Old Feb 04, 2013, 01:44 PM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
So long as they send you the MiG board then the gyros should be calibrated correctly, leaving you to just drop it in.
Tony
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Feb 04, 2013, 04:42 PM
xmech2k is online now
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Thanks for the good video, Bwoollia! Sounds like a fair, unambiguous review.
xmech2k is online now Find More Posts by xmech2k
Old Feb 04, 2013, 06:15 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by AustinG View Post
Awhile back HH sent me a new board for my Mig(for battery connector that pulled off). Will I need their programmable USB cord to make the AS3X system function when I replace the board?
No you will not need to program it, however There is no way to verify which programming is loaded on the board. The Sbach3D and Mig share the same board same part#) so you might have sbach programming on the board.
The USB programmer is cheap and there is now softare that lets you fine tune the gains on all 3 axis individually.
Sounds exactly like what I though of them link here. The Mig, even with less raw power, has a slightly higher top speed than the F-86. Probably due to the better airfoil.
-Brian
kalmon is offline Find More Posts by kalmon
Old Feb 05, 2013, 08:36 AM
AV8TRX is offline
Find More Posts by AV8TRX
AV8TRX's Avatar
Joined Feb 2012
Great video Bwoolia. It appears that the F86 is faster. I get the thrust to weight ratio difference, but is it actually faster?
AV8TRX is offline Find More Posts by AV8TRX
Old Feb 05, 2013, 09:38 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
I have flown my stock mig at the same time as someone flying a stock F-86. They are near identical is level speed however the mig holds energy better and is very slightly faster out of a dive.
-Brian
Old Feb 05, 2013, 10:54 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
-Brian
My thoughts exactly. I really didn't notice a significant speed difference. The undercambered wing of the F-86 is likely more draggy than the Mig's solid wing. The larger, heavier Mig holds its energy better but doesn't climb as well as the lighter F-86. Without measuring actual thrust or efflux, my gut feel is that the F-86 has more power which allows it to outclimb the Mig, but the extra drag keeps the speed in check.
The precision of the Mig is very nice, but I really like the "big air" flying you can do with the F-86. Honestly, they're both great models.
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Feb 05, 2013, 01:15 PM
AV8TRX is offline
AV8TRX's Avatar
Joined Feb 2012
Thank you
Old Feb 05, 2013, 01:36 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
If you want the best of both worlds (and dont mind a shorter motor life) put a tiny heatsink on the MIG's ESC FETs and Voltage Regulator and limit your throttle travel to 80% then you can usually run 3S packs! The other more involved option is so use an external ESC and and AEO Fan and a tiny 16000kv motor. 1:1 t:w on 2S! see the mod thread for info.
-Brian
Old Feb 05, 2013, 02:16 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
where are people getting these tiny heat sinks?
habitforming is offline Find More Posts by habitforming
Old Feb 05, 2013, 05:55 PM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
PM Erkq here on the forums, he has a source for them.
-Brian
Old Feb 05, 2013, 07:18 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Winds are down.
Need to set up my limbo pole....
(Video to follow?)
tracknoob is offline Find More Posts by tracknoob
Old Feb 06, 2013, 09:09 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Originally Posted by tracknoob View Post
Winds are down.
(Video to follow?)
YES!!!
I hate winter. We've been having winds of 10-30 mph non stop. Yes, I know the Mig could handle it, but when it's 30-40 degrees AND windy, it's just not much fun.
haven't even flown the little Sbach in the yard in a month. COME ON SUMMER!!!
whichwaysup is offline Find More Posts by whichwaysup
Old Feb 06, 2013, 09:49 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
Originally Posted by whichwaysup View Post
YES!!!
14 degrees and snowing here. It has been a light year for snow here, we've only got about 18" on the ground and a total of 31.5" fell in January alone. At this rate I'll be able to dig a tunnel in the snow and fly through it.
-Brian
Old Feb 06, 2013, 01:01 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
+17 F & snowing here. Feels like a heat-wave!
Haven't been able to fly the MiG since before we got the 1.5 feet of snow back in early December. It's been over a month since I've flown anything outdoors, and that was a 5-minute 130X flight from the deck. Last time I flew fixed-wing outdoors was before Christmas, when I got in a few ROS flights in the yard with the CC on floats. Since then, it's been too cold, too windy, too rainy, too icy, too snowy - or a combination thereof. Given that we lost our indoor spot, it looks like I won't be getting in much stick-time on anything but the MV & nCPX until spring - aside from maybe a few ROS flights with the CC & a few spins around the yard with the 130X now & then.
For 25 years, I simply accepted the fact that I'd get very little stick-time in during the winter. I got into micros when the original Sukhoi 26m came out in '09 & flew it at the sports center that winter. That was my first experience with indoor flying - aside from flying the mSR around the house. After just three winters of flying indoors, I'm going through 'RC withdrawals' because we lost our indoor spot. Funny how that works....
Lately, I've been satisfying my RC jones by DSing at the DS Ridgeline site in RF 6.5. With the default wind settings, I am able to get the Mistral 3m sailplane up to nearly 400 MPH without breaking or crashing it. I know that DSing in the sim is much, much easier than it is in real life. Nevertheless, it definitely keeps one's reflexes sharp during the off-season! I'd love to try it for real someday, but we're a bit shy on DS sites around here. However, DSing in the sim has perked my interest in getting back into fast planes. It's been over 10 years since I've had anything that flies over 100 MPH. I feel the need - the need...for speed!
Top Gun "Need for Speed" (0 min 15 sec)
Joel
turboparker is online now Find More Posts by turboparker
Old Feb 06, 2013, 06:25 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Nose Ring
Reference is made to the "parkflyer nose ring" for the MiG. I recall seeing photo's of it. Can anyone advise where to got one or more of these, or is it a DYI affair?
Thanks.
FWIW: I am coming up on 100 flights with the mini MiG, and the nose is still............recognizable!
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19222 Feb 03, 2016 03:36 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 03:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 07:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 05:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 02:35 PM
