Old Nov 14, 2012, 12:56 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Originally Posted by khen View Post
I'm swimming in EPP scraps I didn't want to confuse the build with extra EPP in the bag, but it sounds like it would be a good idea.
It actually wouldn't be a bad idea.. you could put a little sharpie mark or something on the scraps that you put in to make sure no one gets confused.
And IflyRCs I am using the wood kit, no carbon except the LG and pushrods.
nightfox7 is offline Find More Posts by nightfox7
Old Nov 14, 2012, 01:08 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
khen, you have colors coming today or soon? Or even white...
Cart's loaded but yellow is not too pleasing.
(uh oh cart has self emptied - not good khen)
ARE you guys preferring 8" over 9" on 2s outdoors?
Really surprised at that. Someone posted 9 felt more floaty?
khen only has 9s in stock too.
So I need to pick a battery size now and build around that size for CG so only 1 cutout is needed?
Thanks for the advice.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Nov 14, 2012, 01:24 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
I'm using a 9x4.7 prop on a 460mah 2s battery.
I'll have a vid up in a bit for you.
Old Nov 14, 2012, 01:33 PM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
IFlyRCs,prop selection depends on the outrunner used and the kv rating. Generally on 2s 1500kv outrunners in the 25-26g like the 2205 run well on 9x5-9x4.7 props. The power hd 1900kv outrunner runs well on both 2s and 3s with 8x4dd props. On 2s in the slicko the 9'' props will work a bit better do to its larger overall size,its a bit larger than more common 32'' size epp foamies so it also has a slightly higher AUW. For lipos a 2s 450-460mah pack provides reasonable flight time at a moderate weight,about 6 minutes plus flying time depending on throttle usage. Smaller packs work well for lighter set ups and more floaty feel but sacrifice some flight time.
Get Real is offline Find More Posts by Get Real
Latest blog entry: Simplecopter T-Copter
Old Nov 14, 2012, 01:48 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Good point get real, i'm using the Aoxing 1500kv motor
Old Nov 14, 2012, 01:51 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Here you go IflyRCs Quick and dirty, but shows something. The plane was unharmed after the tree encounter at the end. It was very breezy.
RCPB Slicko (1 min 35 sec)
Old Nov 14, 2012, 02:05 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
I plan to go ahead and get the power kit from khen.
So I'll get the 9s he has in stock. Good.
NF7, thanks man, SOLD!
Old Nov 14, 2012, 02:18 PM
medic45 is offline
Find More Posts by medic45
United States, KY, Booneville
Joined Jul 2012
Nice Video NF7 I bet you get alot of deers come outta that little spot..If thats your Back yard im Jealous.
medic45 is offline Find More Posts by medic45
Old Nov 14, 2012, 02:23 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
No problem
You'll love it!
Thanks, and yeah we get a few.
To help your jealousy, the Chattahoochee is about ~150 yards through the woods back there.
-Seth
Old Nov 14, 2012, 02:32 PM
medic45 is offline
Joined Jul 2012
Sweet..
Old Nov 14, 2012, 02:45 PM
IFlyRCs is offline
ICrashRCs
Joined Jun 2011
So both of you are running 2s Nano Tech 460's?
Guess I need to hunt some up...
Clarify for me.
I can't easily run other sizes once set up for these?
I assume it makes the slot sloppy and things don't stay in place as well.
What if I want to run 3s some time?
Old Nov 14, 2012, 02:51 PM
maxxnut is offline
Find More Posts by maxxnut
Hoarding balsa is a sickness
smokey point, wash.
Joined Dec 2003
The closer the battery is to the CG, the more flexability you have in choosing batterys. If you are planning on switching between 2 and 3 cell, cut the slot for the thicker / larger battery, and bond a shim of depron or other soft material to the smaller batterys to take up the size of the hole. If you balance with a 2 cell battery just behind the aileron servo, and then install a heavier battery, you will be nose heavy. That can be corrected with a penny or nickle taped to the bottom rear of the rudder..or something like that. A penny is 3.25 grams, a nickle is about 5 grams, but you have the distance from the CG called the "moment-arm" that allows you to do that
maxxnut is offline Find More Posts by maxxnut
Old Nov 14, 2012, 02:57 PM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
Medic45, here are a couple of shots of the ESC and reciever on my son's plane..keep them foward if needed. I cut a slit in the foam and passed the motor wires through, now with the wires soldered to the ESC, just cut the foam and then reglue together.
Old Nov 14, 2012, 03:44 PM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
Yep, down to yellow right now. I will have some whites ready to ship tomorrow. Other colors might be 2-3 days do to paint times.
If you create an account on the site it will save your cart contents and reload them when you login.
I am down to just 9" in the Dura-Thrust props, but I have some 8" gemfan props which work good as well. Dura-Thrust are on their way hopefully soon.
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Latest blog entry: Latest Video's
Old Nov 14, 2012, 04:06 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Should I remount my electronics?
I have both rx (orange, no case) and esc on the same side. Should I remount one on each side. I mount my battery thru the center of fuse.
@Khen, what about some other colors? I'd like a purple one.
3flyguy3 is offline Find More Posts by 3flyguy3
Build Log Mile High R/C Winners Model 49" EPP Yak 55m Build Thread funflyr 3D Foamies 39 Nov 01, 2015 08:58 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Toccata 3D EPP Complete Build Thread Magnum9 3D Flying 59 Mar 04, 2006 01:45 AM
