a battery. The only way I know of to do it now is by the loss of flight times because the battery being no longer able to hold a charge for any length of time under use.
Old Feb 08, 2013, 10:28 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
The magnets in the motor also could be losing their magnetism. This happens after heat cycles. Though normally I wouldn't think the motor would get hot enough... Maybe it is just trying to tell you to install that new 16000kv motor.
The Revolectix / FMA PowerLab series will show you the internal resistance of each cell. This is the best way to measure the "health" of the pack. The lower the better.
-Brian
Old Feb 08, 2013, 11:20 AM
impmotor is offline
Horsham, PA
Joined Aug 2007
Brian,
Thank you for the info
Old Feb 08, 2013, 11:42 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Brian,
I know there are other less expensive ones out there, but I don't know which ones are good or not.
The Powerlab series require a good power supply as well don't forget to figure that into the price.
-Brian
Old Feb 12, 2013, 08:31 AM
Go Pens is offline
Find More Posts by Go Pens
Go Pens's Avatar
United States, PA, Venetia
Joined Nov 2010
Supplied charger
Just pick up the mig @ lhs, flew great but my charger that came with the kit will not charge. Power on-green led flashes, plug lipo in-green still flashes, push start and red and green blink but not at the same time. any thoughts? I do have a thunder charger for other lipos I could use but I like the compact size of the stock one.
Go Pens is offline Find More Posts by Go Pens
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19423 Aug 15, 2016 09:37 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
