Old Aug 10, 2012, 05:51 PM
maxxnut is offline
Find More Posts by maxxnut
Hoarding balsa is a sickness
smokey point, wash.
Joined Dec 2003
I just went to the mail box and got more candy...and 4 new batteries, each was shipped at 3.8 volts / cell. Now for some easy charge and gentle flying to break them in and I should be go to go. Thanks.
More progress will be done to the yellow plane now that the kid and I got his pick up back on the road again..stay tuned.
>>>> "YMMV"<<<< from a previous post I think means: " Your Milage May Vary"?? Old guys take longer....
maxxnut is offline Find More Posts by maxxnut
Old Aug 11, 2012, 04:51 AM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Yes on YMMV.
Get Real is offline Find More Posts by Get Real
Latest blog entry: Simplecopter Mini T Copter Fun
Old Aug 11, 2012, 08:57 AM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
Very good, then " IWBCNUAO", sometime.
Old Aug 11, 2012, 10:56 PM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
Charged all 4 batteries today at 250 mah and recorded a done charge at 4.21vts each. Put #1 into the plane and kept it in the air gently for 4 minutes, pulled the battery and the voltage was 3.85 after resting 15 minutes...will do the same for the others 3 or 4 times then will see what they got.
Old Aug 12, 2012, 08:47 AM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
Mmm.. "I Will Be Seeing(CN) You(U)" but what is the "AO"?
Thanks for reviewing the batteries, looking forward to your feedback.
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Latest blog entry: Latest Video's
Old Aug 12, 2012, 09:51 AM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
"A-O" = " A-Round"...
Old Aug 12, 2012, 11:20 AM
stevelmaa is online now
Find More Posts by stevelmaa
Renton, Wa.
Joined Feb 2006
Anyone know when more Slicko kits are due in?
stevelmaa is online now Find More Posts by stevelmaa
Old Aug 12, 2012, 12:38 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
I just broke another prop on a light nose strike. The props don't "pop off" like they do on my Twisted Edge. On the Slicko the prop sits much deeper on the prop saver thus not allowing it to pop off. Is this normal operation that it doesn't come off easily in a nose strike? I saw somewhere of talk of using washers, but I'm not sure if it was in this situation or something else. Any advice on how I can "save" my props?
3flyguy3 is offline Find More Posts by 3flyguy3
Old Aug 12, 2012, 01:08 PM
Get Real is offline
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
The outrunner design and the prop saver bands or orings used are the reason one prop will pop off and the other will stay mounted and transfer energy to the blades and potentially break props. Using orings on most outrunners provides less holding power for the prop.. im not a fan of orings myself because i usually have more issues with flinging props off the hub in flight or them floating off the hub and twisting then striking the nose of the plane and losing power.
Possible solutions:
1. Use less secure mounting.. orings or a single prop saver latex band.
2.If using a outrunner with an extended shaft that protrudes past the prop saver hub you can dremel it off flush with the hub.. take care not to have metal debris enter the outrunner.. best to mark the shaft with a sharpie and remove it completely from the stator and can if cutting.
3. Use durathrust or similar heavy duty props if using slow fly style props like 8x4.3s etc,much more durable than gws but also heavier and a little less performance.
Old Aug 12, 2012, 07:00 PM
n00ber420 is offline
Find More Posts by n00ber420
One more flight...
n00ber420's Avatar
USA, AL, Mobile
Joined Aug 2008
found an old phone today and decided to stick it on the slicko for some birds eye action.
ok so the phone weighs 4.6 oz and i upped the mah to 950 so i used a 2.6 oz battery too so a failed ground launch but still all good. bad quality, the most shocking thing about it is the plane lifted it...lol
RCPB Slicko with Samsung Galaxy S for a flightcam. (3 min 29 sec)
good example of prop ring stretching too hard on takeoff and letting the prop slip.
n00ber420 is offline Find More Posts by n00ber420
Old Aug 12, 2012, 09:17 PM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
God Bless wing spars !!!
Old Aug 12, 2012, 09:49 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Possible solutions:
I'm using one single band currently. I think I may explore option 2. Thanks!
Old Aug 13, 2012, 07:14 AM
Utah USA
Joined Jun 2002
You could also try slightly reaming out the small center hole in you're props so that it's not not a tight fit over the protruding shaft. Not as effective as the dremmel, but it does help a lot.
Site Sponsor
Old Aug 13, 2012, 07:25 AM
Utah USA
Joined Jun 2002
Very cool! That's a great way to repurpose old cell phones.
Site Sponsor
Old Aug 15, 2012, 09:18 PM
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
The prop saver seems to be working fine with my props. Just broke my first prop (prop struck a fence under throttle). Still on my first latex band (though it is showing some wear).
Had a few more crashes but no damage aside from the prop. Gradually getting a little more bold in the backyard and a lot more comfortable with it.
Rayne is offline Find More Posts by Rayne
Build Log Mile High R/C Winners Model 49" EPP Yak 55m Build Thread funflyr 3D Foamies 39 Nov 01, 2015 08:58 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Toccata 3D EPP Complete Build Thread Magnum9 3D Flying 59 Mar 04, 2006 01:45 AM
