Flew mine today in actual 20 mph winds, with gusts to ????..... got over the edge of our hill, caught in a swirl, turned the mig sideways, and it ripped both wings literally out of the sockets!
I CA'ed them back on, but have not had a chance to try to fly it again. I guess I know the max environmental conditions for this little hunk of foam now.... |
Congrats on getting the Mig back up and going - VERY MUCH looking forward to that contest entry!! Quote:
I've flown mine in wind up to 20, but not over it. I would have liked to see the vid of the "post wing removal" portion of that flight! WOW!
I know for a fact at least one separated in flight, and think they both might have, but on review, it is possible that the second one came off when it hit the ground. In any event, when I walked up to it, the fuse was lying upright, and the two wings were folded up over it, like a Corsair on the storage deck, held to the fuse only by the servo wiring!
New Twist on AS3X!! A custom software that allows independent incremental gain adjustment on each surface and (possibly) a way to enable and disable the gyros remotely using channel 5. Also stick override priority for each axis as well.
Software here. I am hosting this at my personal webserver. Files have been scanned with Kaspersky 2013 and clean of malware/spyware/virus. -Brian |
Joined Jun 2012
I rebuilt mine and used shoe goo to attach the servos.
going back in again to replace the impellor which is showing some signs of damage from sucking up stuff through the front of the fuse. Mine has never had a great amount of speed and after crunching the front as you mentioned on yours I rebuilt the fuse. It was bearly flyeable however I did notice the damage on the impellor. If this does not fix it I am going to shelf the little thing and just stick with my bigger planes. A shame since this is a nice looking plane when it is flying |
Had to reinforce a crumbled elevator and a couple other minor tweaks, but this is a tough little critter. Found just enough time this morning to run one checkout battery and then trim a bit, and one followup battery, before the horrible weather moved in. It flies pretty well. Ready for limbo contest at first sign of decent weather!
United States, FL, Eustis
Joined Oct 2012
Anyone know have a checklist of things I should be checking in regards to my thinking that thrust is reduced? The airflow to and from the engine is clear. I had to re-attach the battery connector at some point so it could be a bad solder job giving less power draw from the battery. Though I didn't notice any reduced power until recently. I had a crash and repair recently and it could be knocked a tad off kilter there as well. Though it seemed ok at a glance during the repair.
Check servo wires Check rotor/fan for balance/damage Listen for bearings going bad. Check battery for voltage droop under load Check nose for smooth intake (not crunched) -Brian |
Joined Oct 2012
By servo wires you mean them being in the way of airflow behind the fan? That part is clear. I had expected more thrust post fix because I had fixed a piece of tape that would always get detached from the side and protrude into where the air flows. |
I also have the parkflyer nose on mine and have no thrust reduction. I was really careful to trim it so that there was no lip on the ring and that the airflow was smooth. Check that the blades are not bent or rubbing as well. -Brian |
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16606 | Today 12:22 PM |
| Discussion Hobbyking Lancaster official owners thread | Tartago | Electric Warbirds | 930 | Today 11:22 AM |
| Discussion UMX Mig-15 DF Mod Thread | NitroCharged | Micro EDF Jets and Power Systems | 908 | Mar 28, 2013 08:53 AM |
| Discussion E-flite UMX MiG 15 DF SNEAK PEEK! | D PAYNE | Micro EDF Jets and Power Systems | 2210 | Dec 19, 2012 09:29 PM |
| Sold Eflite F-86 Sabre 15 DF NIB! | blue7.62 | Aircraft - Electric - Jets (FS/W) | 1 | Apr 05, 2012 01:35 PM |
