Old Nov 11, 2012, 09:37 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I just now bought one of these for a good price on Ebay...I can now count myself into the MiG 15 group!!!...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Nov 11, 2012, 09:52 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Kevin
Congrats Kevin, and welcome to the club! I love mine and hope you do as well. (Though I like ROG flight and it's a bit tough right now with all the snow and the park walkways having 2 to 3 foot high BURMS on either side ... kinda like rolling down the Death Star trench for take offs and landings!
Marlin
Fish99 is offline Find More Posts by Fish99
Old Nov 12, 2012, 06:47 AM
vadimpelau is offline
Find More Posts by vadimpelau
Joined Jun 2007
Originally Posted by vadimpelau View Post
Hi guys, need some help over here.
Today I noticed a high frame loss (or I think it's high), 83 with my first batt, 130 and 1 hold with my second one.
I performed a range check and as long as I was facing the plane I had no lost frames or holds for about 40 meters or ~130 feet.
Is this normal? I might just be noticing this now but... better safe then sorry.
So, anyone happened to take a peek at their telemetry?
vadimpelau is offline Find More Posts by vadimpelau
Old Nov 12, 2012, 07:37 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Originally Posted by Planecraazy View Post
Flew it today with no problems and same battery in it, same battery I fly in my sbach, who knows, just a quirk I guess. Plus on 3s the voltage would have to drop waaay down to hit lvc right? Flew a 3 min flight on it today with that batt........
Planecraazy,
You're right. I somehow missed that you were running 3s. A 3s pack would be toast if the voltage dropped that low even once. I accidentally flew to LVC with one of my Hyp 180 3s packs in the Beast 3D. Instant pack death. The pack had puffed up enough that I could barely remove it from the plane.
Kevin
Kevin,
Welcome to the MiG club! It's my first EDF - and I love it! Like Marlin, I prefer ROG flight, but the MiG really scoots when you remove the gear, and it's a great belly-lander! Good packs are pretty much mandatory, as the MiG pulls more current than any of the other UMX planes.
Marlin
Hi Marlin,
That would make a cool video! Hmm.....how about ROS takeoffs on the belly? Just have to keep the nose up so the MiG doesn't turn into a micro snow-blower.
BTW - it's snowing pretty hard here right now. It's the first snow of the season that hasn't melted as it hit. It's supposed to warm up to 45-50 F later this week, so it won't stick around very long. Hope I can get in a few MiG flights at the club field. It's been over a week since we've had any decent flying wx around here.
Joel
turboparker is offline Find More Posts by turboparker
Old Nov 12, 2012, 09:32 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
I flew my Sbach UMX for about 4 minutes yesterday and went plenty far away (almost far enough to lose orientation) as well as did usual acrobatics which would have put the fuse (and it's internal receiver antenna) at various orientations to the transmitter antenna, and I saw that I got 3 Fades and zero holds for that flight, if that helps any....
tracknoob is offline Find More Posts by tracknoob
Old Nov 12, 2012, 10:16 AM
Joined Mar 2007
I'm going to take the gear off and fly her from my back yard...I don't have access to a good smooth runway unless I go to a church or school parking lot...I have plenty of good batteries----Hyperion, TP, and NanoTechs....
For those using 3S batts---Are you getting away using 3S batts without modding the brick or are heatsinks on the FETs and VR necessary???
Kevin
Old Nov 12, 2012, 10:18 AM
Joined Jun 2007
Well that sounds bad... for me. Flew again today I lose 80-90 frames on average and 1 hold every 3-3:30 minutes.
I usually fly as far as 90m or 290feet (measured with google maps there's some kind of tool in the labs section)
I had a nasty crash last week that broke off the antenna so I soldered a slightly thicker wire and I mean SLIGHTLY, you wouldn't be able to tell the difference!
Also I put a dab of bath caulk/rubbery silicone around the antenna base to prevent it from breaking in future crashes. Could this be the issue?
If anyone can shed more light on this please do so.
Thanks!
Old Nov 12, 2012, 10:55 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Very much yes, if you did not match the LENGTH of the exposed wire part EXACTLY to the dimensions of the old antenna! Antennas have to be matched to the frequency, and I suspect yours is now either slightly too short or too long.
I don't want to be a nervous nellie, but really, you should be qualified and licensed before trying to repair transmitter/receiver combos. On the receiver side worst case is probably poor performance, but anyone without correct knowledge and qualifications messing with the transmit side could easily run afoul of FCC by causing interference into non-hobby bands!
Old Nov 12, 2012, 11:18 AM
Joined Jul 2009
Thanks!
That would do it. RF does not behave at all like DC or low-frequency AC. Length-to-diameter ratio affects antenna tuning. The fatter the antenna, the shorter it needs to be. This is a big deal at 2.4 GHz, due to the short wavelength. The insulation type, or lack thereof also has an effect on antenna tuning. Plus - many household caulks are lossy at radio frequencies - even though they may be insulators at DC or 60Hz. And loss increases dramatically as the frequency goes up. At 2.4 GHz, everything matters. The amount of solder used to connect the antenna will affect its tuning.
With all things RF - the higher the frequency, the more critical everything becomes. What may have been "good enough to get by" at 72 MHz simply won't cut it at 2.4 GHz.
Joel
Old Nov 12, 2012, 11:48 AM
Joined Jun 2007
Thanks. I'm going to start by removing as much as possible from the silicone. If I don't notice a decrease I'll shorten it a few millimetres and if even this doesn't help I'll replace it completely.
The solder joint is extremely clean I always noticed that on the e-flite micro models.
Will report progress.
Old Nov 12, 2012, 02:08 PM
Joined Jul 2009
Just a heads-up - antenna tuning at 2.4 GHz is done in very small increments, as a 1/2-wave antenna is only about 60mm in length. I suggest getting a replacement antenna if removing the silicone doesn't solve the problem.
Joel
Old Nov 13, 2012, 04:42 AM
Joined Jun 2007
Does E-flite actually sell that tiny wire anywhere? I tried searching but I don't even know what gauge the wire is supposed to be...
Old Nov 13, 2012, 07:23 AM
Joined Jul 2009
I've heard of others getting replacement antennas for these bricks, but I'm not sure how they went about getting them. I suggest calling HH tech support.
Joel
Old Nov 13, 2012, 07:47 AM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
I lost the antenna on my UM 4-site.
Called Horizon and told them it was about 18 months old with hundreds of flights.
They had me send in the old brick and sent me a new brick free of charge.
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Nov 13, 2012, 08:04 AM
Valkpilot is offline
Find More Posts by Valkpilot
Valkpilot's Avatar
Joined Mar 2012
God how I love this machine! A little breeze and a little cold doesn't stop it's superior performance. Only the human element, such as today when I was flying. Darn thing seemed to want to climb a lot. Didn't realize until after the last flight, that somewhere along the line
I'd put in some up elevator. Unfortunately, winter's closing in and I'll probably have to set her aside for a while and fly my heavy duty birds.
Valkpilot is offline Find More Posts by Valkpilot
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19286 Apr 11, 2016 03:54 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
