Old Sep 21, 2012, 08:00 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by jim350 View Post
Whilst the servo is in it's programming mode you can turn the gears with your fingers to the required position. It will remember this position as the neutral point.
Is this confirmed? This would allow us to change the offset amount on these servos.
-Brian
kalmon is offline Find More Posts by kalmon
Old Sep 21, 2012, 08:08 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
-Brian
That is exactly what I thought!
No need to swap servos, just reprogram them
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Sep 21, 2012, 08:09 AM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
I just did it to mine.
The first time i tried to reverse the servo i slipped before it fully entered programming mode and it changed the neutral point.
Out of experimentation to try and re-centre the servo i discovered whilst in programming mode i could move the servo and it maintained the new neutral point.
jim350 is offline Find More Posts by jim350
Old Sep 21, 2012, 08:11 AM
jim350 is offline
Joined Aug 2011
It has not changed the differential inbuilt in the servo. It still moves one way more than the other.
Old Sep 21, 2012, 08:18 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
OK so this could create an over-driven situation as the amount of travel each way is the same, just the center point is being moved.
I guess a word of caution to all those who do this, make sure the servo doesn't go to the end when on high rates as it will likely jam there.
Still a neat thing to fiddle with, just don't get to extreme in the movements.
-Brian
Old Sep 21, 2012, 08:24 AM
BMFA 190658
Joined Mar 2007
That is a shame...
I thought HH had reprogrammed a servo [presumably in this way] because someone bought a wrong sided servo.
Are you sure that if you moved the centre point it still moved 50/50 from the new point?
Old Sep 21, 2012, 08:26 AM
BMFA 190658
Joined Mar 2007
What I mean is, if you were to change the neutral point to the other end of the travel, would the servo act as a differential servo with more down than up...
Old Sep 21, 2012, 08:48 AM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Wow, nice find!!!! I did reverse quite a few servos, but never stumbled into that.
RealGambler is offline Find More Posts by RealGambler
Old Sep 21, 2012, 09:09 AM
Valkpilot is offline
Find More Posts by Valkpilot
Valkpilot's Avatar
Joined Mar 2012
Battery Charging
Can I charge the MiG's battery off of a 6v lantern battery using the included
alligator clips?
Valkpilot is offline Find More Posts by Valkpilot
Old Sep 21, 2012, 09:21 AM
jpt1205 is offline
Find More Posts by jpt1205
Mayday! Mayday!
jpt1205's Avatar
Joined Aug 2010
Yes most agree this is the best way. The Elevator strips are probably unnecessary as Pugsam said. I used the sizes to mentioned on mine, but I didn't skewer as I did mine before someone thought about that idea. If I did it again I would do the skewer method as it looks cleaner. Make sure that strip piece in the middle is one piece pushed through the vertical stab!
Foam safe CA is my preferred method for attaching it.
I cut CF with a razor saw. Then I use fine sand papaer on the cut edge to smooth and prevent fraying.
-Brian
Thanks Brian!
jpt1205 is offline Find More Posts by jpt1205
Old Sep 21, 2012, 10:25 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
alligator clips?
no, The charger that comes with the mig is designed for 12volts (car battery).
-Brian
Old Sep 21, 2012, 08:10 PM
LowlyElevated is offline
Find More Posts by LowlyElevated
Because I was INVERTED
LowlyElevated's Avatar
United States, FL, DeLand
Joined Sep 2012
Maybe 2 lantern batteries in series, but it would be simpler with a car battery.
LowlyElevated is offline Find More Posts by LowlyElevated
Old Sep 22, 2012, 12:38 AM
Boofhead is online now
Find More Posts by Boofhead
That will simply buff out
Boofhead's Avatar
Australia, NSW, Kareela
Joined Jul 2001
Floating MIG
Found out that you need to be careful and ensure that the battery is properly engaged with the velcro
2nd flight this morning and after a shallow dive pulled up rapidly to go to vertical - a small blue object kept going forward and the MIG simply stopped in mid air. Frantically trying to control the MIG then realising that the battery had come out of the plane and of course no power to any of the controls
Finally floated down - 1 wing needed some glue but not too bad and will check that velcro next time for sure
Boofhead is online now Find More Posts by Boofhead
Old Sep 22, 2012, 04:37 AM
bigbill1966 is offline
Find More Posts by bigbill1966
United Kingdom, Fareham
Joined Sep 2012
mig15 construction
am i being dumb but does anyone know for sure what foam she is built from?
bigbill1966 is offline Find More Posts by bigbill1966
Old Sep 22, 2012, 10:01 AM
mikhail tupulov is offline
Find More Posts by mikhail tupulov
Switzerland
Joined Aug 2012
EPS (unfortunately)
mikhail tupulov is offline Find More Posts by mikhail tupulov
Reply With Quote  (Disabled)
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19352 Jun 16, 2016 01:08 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
