Old Sep 30, 2012, 02:24 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Now, now boys.
What would Mrs. Cleaver say?
pugsam is offline Find More Posts by pugsam
Old Sep 30, 2012, 02:27 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Originally Posted by pugsam View Post
......What would Mrs. Cleaver say?
This.........
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Now, now boys.
Har... and I'm usually the guy who says, "Get a room!"
erkq is online now Find More Posts by erkq
Old Sep 30, 2012, 03:00 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Originally Posted by kuczy View Post
Been doing it since the Beast V1 and the batteries are room temp after charging.
Curious here... When the Beast V1 came out, the only NanoTech available for it where the 120mah and 180mah (and even then, it took a while for those to come out). Are you talking about charging those batteries at 10C? I absolutely love them, and own them since the first day they came out. Great batteries, but I would not dare to charge them at more than 5C (Though I accidentally charged 4 of them at 12C once so I know they can take a beating... My mistake, nothing happened).
RealGambler is offline Find More Posts by RealGambler
Old Sep 30, 2012, 03:31 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
^Hyperion 180's and 240's. The 240's were a little heavy for it though IMHO
Not trying to through my weight around. Just trying to say It's not my first time trying this or jumping into something. I've done it for for a while. I didn't just try it and walk away, come back and then post it. It works and the batteries are fine. Yes you should charge them at a lower rate and yes you should charge and discharge them a few times before going that high. This works for me and its how I've been doing it with other small 2s packs. I'm still flying my COX Zero with the same 2s 370 and 460 Nano's and I've charged them at 6amps for over a year as well...
kuczy is offline Find More Posts by kuczy
Old Sep 30, 2012, 07:23 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
I'm glad it is working for you, however, I just want to make sure that anyone who does try this: Don't leave the batteries alone while charging! At this rate a battery *might* blow. Just be safe and keep an eye on them while charging.
-Brian
kalmon is offline Find More Posts by kalmon
Old Sep 30, 2012, 10:58 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
You should never leave any lipo alone while charging. That's usually when people have an accident.
My buddy and I have done this for some time now.
Like I said the batteries have never been more than room temp after charging. If you don't want to do it then don't. I guess it's like the 3s thing except after hundreds of charges between the 2 of us, and I assume more, there hasn't even been the slightest sign of a battery even slightly warming.
Luke
On a side note I had 5 great flights today. I spent one flight inverted for almost the entire pack. It's nice to be able to fly an EDF off the back porch and not have to go to the field. Even though the vertical is lacking giant loops are still easy to do and like I said inverted is pretty easy with just a little bit of down elevator.
Old Oct 01, 2012, 03:55 AM
jpt1205 is offline
Find More Posts by jpt1205
Mayday! Mayday!
jpt1205's Avatar
Joined Aug 2010
I'm still waiting for my foam safe CA (I'm deployed to a certain Middle Eastern Country and cannot run down to my LHS, unfortunately) to attach the small CF rods/strips I got to reinforce the H Stab on my Mig. I've flown 6 or 7 times since last week and I didn't notice any H-Stab flexing issues...yet. I did notice the center portion of the V Stab where it meets the H Stab is already reinforced with hard plastic... is that standard with past versions?
Anyway--so far, so good...love this little EDF! It is starting to get a little stained on the underside and intake with fine dust/dirt because of the area I fly in...is there a recommended cleaner/wipe for this foam or am I best off just to use water and a clean cloth? Hopefully she holds up well until I can return home in less than 2 months!!!
jpt1205 is offline Find More Posts by jpt1205
Old Oct 01, 2012, 09:14 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Was out at the club field yesterday along with - well, I'm pretty sure every other member . Man, it was great to see so many folks out there. A couple guys took out their EDF's - not very common in our club, so I couldn't resist and pulled out the Mig. It was pretty funny to see an oversized ME 262, a JAS Gripen (again, pretty danged big), followed around my my little Mig. To it's credit, it kept up pretty well! A few low inverted passes down the runway got some comments.
I was definitely outclassed, and had one come up behind me too close, I'm pretty sure it would have sucked me in and spit out "mig mash" without missing a beat, but it was a great time.
whichwaysup is offline Find More Posts by whichwaysup
Old Oct 01, 2012, 10:06 AM
mavdriver is offline
Find More Posts by mavdriver
mavdriver's Avatar
United States, CA, Apple Valley
Joined May 2002
Just a quick tip you can use a credit card cut it about 1/4 of an inch and glue with foam safe CA to your stab , it really has made the elevator more responsive , before it felt sluggish , now its great IMHO .
mavdriver is offline Find More Posts by mavdriver
Old Oct 01, 2012, 10:11 AM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
I did the plastic spoon over the servos mod and it really protects them well and it's pretty aerodynamic too. I used regular white spoons, but last night we went to DQ and ended up with some smaller red spoons that might work also and save some weight in the process. I"ll see how well they fit later.
Old Oct 01, 2012, 11:56 AM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
......last night we went to DQ and ended up with some smaller red spoons that might work also and save some weight in the process. I"ll see how well they fit later.
Is this a great thread, or what?
Inverted low UM EDF passes; the search for the lightest plastic spoons, MiG mash; using a credit card for good instead of evil; etc., etc., on and on.....
ps - note that even the regular white spoons come in various thicknesses/weights.
pps - jpt: a strip of clear tape along the bottom of the fuse keeps the foam clean, and can be wiped-off or replaced easily.
Old Oct 01, 2012, 12:01 PM
Joined Apr 2012
Man, you and I think too much alike. I read about that Dairy Queen spoon and thought "What a cool hobby that we're constantly on the prowl for seemingly ordinary items to do extraordinary things with!"
I think I might just have to swing by DQ and buy a blizzard - you know, just to test the spoon and save my family the cost of replacing an aileron servo or an airframe, or both.
Oh, and on that low pass comment, I failed to report that i also *attempted* a low knife edge with my Mig. Big Migtake. I dont' know if a Mig is capable of a Knife edge, but I can tell you that I am not. The intake now requires the air to take a new path to the fan.
Old Oct 01, 2012, 12:02 PM
jpt1205 is offline
Mayday! Mayday!
jpt1205's Avatar
Joined Aug 2010
Cool...thanks for the tip, Pugsam. Do all the earlier versions of the Mig have reinforced hard plastic where the vertical stab meets the horizontal stab? I was still going to reinforce mine, as recommended, but didn't remember seeing the plastic piece in previous posts/pics...
Edit: I re-looked at old pics and the rounded plastic piece is visible...nevermind, thanks!
Old Oct 01, 2012, 12:17 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Working from memory only , I think there's reinforcement on the vertical part only.....not on the horizontal - which could use it!
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19423 Aug 15, 2016 09:37 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
