Old Jun 29, 2012, 11:39 AM
Tom Hunt is offline
Find More Posts by Tom Hunt
got any foam to bash?
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
Mini-HowTo
FMS 1400mm BF-109F Bash and repaint
Hi Guys
Since I guess I have already done a bit on this model, I should start sharing.
I bought the "kit" from the fruit company some time ago when it was offering free shipping.
Things I plan to do:
Make a new scale tail assy: The model is way oversize in the vert/rudder and the horizontal is a bit oversize (and way too thick!)
The oil "chin radiator" is too deep. It is approaching the size of the "G" series.
Repaint
maybe some other small things we'll see.
Lets get started:
Tom Hunt is offline Find More Posts by Tom Hunt
Old Jun 29, 2012, 12:14 PM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
new tails
I started by lopping off the old vertical tail tangent to the top of the fuselage at the LE of the vertical. I then shaped out a new scale vertical stab.
I shaped out of some rather high density foam (like "spider foam" but still a little denser) a new set of horizontal tails and inserted two 6" long 1/4" carbon tubes into the foam to attach them to the new vertical.
The elevators (and soon the rudder) was first cut out from 1/8" balsa and then I glued DOW "blue-foam" to each side and shaped with a corase sanding board.
Later these will be joined with a 3/32" wire joiner to only require one pushrod to the elevator.
Old Jun 29, 2012, 12:17 PM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
chin scoop mod
The chin scoop is a little on the "deep side" for an "f" model, so I cut it off, and buried it a littel deeper (about 3mm) into the fuselage
Old Jun 29, 2012, 12:24 PM
Prowler901 is online now
Find More Posts by Prowler901
Prowler901's Avatar
USA, NY, Amsterdam
Joined Jun 2007
Beautiful work as usual Tom. I look forward to your progress on this one. she'll be a beauty for sure.
Todd
Prowler901 is online now Find More Posts by Prowler901
Old Jun 29, 2012, 07:21 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Subscribed
GiusedtoBe is offline Find More Posts by GiusedtoBe
Old Jun 30, 2012, 03:06 AM
bullworm is offline
Find More Posts by bullworm
United States, NJ
Joined Apr 2012
nice work
bullworm is offline Find More Posts by bullworm
Old Jun 30, 2012, 10:28 AM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
paint stripped
I stripped the paint (most of it anyway) with acetone. The greeen and the yellow came off easy. The gray is just not effected! must be a different paint.
I "tacked" it together for a couple of shots.
additionally I will be shortening the aileron (inbd) and lengthening the flap (outbd) to make them more scale size. The aileron hinge was broken in transit, so I just lopped them both off.
Old Jun 30, 2012, 11:23 AM
Randbo39 is offline
Find More Posts by Randbo39
Randbo39's Avatar
United States, AR
Joined Mar 2009
I used lacquer thinner on mine. It took the grey off as well.
Randbo39 is offline Find More Posts by Randbo39
Old Jun 30, 2012, 11:30 AM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
motor mounted
Although I may change my mind, it was just too convenient to mount an AXI-4120-20 (465 Kv) (roughly equivalent to a 5055 though they do not make a kv that low yet). The axi prop adapter comes already threaded for the 3mm spinner retention screw. An EMP, Aeolian or Turnigy woulnd need to be tapped in my lathe.
I made a .5" thick X mount extension and glued and screwed it to the existing firewall, though I did have to add a piece to the top side of the firewall for support.
I first glued the cowl on without the right thrust (I don't believe in it) and then routed the hole in the front big enough to pass the motor witht he x-mount installed.
I also (AND I STRONGLY reccommend everyone do this regards of motor chosen or cell count) threw away the crap chinese screws that retain the prop to the backplate and tapped the backplate for 4-40 (3mm would be good for the rest of the world). I then installed 1" long 4-40 screws AND washers.
Old Jun 30, 2012, 12:51 PM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
I might have some around.. I'll try it.
Old Jun 30, 2012, 02:28 PM
MPS86 is online now
Find More Posts by MPS86
MPS86's Avatar
United States, NY, Fairport
Joined Jan 2011
Tom you might want to try lacquer thinner on a scrap piece first. Acetone evaporates much quicker than lacquer so it more than likely will not eat the foam. I know foam in packaging found boxes will dissolve with lacquer not sure about EPO foam though. Mineral Spirits or Naptha might also work but a little pricey just to get paint off.
Matt
MPS86 is online now Find More Posts by MPS86
Old Jun 30, 2012, 03:41 PM
Randbo39 is offline
Randbo39's Avatar
United States, AR
Joined Mar 2009
Yes, definitely test first. I don't want to be responsible for any disasters but I've used it on two FMS planes and had no problems. The problem I had was the fumes attacked my plastic lens glasses so be aware and have very good ventilation if you do it. And of course protect that nice tail mod. I don't think Pink or blue insulation foam will stand up to it.
Old Jun 30, 2012, 04:07 PM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
No worries mate. been a modeler (RC) for nearly 40 years... I always test! more than once!
I had a can of "Perfect" paint thinners, it did not take the gray off, nor did it harm the foam.
Old Aug 07, 2012, 02:00 AM
Randbo39 is offline
Randbo39's Avatar
United States, AR
Joined Mar 2009
Been working on it lately?
Old Aug 07, 2012, 06:46 AM
Tom Hunt is offline
Tom Hunt's Avatar
Lake Grove,LI, NY
Joined Aug 2000
no, sorry,
Wife is finally getting her new kitchen after 27 years in the same house. I'm doing everything except the electrical and countertop. I should get back to it soon. I brought the Mk12 Spit to work so I could at least get something done during lunch in my lab.
Tom
Sold FMS BF-109 with retracts/ receiver ready demire Aircraft - Electric - Airplanes (FS/W) 6 Jun 27, 2012 06:06 AM
Discussion Fms bf-109f ArticWolf Electric Warbirds 0 Feb 01, 2012 10:19 PM
Build Log Ugly Duckling to Beautiful beast BASH FMS/Airfield BF-109E Tom Hunt Electric Warbirds 153 Nov 20, 2011 02:25 PM
Yippee! Warbirdkits.com Bf-109F-2 St. Martin Scale Kit/Scratch Built 346 Apr 15, 2005 04:25 PM
FS:DJ Aerotech Roadkill Messerschmitt BF-109F Tim Wolff Aircraft - Electric - Airplanes (FS/W) 4 Aug 27, 2003 11:09 PM
