Old Nov 09, 2012, 09:19 AM
Professional Pixel Flyer....
RightcoastRC's Avatar
USA, VT, Ludlow
Joined Dec 2005
Well there are now 25 virtual Slickos out there being enjoyed, and 12 of each color, all in only 5 hours, I feel good!
I have a server up called Slicko Club, password: wickedfun
Rf version 6.5
RightcoastRC is offline Find More Posts by RightcoastRC
Old Nov 09, 2012, 09:24 AM
medic45's Avatar
United States, KY, Booneville
Joined Jul 2012
Awesome buddy that freaking great!!!
medic45 is offline Find More Posts by medic45
Old Nov 09, 2012, 11:33 AM
USA, VT, Ludlow
Joined Dec 2005
The Slicko is Wicked Fun....
Old Nov 09, 2012, 11:44 AM
medic45's Avatar
Joined Jul 2012
Yes yes yes it is lol
Old Nov 09, 2012, 04:24 PM
USA, VT, Ludlow
Joined Dec 2005
All of you that have the ability to fly the Slicko in Rf, please let me know what kind of frame rates you get while flying, you can add the graphics frame rate readout to the nav guides if its not there already, go to Gadgets>Edit Nav Guides
Old Nov 09, 2012, 05:21 PM
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Using RF 6.5
Frame Rates (frames/second):
Idle ~105
Highest ~48
Lowest ~88
I am flyiing on HIGH rates.
And now a few questions:
It can almost loop within its own length...
1. Does the real Slicko have what appears to be extraordinary elevator authority?
I can flat turn at 1/2 throttle using full rudder and no aileron or elevator correction...
2. Will the real Slicko flat turn at full rudder with no aileron correction?
Rudder authority seems weak compared to elevator authority...
3. Is this correct?
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Nov 09, 2012, 05:34 PM
USA, VT, Ludlow
Joined Dec 2005
Originally Posted by JC Spohr View Post
Using RF 6.5
Idle ~105
Highest ~48
Lowest ~88
3. Is this correct?
JC
Good framerates, average computer?
As far as the flying characteristics, I am not sure myself, but Khen did say it was spot on with his Slickos
Old Nov 09, 2012, 05:42 PM
smokey point, wash.
Joined Dec 2003
Rightcoast, you need to state what your control throws are in degrees ie: 45 degrees on elevator, ect. and mine will almost loop in it's own length with 40 degrees of elevator throw. I do need a little opposite aileron to rudder for flat turns when they get tighter, and knife edge loops are about 10 feet diameter.
maxxnut is offline Find More Posts by maxxnut
Old Nov 09, 2012, 06:51 PM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I have to agree with JC, although I don't have a Slicko to compare against. I tried to create a recording but I must be missing something. I hit record get a notice recording, stop recording, can't find the file. ? Any hints on this.
My frame rate is showing as 360. Dell Alienware. I had to change to physics from expert to intermediate to slow everything down. Still will basically loop around the CG and the rudder seems soft. The roll rate is a blur and never loses altitude without any elevator correction.
Azarr
Azarr is offline Find More Posts by Azarr
Old Nov 09, 2012, 07:03 PM
Multirotors ROCK!
Get Real's Avatar
Illinois
Joined Feb 2006
I dont have a realflight to reference and its been a few years. You should be able to find the folder where it defaults the recorded files to within the program folders somewhere within realflight. I dont remember the extension file used but on windows 7 it shouldnt take long to find if anyone knows the file format used for the recordings with the search function.
Get Real is offline Find More Posts by Get Real
Latest blog entry: Octocopter With DSLR
Old Nov 09, 2012, 07:13 PM
Azarr's Avatar
Joined Jan 2000
Might be a bug in 6.5. I was able to record until I upgraded from 6 to 6.5. The file should appear in the drop down box, but nothing shows up.
Azarr
Old Nov 09, 2012, 07:32 PM
khen's Avatar
Utah USA
Joined Jun 2002
I don't have real flight 6.5, but real flight 5.5 has rudder issue with KE flight especially noticeable on KE loops on the back side of the loop. I correct all my planes by sitting the vertical height of the fuselage to be almost double that of the real plane. Do you 6.5 owners have that issue? It goes into a death slide and unless you apply gobs of throttle it's overly slow to recover. The Slicko can do pretty tight KE Loops. Elevator is pretty close to accurate. The Rudder turns on the RF version are a little flatter than life. LIke maxxnut mentioned it does require some counter ailerons on sharp rudder turns.
I will be going to the LHS tomorrow to grab the 6.0/6.5 upgrade.
My 5.5 records fine, but the .recording format seems proprietary. I will have to purchase FRAPS or something similar to capture video for youtube.
My frame is usually in the 120fps range.
khen is offline Find More Posts by khen
Site Sponsor
Old Nov 09, 2012, 07:39 PM
khen's Avatar
Utah USA
Joined Jun 2002
Oh, and the roll rate on the RF Slicko is faster. I set the travels down to 27 - 30 degrees on the ailerons.
Site Sponsor
Old Nov 09, 2012, 07:54 PM
medic45's Avatar
Joined Jul 2012
Ok y'all done and went and confused me lol
Old Nov 09, 2012, 08:10 PM
Azarr's Avatar
Joined Jan 2000
In RF 6.5 my knife edge loops are large but consistent speed throughout like I'm on low rate. Wing overs take a lot of room, the rudder is very soft. Full elevator and throttle and It's not a loop, the plane just pivots around the CG both inside and outside. Same with snap or Sullivan rolls. The elevator authority seems unrealistic.
Azarr
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 521 Jun 12, 2013 08:06 PM
Build Log Mile High R/C Winners Model 49" EPP Yak 55m Build Thread funflyr 3D Foamies 38 Jul 12, 2012 04:33 PM
Toccata 3D EPP Complete Build Thread Magnum9 3D Flying 59 Mar 04, 2006 01:45 AM
