Any tricks to get my computer to recognize my JR XP6102
I got this cable
http://www.ebay.com/itm/USB-Simulato...item4166a79294 to use with my JR XP6102 on my computer with windows 7 32bit. When I plug it in the transmitter powers up but the computer does not recognize it. Are there any tricks to get my computer to recognize this controller or is the cable a rite off Thanks for any help |
Click Start, type in devmgmt.msc press enter. This will open Device Manager. It may be under HID (Human Interface Devices) or some other heading, just look for objects that have an exclamation next to them, that indicates a device that wasn't properly installed. You can then right click it and either install the driver or enable the device.
Something else you can try, with the dongle plugged into the computer without the transmitter hooked up, shut down the computer, then turn it back on. With the device plugged into the computer Windows should see the new device on restart. It's possible at some point you set Windows to not auto detect connected hardware. If above fails, go into Control Panel | Devices and Printers and try Add New Device in the upper left. |
Think it might be time to buy one of these http://www.nitroplanes.com/newrcte6chfl.html Thanks for the help |
Here's a silly question, have you tried the usb dongle on another computer?
You could also try removing the device from Device Manager then letting it try to reinstall. Though not as good as a dongle you could try Smartpropolus and PPJoy. It creates a PPM signal via a male to male 3.5 audio connection from your mic or line in on your sound card to Windows. Windows then sees it as a joystick. This is how I use my transmitter in Clearview. This doesn't work for USB audio and they clearly say it in the support docs. Also it seems pretty glitchy with Audigy cards. http://www.smartpropoplus.com/dnn/ |
| Thread Tools | |
| For Sale Jr xp6102 tx and rx along with full fpv setup $500 | Omac1984 | FPV/RPV - Equipment and Vehicles (FS/W) | 3 | Jun 16, 2012 06:54 PM |
| Help! Can't get Hobbyking 6ch tx to work with computer | doh2doh | Radios | 2 | Jun 14, 2012 11:07 AM |
| Help! My eloggerV3 couldn't be recognized via my computer | herbalist | Eagle Tree Systems | 4 | Oct 07, 2008 10:28 AM |
| For Sale JR XP6102 6ch computer radio with servos , rx and misc | knierien_15g | Aircraft - Electric - Helis (FS/W) | 1 | Jul 20, 2008 08:33 PM |
| Sold FS JR XP6102 6CH Computer Radio 2 Receivers and 4 Mini Servos | brianu.16 | Aircraft - General - Radio Equipment (FS/W) | 3 | Aug 19, 2005 03:58 PM |
