Old Nov 13, 2012, 11:15 AM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Anybody here who is running 3s on their mig?? I Wana try the same 180mah 3S nanos that I get such great performance from in my Sbach in this mig?? Will I need any mods??
Or can I just pop the battery straight in and just fly her. My mig is currently out of commission due to two broken servos ( my fault, I was running them at 120% rate)
I'm planning on getting another one and use the old one for spare parts.
Oh and for whatever its worth I've been watching my telemetry a few times,, and at least during the times I've watched,, never have gotten ANY holds or frame losses but then I always like flying my mig in close. :-)
Airman74 is offline Find More Posts by Airman74
Old Nov 13, 2012, 01:01 PM
FragGyver is offline
Find More Posts by FragGyver
Joined Aug 2012
Hi guys,
I bought a UMX Mig-15 a week ago as my third plane (4CH EasyStar clone and UM P51) and i realy enjoy flying this little screamer. Only one thing for me to mention: It'S hard to recognize the orientation of the plane, but maybe that's because of the cloudy and foggy weather here in Vienna? But I never had this problems with my other planes.
Anyway, my question:
My plane always wants to climb (especially at WOT) and I need about 10 clicks of trim for level flight. The elevators look pretty good, the CG is 58mm with my NanoTech 260 all the way forward.
Is this a normal behavior of this plane?
Thank you very much and greets from Austria!
FragGyver
FragGyver is offline Find More Posts by FragGyver
Old Nov 13, 2012, 02:30 PM
SLK Count is offline
Find More Posts by SLK Count
Beast 60E Maniac
SLK Count's Avatar
Hamburg, Germany
Joined Feb 2010
Gyver, first of all you should have elevator horizontal--- if you have positiv elevator your plane goes nose inverted.
Some Migs from our german board (rcline) come with positiv elevator adjustment out of box...I bent the linkage to neutal elevator and moved the lipo pack (200 stock and 240 mylipo) backwards.
Now at calm days the Mig is a bit nose down, with wind horizontal....some guys cut foam and created more space.
Untypical that your Mig goes up if the elevator is horizontal
SLK Count is offline Find More Posts by SLK Count
Old Nov 13, 2012, 02:31 PM
airpower is offline
Find More Posts by airpower
Have fun
airpower's Avatar
United States, CA, Mission Viejo
Joined May 2007
This baby's price is 150 now, buy it while you can!
airpower is offline Find More Posts by airpower
Old Nov 13, 2012, 02:49 PM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
Originally Posted by FragGyver View Post
......Anyway, my question:
FragGyver
FragGyver,
Welcome to the MiG club!
The MiG should track like an arrow at any throttle setting. It should not pitch up or down as the throttle is opened or closed. If it pitches up as you add throttle, pitches down when you cut the throttle, and needs visible up-trim for level flight, it's nose-heavy. If it pitches down when you add power, pitches up when you cut the power, and needs visible down-trim for level flight, it's tail-heavy. When the CG is right, the plane should remain level at any flight power setting, the nose should only drop slightly when you cut the throttle, and you should be able to roll inverted & only need a small amount of down-elevator to maintain altitude. Try moving the pack about half-way back & see how it flies. Be sure to center the elevator trim before the flight.
Also - be sure to mechanically trim the plane once you've got it flying straight & true. Anything more than 3-4 clicks of trim will screw up the AS3X system, as it interprets excessive trim as pilot input.
Joel
turboparker is offline Find More Posts by turboparker
Old Nov 13, 2012, 02:57 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
FragGyver
Move the lipo all the way to the back. Your climbing because your holding the nose up with all that trim because you're nose heavy.
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 14, 2012, 01:50 AM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
Only 3 flights on my (3rd MiG because the 1st 2 were defective) and the right aileron ripped away from the wing closest point to the fuselage... I guess that is why the price is dropping on the MiG... I should have waited longer I guess
Aphro is offline Find More Posts by Aphro
Old Nov 14, 2012, 06:20 AM
Joined Aug 2012
Thank you for all your advices. But unfortunately it doesn't matter anymore.
Went out to today to try different CGs when suddenly I couldn't hear the engine anymore and had no control. Well, my MIG crashed and hit a tree.
So I need new wings, the tail set, maybe the fuse set and an aileron servo. That's about 80 Euros, maybe it's better to buy a new one for 140 and use the old one for spare parts?
I have no idea why this happened, i always fly my P51 at this place and newer had a problem with interferences.
Sad day, I really liked to fly this plane (for about 10 batteries) and as I'm a student it's quite an amount of money.
Old Nov 14, 2012, 06:56 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I have no idea how the Customer support is over there but in the US if you had a complete power loss on the 10th flight HH would usually have you send the model back and replace it with a brand new one. Try your customer support options.
-Brian
kalmon is offline Find More Posts by kalmon
Old Nov 14, 2012, 12:10 PM
airpower is offline
Have fun
airpower's Avatar
Joined May 2007
Did you hit lvc?
Old Nov 14, 2012, 12:44 PM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
And what Transmitter were you using?
whichwaysup is offline Find More Posts by whichwaysup
Old Nov 14, 2012, 02:57 PM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
Just get you some depron and make the parts that I broke. Should be able to get fairly close if you can somewhat piece the parts back together and trace them out on some foam.
stingeragents is offline Find More Posts by stingeragents
Old Nov 14, 2012, 02:59 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Use some glue.....
I've smacked off wings and tails on my mig and glue really works well....
Old Nov 14, 2012, 08:30 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
Originally Posted by NitroCharged View Post
Use some glue.....
ah glue....where would we be without glue i ripped my mig in half at the field....glued it back together....was back flying in 10 minutes !
KCinNC is offline Find More Posts by KCinNC
Old Nov 15, 2012, 12:35 PM
rcoconut is online now
Find More Posts by rcoconut
Do you see what I see?
rcoconut's Avatar
Rancho Cucamonga, CA
Joined Sep 2006
Awe man, sorry for your loss, don't give up on her, go with the glue.
Good luck
rcoconut is online now Find More Posts by rcoconut
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19423 Aug 15, 2016 09:37 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
