Old Nov 23, 2012, 01:59 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Originally Posted by pugsam View Post
The problem that I (and, I believe, a number of others) have had is that the aircraft often fails to bind long after it is no longer new.
That is, when the tx and then the plane is powered-up, the LED continues in flashing mode and the controls do not respond. Sometimes, this will repeat many times before the LED "bind" light goes solid and the intialization process then can begin.
I know better than to argue technical nuances with Joel. If it's wrong to refer to that as a binding problem, so be it.
But whatever it is, it's a problem.
And I haven't solved the problem. Sometimes moving the tx farther away seems to help. Sometimes it doesn't. In general, the phenomenon seems to be pretty much random.
However, considering how cool the Mig is, things like like this, although annoying, are just mild turbulence......
I've found something that seems to work *MOST* of the time on the binding/initialization/linking/connection-activity-between-tranny-and-thing-with-wings-thingy. If you keep some object between the plane and your transmitter, it seems to (insert proper technical term here) with less issues. Probably accomplishes the same thing as having the transmitter farther away, but I get nervous and feel stupid walking my transmitter 15 feet away, then walking over to my Mig, then trying the battery, then going and getting my transmitter (assuming someone didn't inadvertently step on it).
Try it. Doesn't work all the time, but it seems to work more often than not.
whichwaysup is offline Find More Posts by whichwaysup
Old Nov 23, 2012, 02:34 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
I just turn around so that my body is slightly in the way
airpower is offline Find More Posts by airpower
Old Nov 23, 2012, 03:30 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Yup. Anything that reduces the signal strength will work. Hence, why I point the tip of the tx antenna at the aircraft. That attenuates the signal by at least 30 dB (1/1000). Your body will also attenuate 2.4 GHz by about 30 dB or so. In contrast - doubling the distance only attenuates the signal by 6 dB (1/4).
Joel
turboparker is offline Find More Posts by turboparker
Old Nov 23, 2012, 03:40 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
I'll try holding the TX up to my temple.
The metal plates in my skull could really git that sucker attenuated.
pugsam is offline Find More Posts by pugsam
Old Nov 23, 2012, 04:08 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
My plane will intiallize but at times the LED won't light up after all of the beeps...Everything works but no LED lit on the brick...I don't feel comfortable without seeing the LED flash then come on solid after initiallization so I re-initiallize the plane to get the LED...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Nov 23, 2012, 07:17 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Correction !
As a correction to my previous post, my Mini MiG gives out a single "Doodley" after complete initialization, not a "Doodley-Doodley". I must have had a CC Phenoix ESC in mind.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Nov 24, 2012, 04:03 PM
Joined Mar 2007
I just now flew the MiG and it's 43*...What a ROCKET it is in colder weather!!!...My lipos are kept warm (room temp/72*) and don't fade off in flight due to only the bottom of the batt exposed to the cold air in flight...This plane is now one of my favorites!!!
Kevin
Old Nov 24, 2012, 10:29 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
Kevin
my first mig has been dinged, bent, broken in two & glued back together so many times...it still flies great, even with the extra glue weight !
i'm fixing to buy another with no hesitations
KCinNC is offline Find More Posts by KCinNC
Old Nov 25, 2012, 12:12 AM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Happy to report Nitrocharged MIG bra saved the nose of my MIG twice today.
First was battery velcro gave way at launch end in a nose plant into the ground and a cartwheel. No damage.
Second was a botched hand launch. Tail of plane caught my hat and ended in a nose plant into the ground. Again no damage to the airframe. MIG bra sustained a small crack.
jim350 is offline Find More Posts by jim350
Old Nov 25, 2012, 12:17 AM
KCinNC is offline
Joined Aug 2007
is this mig bra for sale here ??
Old Nov 26, 2012, 03:29 AM
SilentPilot is offline
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
I wanted to test fly my MiG in some 15kt winds the other day but forgot to take my MA300s with me. I had some TP325s but I never tried to fit these as they are a lot deeper than the Miniaviations...
Do you guys scoop out some foam for the TPs to fit? I would really like to try these, any help would be appreciated!
Tony
SilentPilot is offline Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Nov 26, 2012, 08:35 AM
Joined Jul 2009
Factory TP 325 mAh 65c UMX packs now available!
Tony,
I just let the TP 325s hang down a bit. So far, I have not had any problems - even when belly-landing on grass. I just bring her in nose-high when belly-landing. I suppose one could shave a bit of drag by flush-mounting them.
Hey Nitro,
You must have had a bit of inside info! TP is now making 325 mAh 65c UMX packs: http://www.horizonhobby.com/products...-THP3252SPP65B
Joel
Old Nov 26, 2012, 09:00 AM
BMFA 190658
Joined Mar 2007
Thanks Joel, I'll try that
Old Nov 26, 2012, 09:35 AM
mavdriver is offline
Find More Posts by mavdriver
mavdriver's Avatar
United States, CA, Apple Valley
Joined May 2002
Tony
Tony I actually lay them flat on the bottom where the original lipo fits but i did had to cut out some foam to make it fit that will also makes the mig fly better with out having the wires and battery hang low I posted a while back go to this link and go to post 1589 http://www.rcgroups.com/forums/showt...6#post22527570 you will see the pic of how i did it
mavdriver is offline Find More Posts by mavdriver
Old Nov 26, 2012, 09:39 AM
BMFA 190658
Joined Mar 2007
Sounds good
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19361 Jul 13, 2016 07:43 AM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
