Old Nov 22, 2012, 02:47 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
I think what he means is that the servos make no noise when its bound like non as3x ums.
Ultra micros with linear servos are the only type of plane that make noise without moving the sticks.
The as3x servos are so powerful and quick and thus dont need to make tiny corrections and thus noise.
airpower is offline Find More Posts by airpower
Old Nov 22, 2012, 03:32 PM
pmpjohn is offline
Find More Posts by pmpjohn
Dr John
pmpjohn's Avatar
Lake Placid, Florida
Joined Dec 2001
Originally Posted by Waffleman View Post
When I power it up, I have towigglr the sticks on my radio or it will act like its not bound. Is this normal?
describe "act like its not bound". The gyros will not initalize until after the throttle has been blipped and this is normal. If it is not bound wiggling the sticks will do nothing.
Dr John
pmpjohn is offline Find More Posts by pmpjohn
Old Nov 22, 2012, 06:02 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
My MiG, sometimes when binding, will act like it's going to bind and goes through all of the beeps but the LED on the brick never comes on...Not exactly feeling the warm fuzzies over this I always move the TX away from the plane and re-bind, making sure that the LED is lit...All is well when the LED on the brick is lit...
I'm thinking that all of these binding issues are due to the TX being too close during binding...Make sure that the TX is at least 4 feet away from the plane when binding...
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Nov 22, 2012, 08:35 PM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
I see that some people are mixing up terms. Binding is what you do with a new aircraft. You fire up the aircraft, and then fire up the tx while pushing the bind button. Powering up the tx and then powering up the aircraft to fly is called initializing - not binding. Losing bind & failing to initialize are completely different issues. To eliminate confusion & make it easier to troubleshoot problems with these bricks, I suggest that we use consistent terminology.
Joel
turboparker is online now Find More Posts by turboparker
Old Nov 22, 2012, 09:25 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by turboparker View Post
.....Binding is what you do with a new aircraft......
The problem that I (and, I believe, a number of others) have had is that the aircraft often fails to bind long after it is no longer new.
That is, when the tx and then the plane is powered-up, the LED continues in flashing mode and the controls do not respond. Sometimes, this will repeat many times before the LED "bind" light goes solid and the intialization process then can begin.
I know better than to argue technical nuances with Joel. If it's wrong to refer to that as a binding problem, so be it.
But whatever it is, it's a problem.
And I haven't solved the problem. Sometimes moving the tx farther away seems to help. Sometimes it doesn't. In general, the phenomenon seems to be pretty much random.
However, considering how cool the Mig is, things like like this, although annoying, are just mild turbulence......
pugsam is offline Find More Posts by pugsam
Old Nov 22, 2012, 09:33 PM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
I also need to make the the transmitter isn't too close or it won't bind on power up... Happens every once in a while, hopefully it doesn't become more frequent
Aphro is offline Find More Posts by Aphro
Old Nov 22, 2012, 09:40 PM
LowlyElevated is online now
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Lets try this again:
When I power up the RX, it will not initalize the bind unless I wiggle the sticks on the TX right after plugging in the battery on the plane. Sometimes, it still dosen't initialize and has to be unplugged and tried again. And even rarer, I sometimes have to rebind it entirely.
Is this a fairly common issue?
I have never lost bind in flight, but it can be kind of annoying sometimes.
LowlyElevated is online now Find More Posts by LowlyElevated
Old Nov 22, 2012, 11:42 PM
Joined Jul 2009
Dave,
What you describe is not a failure to bind. It is a failure to initialize. If the rx actually lost bind, it would not initialize - regardless of how many times you disconnected & reconnected the pack. You would have to go through the bind procedure over again.
Waffleman,
Thanks for clarifying. I have had initialization failures on occasion - but only with certain bricks. It never happens with either of my Beast 3Ds, and it rarely happens with my MiG. It happens quite often with my Blade 130X & Carbon Cub. I sometimes have to disconnect/reconnect the pack a few times, however wiggling the sticks has no effect.
I have noticed that due to differences in rx antenna orientation, some of the UMs are more sensitive than others regarding transmitter separation distance. I always have the best results by initializing with the tip of the tx antenna pointing at the tip of the brick's antenna if possible. This puts the receiver in the deepest null of the tx antenna's pattern & it puts the transmitter in the deepest null of the rx antenna's pattern. Next best is to have the tip of the tx antenna pointing at the brick, with the rx antenna perpendicular to the tx antenna. But as Dave noted - moving further away doesn't always work.
On very rare occasions, I have had to actually re-bind. But again - only with those certain bricks.
Joel
Old Nov 23, 2012, 05:48 AM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
my bad... initialize...
Old Nov 23, 2012, 06:23 AM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
When using a DSM2 transmitter it also helps to turn on the Tx and wait a few seconds for it to chose which frequencies to use before powering the Rx. Reinitializing is not uncommon, having to rebind is fairly rare.
Dr John
Old Nov 23, 2012, 07:09 AM
Joined Sep 2012
I am using a DSMX DX8 trannsmitter. What I have descibed will happen almost every time unless I wiggle the sticks. I think It might have something to do with the reciever trying to find the trannsmitter output, if I don't wiggle the sticks the reciever will be looking but it won't "find" the trannsmitter.
My mig is one of the early production models (early summer of this year), so it might have a bug or two in the electronics.
Old Nov 23, 2012, 07:16 AM
pmpjohn is offline
Dr John
pmpjohn's Avatar
Joined Dec 2001
My first Mig was ordered the day they showed up on the HH site. I bound it once to my DX8 and it has stayed bound ever since. I have had a few times to repower to get it to initialize. Definately sounds like you have other issues with yours. I would contact HH customer service about your problem and let them handle it.
Dr John
Old Nov 23, 2012, 08:32 AM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
DX8 here too with no problems. Connects from about 3 ft. Actually I don't pay much attention to the distance because it connects in about 10 seconds consistently. Sounds like something wrong with the plane. Maybe a broken ant, or somesuch.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Nov 23, 2012, 09:02 AM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Of all my Micros in the fleet, the UMX MiG has been the only one to fail in the initializing proceedure. Wiggling the sticks doesn't help. I listen for the "doodley-doodley" tone after connecting the pack. When I hear that, I know the initialization has been complete, and the plane is ready to fly. A bit of an aggravation, but nothing too serious. As noted, there will be no sound from the servos until you blip the throttle to turn on the AS3X. Overall, I am definitely pleased with this Mini Mig.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Nov 23, 2012, 01:15 PM
Joined Sep 2012
Im not going to call customer support. Once it is initialized, It stays initialized, so I dosen't treally bother me.
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19352 Jun 16, 2016 01:08 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
