Old Jul 16, 2012, 02:20 PM
sps3172 is offline
Find More Posts by sps3172
United States, MO, St Louis
Joined Oct 2006
I LOVE the aileron drive setup!!
Have you ever used that control system (with bigger servos) on larger models?
sps3172 is offline Find More Posts by sps3172
Old Jul 16, 2012, 11:36 PM
dylan roberts is offline
Find More Posts by dylan roberts
why wont it fly
south africa
Joined Jan 2006
someone else here on RCG has done it on a normal foamy (think it might have been Donatas?)
i use a Rotary Drive System on our larger models, not sure if the servo will like all the hinge load as well as controll loads
dylan roberts is offline Find More Posts by dylan roberts
Old Jul 18, 2012, 05:31 PM
3Deranged is offline
Find More Posts by 3Deranged
Aerodynamically challenged
3Deranged's Avatar
3D World, Florida
Joined May 2005
Excellent work-looking forward to some vids
3Deranged is offline Find More Posts by 3Deranged
Old Sep 12, 2012, 01:33 AM
JeWorms is offline
Find More Posts by JeWorms
Joined May 2012
The idea of aileron setup is good. but ..I have tried once with this before it's not good in my case(foamie with cf rod).
I found that if the vibration caused by driving the servo is to great the two servos will end up causing non stop resonance and the whole plane would just shake until I did some adjustment again. One of my servos (using plastic gear) was broken down after several test fly.
I guess a metal gear will last longer.
JeWorms is offline Find More Posts by JeWorms
Old Oct 03, 2012, 11:42 AM
Devin McGRath is offline
Find More Posts by Devin McGRath
Team Futaba
Devin McGRath's Avatar
Rochester New York
looking good Dylan nice VW also !
Devin McGRath is offline Find More Posts by Devin McGRath
Few items take one or take all EDFPILOT Non R/C Items (FS/W) 7 May 25, 2012 10:50 PM
Idea Balsa airframe F3P nadine Indoor Pattern/F3P 24 Apr 15, 2012 10:43 AM
Discussion TWO Wings..Two Airfoils..What do you think? guyg Aerial Photography 1 Jun 29, 2009 12:55 AM
Idea Bumblebees - Investigation of Geodetic Structure for 34" and 60" Balsa DLG's Geode Hand Launch 158 Jun 27, 2009 11:33 PM
