Old Jul 15, 2012, 01:37 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Thanks Kevin! I'm flying whenever i have the chance
after i got it out of the tree
RCPB Slicko messing around in yard (5 min 59 sec)
nightfox7 is offline Find More Posts by nightfox7
Old Jul 15, 2012, 03:06 PM
3flyguy3 is offline
Find More Posts by 3flyguy3
3flyguy3's Avatar
United States, IL, Waukegan
Joined Apr 2012
Originally Posted by khen View Post
A 49(.073) is the sweet spot, it's a nice fit. My son has been bending the z and v bends for extra spending money.. He hates the v-bends. He'd be happy to see me go to the connectors.
Khen are you saying the ones on your site are a good way to go, require no drilling? Or are you planning on adding the Dubro # 845 Mini EZ connectors to your site? While I finally got the current set up working, I'd like to have some on hand for this and future builds.
3flyguy3 is offline Find More Posts by 3flyguy3
Old Jul 15, 2012, 11:01 PM
WickedFunRC is offline
Find More Posts by WickedFunRC
WickedFunRC's Avatar
Utah USA
Joined Jun 2002
I'll be going with the ones on the site to keep costs down. They require you drill the servo arm or control horn with a 49 (.073") drill bit or 1.8mm metric. I don't use a drill, I just turn the bit by hand. In a pinch you can carefully bore the hole with an xacto knife but the bit is ideal. I've used them successfully on planes up to 28oz. They install easily with the nut, you only snug the nut so the connector still turns freely and then drop some medium loctite on the nut/threads. They're easy to remove for re-use.
The connectors on the RC Factory plane look to be he same as the ones on the Hacker planes I sell. They have a tiny shaft that fit the arm without drilling. They must come out of the Czech Republic.
WickedFunRC is offline Find More Posts by WickedFunRC
Site Sponsor
Old Jul 16, 2012, 07:30 AM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
EZ connectors will be a nice addition to the kit
Also... how do you want your ailerons adjusted?
Old Jul 16, 2012, 10:41 AM
Utah USA
Joined Jun 2002
One other thing that the v-bends do (in theory) Is provide a bit of shock absortion on impact so that the servo doesn't take the brunt of it. But in the case here I don't think it will be a concern.
A good way to tighten up z-bends is to put a drop of CA at the z-bend/servo arm. After a few seconds you slowely turn the arm back and forth so the z-bends stay free. I thought that was crazy at first, but it really does fill the gaps so there is no slop. I'm certain you can do that with the connectors if you drill it to big as well.
Site Sponsor
Latest blog entry: Latest Video's
Old Jul 16, 2012, 09:26 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
you know it was a good day when you have to come home and repair something
Whats the best way to fix this? I was trying to do an inverted low pass..
Old Jul 16, 2012, 10:27 PM
Utah USA
Joined Jun 2002
Best way to repair the hinge is to hold it in place and run a small bead of goop or e6000 down the seem. Then flaten the bead with your finger a scrap of foam or old razor blade. Hold them together for a couple of minutes and then let it dry. You can also embed/glue some dental floss at the top and bottom of the hinge while you are at it to help stop it from tearing again. You can't kill a slicko, only wound it temporarily.
Site Sponsor
Old Jul 16, 2012, 11:50 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Okay sweet, I have gooo that I have done hinges with before I just didn't know if there was a better way to do it
And I will do the dental floss!
That's what it seems I'm running out if props
Old Jul 17, 2012, 12:44 AM
maxxnut is offline
Find More Posts by maxxnut
Hoarding balsa is a sickness
smokey point, wash.
Joined Dec 2003
Your're running out of props, and I don'dt have any batteries..."cough, cough"
maxxnut is offline Find More Posts by maxxnut
Old Jul 17, 2012, 04:38 AM
Utah USA
Joined Jun 2002
I have bad news on the batteries. The new "35C" 350, 450 and 600mAh batteries have turned out to be weak in my testing. I'd rate them at 20C. I'm extremely bummed givin that they took forever to receive and I took a leap of faith and stockpiled on a bunch of them. The old 440's were a solid 25C battery. I'm now frantically trying to come up with a different brand of cell.
Site Sponsor
Old Jul 17, 2012, 07:11 AM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
I may get flamed for this... But what about the turnigy nano-tech batteries? How do they hold a light to other batteries?
Old Jul 17, 2012, 11:54 AM
Utah USA
Joined Jun 2002
Blasphemy! Just kidding. The only Nanotechs I have tried are the 160mAh 1S cells and they were decent. I have some in the cart as a stop gap until I can find some better 35C cells. I here they are solid.
Site Sponsor
Old Jul 17, 2012, 12:44 PM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
I have a couple of 4S 850 Nano Techs I've tested them on CBA and they are really 700mha usable. In flight they do fine, durability so far so good they have maybe 30 cycles on them I just finished a 4S Sbach so they are about to go back in service. I think they are OK for the money. Just as a reference even top dollar batteries rarely are capable of what they are labeled. But usually considerably more accurate than the less expensive high power packs.
That's my take on Nano's, really stopped by to check out this plane I think my wallet is starting to defy gravity... as it seems to be slipping out of my pocket.
At 20C the 450 is good for 9A. Intuition would lead me to think that should supply good performance on an airframe this weight.
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old Jul 21, 2012, 01:43 PM
maxxnut is offline
smokey point, wash.
Joined Dec 2003
Got a little more build time in with my son on his yellow bird (pried him away from G.F.). Focused on installing the aileron servo and linkage while the upper body was still off, gives more room to work. Then glued on the upper body and carefully set and checked it for alighment. Can't wait for some combat...
WATCH YER SIX KID !!!
Old Jul 22, 2012, 07:05 PM
3flyguy3 is offline
3flyguy3's Avatar
Joined Apr 2012
Where can I get replacement screws that are found on the prop saver (motor) for the Slicko?
Build Log Mile High R/C Winners Model 49" EPP Yak 55m Build Thread funflyr 3D Foamies 39 Nov 01, 2015 08:58 AM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Toccata 3D EPP Complete Build Thread Magnum9 3D Flying 59 Mar 04, 2006 01:45 AM
