Old Aug 27, 2012, 03:53 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
What about simple old silicone spray lube? It usually is good for electronic circuits to prevent water or moisture issues, and it is slick on eveything. Just wouldn't want to get it on a surface you would want to paint later. Any comments?
Fred
Freddie B is offline Find More Posts by Freddie B
Old Aug 27, 2012, 04:06 PM
NwRcFlight is offline
Find More Posts by NwRcFlight
EDF Junkie
Pacific Northwest
Joined Oct 2007
Fred
Slick isn't what you're looking for. You're looking for something to clean off the black gunk that accumulates on the resistive strip and makes the servo unable reach the desired position.
Yes, a can of deoxit seems expensive but it's a near lifetime supply and works! What more can you ask? The model(s) you save will appreciate it.
NwRcFlight is offline Find More Posts by NwRcFlight
Old Aug 27, 2012, 05:14 PM
Boofhead is offline
Find More Posts by Boofhead
That will simply buff out
Boofhead's Avatar
Australia, NSW, Kareela
Joined Jul 2001
Any ideas?
Repaired my MIG-15 with a new Fuse and top deck after a bad nose in
All looks fine and a quick spin up on the bench all seems well
A couple flights with both the original battery and nano-tech 300mah 2S batteries and it is very low on power (cannot even loop) and after about 60 secs it completely shuts down as if the battery has reach its limit
Will be having a look at it on the weekend but any suggestions on where to start the troublshooting would be appreciated, as it is not flyable in it current condition
Cheers
Boofhead is offline Find More Posts by Boofhead
Old Aug 27, 2012, 05:42 PM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Originally Posted by whichwaysup View Post
Also, I need a little help. My Mig is Migbehaving. I'm getting a very dangerous roll when using sudden up elevator commands. Instead of shooting straight up like she used to, she'll drop the port (left, nose away from me) wing. I generally don't use full or sudden up elevator commands, but crashed the other day because my attempt to pull up was foiled by this roll. I'm thinking my horizontal stablizer is at fault, but I've already stiffened it as shown on this thread. Thoughts??? Perhaps Count's positive mystic thing translated to a negative mystic thing for me!
It might be worth doing a positive control check on the Elevators. Sounds to me that only the Port Elevator is working when there is a high airflow over it.
There are various ways to do this check but I think the easiest way with these tiny models would be to give full up elevator then gently try to push the surface downwards. Be very careful, being too heavy handed could very easily damage something. Just gently try to move it to see if there is any play in the control rods or mechanism.
Might be worth opening it up for a good visual check first...
Tony
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Aug 27, 2012, 05:46 PM
BMFA 190658
Joined Mar 2007
Cheers
Is it possible that the glue used to hold the brick in place is not conducting the heat away properly?
It has been noted that the MiG has a very poor airflow for cooling the brick etc. too much glue could be acting like a blanket and triggering OTP
Tony
Old Aug 27, 2012, 06:23 PM
TurboRacer is offline
Find More Posts by TurboRacer
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
I actually have de-oxit - but I didn't want to open a new Mig. Shouldn't have to! I opted for replacement
But yeah, I do use it, it does work. I got the two pack from RatShack.
TurboRacer is offline Find More Posts by TurboRacer
Old Aug 27, 2012, 06:46 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Cheers
Start with a CLOSE inspection of the fan unit and impeller. Look for misalignment, rubbing etc.
NitroCharged is offline Find More Posts by NitroCharged
Old Aug 27, 2012, 11:45 PM
RCBABBEL is offline
Find More Posts by RCBABBEL
**I'm Battman**
RCBABBEL's Avatar
Twin Falls, Idaho
Joined Jan 2005
BB Hyp (3S) 320mAh
3SBrian has agreed to test my latest batt in his MiG.
Should be interesting at 1oz.
Dimensions:
L x W x H
50x24x11.75mm
rc
RCBABBEL is offline Find More Posts by RCBABBEL
Old Aug 28, 2012, 04:37 AM
BMFA 190658
Joined Mar 2007
With a TP tap
Old Aug 28, 2012, 06:20 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
A Warning About Running the Fan on 3S!
Here's a big heads up guys!
My rear bearing has gone already.!!!
I am just about to upload a 'how to replace it' video, but this bearing failure may have been the result of running it above spec on 3S instead of the intended 2S.
Old Aug 28, 2012, 06:35 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by grovey View Post
What you need is DeoxIT FaderLube F5. FaderLube F5 is designed specifically for the type of mechanism seen in these linear servos.
Yes this is the correct DeoxIT to use.
Dimensions:
L x W x H
50x24x11.75mm
rc
What a porker, and the battery looks heavy too
looking forward to more than 2:20 min 3S flights.
Yikes already? Mine still sound ok, however I have my throttle limited to 75% so it might last a little longer. I'm really looking forward to the video and I might take mine apart and put in some 100k bearings just to be proactive. Don't forget to go wobbly about the bodgy e-flite bearing, crikey! (I need to hear more of that aussie slang)
-Brian
kalmon is offline Find More Posts by kalmon
Old Aug 28, 2012, 08:54 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Tony
Thanks Tony - I'll give that a try. I actually (re) reinforced my horizontal stab thinking that might still be the problem - my CF reinforcements were only .020 so weren't giving much strength. I used a bit of very thin, very strong wire and took her out this a.m.. SOMETHING is definitely funky, because if I pull back hard, she just goes completely soft on me - as if the gyro is trying to correct something. It won't even loop! Full throttle, a good descending start, yank back, and she goes nose up, but then wobbles, and sits dead in the air sliding horizontally while pointed vertically and finally falling. Again, I'm pushing it to make this happen, but when I get into trouble and try to pull out, I can see this starting to happen. I'll check that both elevators are working - I think that might explain it. The Gyro make be picking up that one isn't working and the resulting motion is not intended.
Thanks for the tip -
whichwaysup is offline Find More Posts by whichwaysup
Old Aug 28, 2012, 09:58 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
........SOMETHING is definitely funky, because if I pull back hard, she just goes completely soft on me - as if the gyro is trying to correct something. It won't even loop! Full throttle, a good descending start, yank back, and she goes nose up, but then wobbles, and sits dead in the air sliding horizontally while pointed vertically and finally falling. Again, I'm pushing it to make this happen, but when I get into trouble and try to pull out, I can see this starting to happen......
Basically the same thing happened to me, twice, soon after I got my MiG.
At the time, I was spooked by all the reports of servo issues -- so that's what I blamed it on.
But it hasn't happened again......after I did some serious tailfeather reinforcement. Both the horizontal stabilizer and the elevators.*
My hunch now is that, without reinforcement, those surfaces flex too much under stress, and any little crease can become a fault line where there might not be enough strength in the surface to pull you out of a high-G loop or turn.
___________________
* Horizontal stabilizers are not the same as elevators. Just ask vadimpelau and Groovechampion.
pugsam is offline Find More Posts by pugsam
Old Aug 28, 2012, 10:11 AM
Joined Apr 2012
Thanks PugSam! I havent strengthened those flappy thingys on the flat thingy at the back of the plane, so I'll try that next.
Old Aug 28, 2012, 10:20 AM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
Awesome!
That'll make the thingamabobs much gnarlier!
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19352 Jun 16, 2016 01:08 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
