I would say that the reason the ma didnt last long wzs becuase of their higher c and higher c per mah ratio(a 25c pack thats 300mah has a higher c-per-mah than a 25c 200 for example). Becuase of this the mig is able to discharge the MA much faster than the hyp, resulting in a rather equal run time, but the MA would have output more power in that runtime than the hyperion did. Does any of this make sense?
Joined Jun 2007
It's easy to do, and it's best to do it before you crash. All you need is alginate to make a mold, some plaster to fill it and 85 to 90mm shrink tube. If the grass o your field is rough, you should also add a strip of tape on the wings for the same reason. Also, strengthening the elevator/tail wings (or whatever they're called) with either some clear plastic or carbon rod or strip, depending on what you have close by. Quote:
Hmm... Well this could be easier to do than the original mig airbrakes, but finding a mechanism that won't rip the fuselage would be wuite difficult and then again I'd properly have to land near a stretched wire or something. Interesting though ![]() Quote:
Now this is a really good one! The best so far is the pers switch (still didn't get an answer if it can transmit signal) and an electromagnetic relay. I'm a but reluctant about the relay as it's still a mechanical switch and tiny ones are just so hard to find! So, how do I program this chip? Will any of the starter packs do? Then again I have no clue on how to program this thing, so I'll need a lot of guidance, best to continue in this thread. |
Yes. It's all about the pack's internal resistance. Higher C packs have lower internal resistance than lower C packs. Higher capacity packs also have lower internal resistance than lower capacity packs. Therefore, a higher capacity, higher C pack will have an even lower resistance. (Of course - we're talking true capacities & C-ratings here, not the advertized numbers.) As the resistance of the source decreases, voltage at the load increases. Therefore, energy delivered to the load must also increase at given throttle setting. Given that wattage increases at the square of the voltage, a small increase in loaded voltage corresponds to significant increase in available power. Given that the TP 325 65c pack provides a noticeable increase in performance over the MA 300 30c, and given that the MA 300 30c provides a noticeable increase in performance over the the Hyp 240 25c, we know that the MiG pulls significantly more current with lower resistance packs. Hence, flight-times will be shorter when no throttle-management is used. However, if one uses throttle-management, flight-times will actually increase. Higher voltage under load means that less current is required for a given maneuver, so those who practice strict throttle-management typically see longer flights at higher voltages. For example - my Sbach 3D flies longer on a Hyp 180 3s pack to the 80% discharge point than it does on a Hyp 180 2s pack because I only use a fraction of throttle during a typical flight than I do on 2s. Of course, we're talking a UM EDF, so "throttle-management" pretty much consists of firewalling it until it's time to slow her down for the approach! ![]() ![]() Joel |
one of the two times I ever crashed the mig was when I had to duck because I gog to close to myself. The other time was when low airspeed and a violent crosswind, and motor torque actuly got the thing to tipstall. At least it landed in the grass.
Canada, QC
Joined Oct 2009
United States, TN, Jackson
Joined Mar 2007
Some things to remember for extended battery life---On downward lines reduce the throttle to 1/4-idle...For example: At the top of a loop I'm back to 1/2 throttle and once the model starts to arc over I reduce the throttle to about idle...With practice you can make your loops not only the roundest but keeping the same speed throught the loop...(Nothing looks more like an underpowered toy than to pull through a loop, loose a ton of airspeed, and then zoom down at full throttle with a quick yank upward for an egg-shaped loop!!!)...Altitude at the exit is always the same as the entry for the best looking loops....
I like to swap out inertia for throttle...In a split "S" I will back off of the throttle to idle (NEVER to OFF as this causes drag within the duct with a stopped or freewheeling rotor) on the downline and nail the throttle when just about level...The plane maintains about the same speed for a smoother looking flight...With all of that speed you gained for free on the downline and then full throttle when level you can do larger loops using LESS throttle...It's all about inertia and throttle management...I know that it can be hard to use the inertia from a 2.5 ounce model but it can be done!!! Years ago (about 20) when nitro powered ducted fans ruled I saw BVM rep Garland Hamilton routinely make 15+ minute flights with a Maverick Pro when all of the rest of us were getting 9-10 minutes at best...BV himself once scolded him for flying so long as he didn't want to see Garland ding one of his planes...But Garland was a MASTER at using throttle management, swapping out inertia for throttle, and only using enough throttle to get the manuever accomplished...Even with 15+ minute flights Garland ALWAYS landed with enough fuel for a go around or two!!! Kevin |
What is the difference between idle and off with an electric motor? 10% power or less?
Latest blog entry: Maybe my fleet is too big...
Joined Mar 2007
You've gotta remember that a jet has TWO forms of drag---The exterior of the plane and the interior ducting with motor/rotor...On a downline, don't go to the OFF position on the throttle---Carry some "idle thrust" with you on the downline...You will keep the speed up for VERY little cost in battery power as the rotor will be spinning with a little power, causing less drag... Kevin |
With conventional props, even a prop at a low power setting for the flight-speed will have considerably more drag than a stationary prop. If that's also true with EDF rotors, one could enable the prop brake on the brick to make sure that the rotor contributes the least amount of drag as possible when the power is pulled back on down-lines.
Joel |
On my down-lines I usually use about 1/3 to 1/2 throttle increasing throttle as I roll out to level flight. -Brian |
Now here is my problem: On these small electric motors they spin extremely freely there very little drive-train drag unless it is a geared system. So the largest form of drag in a windmilling prop in full scale is gone as there is no engine to turn. Granted yes there is motor mass that has to rotate but it is so little at this scale I wonder how much difference there really is. Bottom line even in this small scale a free spinning prop/blade will have more drag than a stopped one. But maybe not much more? Maybe some aeronautical engineer here can chime in and help. -Brian |
| Thread Tools | |
| Discussion Official Eflite UMX Beast Owners thread! | darksiede | Micro RTF | 16615 | Today 05:08 PM |
| Discussion Hobbyking Lancaster official owners thread | Tartago | Electric Warbirds | 930 | Yesterday 11:22 AM |
| Discussion UMX Mig-15 DF Mod Thread | NitroCharged | Micro EDF Jets and Power Systems | 908 | Mar 28, 2013 08:53 AM |
| Discussion E-flite UMX MiG 15 DF SNEAK PEEK! | D PAYNE | Micro EDF Jets and Power Systems | 2210 | Dec 19, 2012 09:29 PM |
| Sold Eflite F-86 Sabre 15 DF NIB! | blue7.62 | Aircraft - Electric - Jets (FS/W) | 1 | Apr 05, 2012 01:35 PM |
