Old Sep 27, 2012, 09:07 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
Originally Posted by erkq View Post
You don't want to get close. That's not a good metric of 20% reserve. You're much better off tracking how many mAh you're putting back into the battery and adjusting your flight times from there.
I know but I don't have any mini deans to start using my TP charger. So for now I'll just keep it at 4:30 until I get some mini deans and can tell how many MAH I put back in. Then I'll be able to charge these little guys in about 4min.
They just look silly next to each other
kuczy is offline Find More Posts by kuczy
Old Sep 27, 2012, 09:26 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Originally Posted by Waffleman View Post
I wonder if there is something wrong with my mig?
It never hits LVC. I know its time to land whent the motor starts going WAHWAHWAHWAHWAH and the rpms drop. I am prettty sure that its a low voltage Thing, but I have never seen a plane do this before. I am using the stock eflite battery. Shouldn't it hit LVC before it goes WAHWAHWAHWAHWAH?
If it means anything my mig is from one of the first production runs, I had been checking HH every few hours until it was in stock and then I ordered.
"WAHWAHWAHWAHWAH" sounds like LVC to me. It pulses.
erkq is online now Find More Posts by erkq
Old Sep 27, 2012, 09:28 PM
erkq is online now
Joined Dec 2010
You know what you can do... this pic reminds me. You can take a large 3S pack with you to the field and use it to run your 12v charger and fly A LOT if you want. I do this with a 3Ah 3S and my TP 610 charger.
Old Sep 27, 2012, 09:39 PM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
When the motor cycles up and down, that's this particular ESCs way of letting you know it's LVC. Some just cut off cold but will start the motor back up if you put the throttle all the way down then back up again. As long as you don't go to full throttle it will give you enough power to make it home. When my Eflite 200 pooped out like that after the 3 min flight. it took 230 ma back in for a full charge. When I charged the 360s back up after the 3 mins it took 196 ma out of the batt.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Sep 27, 2012, 09:45 PM
LowlyElevated is offline
Find More Posts by LowlyElevated
pǝʇɹǝʌuᴉ sɐʍ I ǝsnɐɔǝq
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Whew. It certainly is low on power. I usually put about 210-220mah back into it.
LowlyElevated is offline Find More Posts by LowlyElevated
Old Sep 28, 2012, 02:32 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Did you make sure that the servo tape hasn't come loose and obstructing the air flow? Any obstruction will severely hamper performance.
Old Sep 28, 2012, 03:29 PM
richos is offline
Find More Posts by richos
richos's Avatar
United Kingdom, England, Wells
Joined Mar 2008
Miniaviation 2s 7.4 450mAh 45C Li-Po
OMG!! OMG!!
From Miniaviation....
(MEGA) 45 punch And a massive (MEGA) 450mAh of flight time Thats massive (DURATION)
I just cant wait to try them out in my Mig 15
Have a sneeky peek at the new Miniaviation (PLUG AND PLAY) 2s 7.4 450mAh 45C Li-Po here.
http://www.miniaviation.com/news.html
richos is offline Find More Posts by richos
Old Sep 28, 2012, 06:27 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
At 450mah, you could use a standard 20C lipo with the same results. This is going to make the Mig pretty nose heavy too... but, you'll be up there for twice as long which I think is what you want.
NitroCharged is offline Find More Posts by NitroCharged
Old Sep 28, 2012, 07:25 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Yeah at some point the weight is too much for the additional power to overcome.
Old Sep 28, 2012, 08:03 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Yeah, I wonder what the 450s weigh. I just weighed an old 430 flightmax and it weighed 30 grams almost double the Eflite at 16 grams. The Rhino 360 weighs 22 grams and the Mig carries it fine. I think the Eflite is running close to its C limit if the motor is drawing 5 amps. I'll put a voltmeter on it tomorrow to see what it's actually drawing.
Gord.
Old Sep 28, 2012, 08:23 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
just got back from the flying field and maiden my Mig-15 got 5 flights in, What a Sweet flyer! Hands down a much better jet then Great Planes F-86 Sabre. Don't get me wrong I love flying my Sabre but the Mig is much more stable then the Sabre. I'm using the Great Planes 250ma batteries I got 5-1/2 minute flights using good throttle management. The funny thing I didnt have to trim the Mig that got me thinking is the 3-axis gyro system compensating for trim needed? It's amazing how twitchy the servos are moving the Mig around in your hand. I hope E-flite makes a micro Sabre next? I thought the Mig-15 was a bit pricey but know I think it worth every cent!
BadLemon is offline Find More Posts by BadLemon
Old Sep 28, 2012, 09:02 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
United States, NC, Mooresville
Joined Aug 2007
i'd like to have an extra half minute....but with more zip !
KCinNC is offline Find More Posts by KCinNC
Old Sep 29, 2012, 10:38 AM
natss is offline
Find More Posts by natss
Registered American Veteran
natss's Avatar
Tulsa, Oklahoma
Joined Aug 2010
What's everybody pulling on the bench? With a freshly charged Hyp 240mah I'm pulling 3.65 amps. Just trying to get a comparison if anybody's done this with same battery on a watt meter.
natss is offline Find More Posts by natss
Old Sep 29, 2012, 11:29 AM
jpt1205 is offline
Find More Posts by jpt1205
Mayday! Mayday!
jpt1205's Avatar
Joined Aug 2010
Flew 4 sorties tonight--what a blast this little plane is! I turned on high rates and wow! What a difference...you really need high rates (at least elevator) on landing (i know the manual states such)--but man, this thing was spot on! I was able to grease 3 or 4 touch-n-goes...so awesome to see her land on the mains and roll out. The aileron roll rate was so much faster on high rates, and doing tighter loops w/out stalling is much simpler too...
What a great little EDF! Now if E-Flite would just come out with a UMX A-10...that would be INCREDIBLE! First of it's kind micro dual EDF w/AS3X!
What a great time to be in this hobby!
jpt1205 is offline Find More Posts by jpt1205
Old Sep 29, 2012, 12:01 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
I think I say that to myself, and to anyone in earshot about three times per day. Just got back from the field and what an amazing array of near-perfect scale, gyro equipped, EDF, warbirds, etc, of sizes from palm-sized to 62 inch wingspan, and each of them available to every-man for not much more than the cost of a premium round of golf.
Telemetry, self-correction, altimeters, GPS, gyros, minicameras, sevoless retracts, superbright LEDs, power-packed battery technology, computerized chargers, cell-phone-like transmitters....
I often say I was born in the wrong era and would have been happier being an adult in the thirties, forties, or fifties, but all of that goes out the window when I think of technology at our fingertips today, and at super cheap prices.
tracknoob is offline Find More Posts by tracknoob
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19361 Jul 13, 2016 07:43 AM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
