Old Aug 03, 2012, 12:38 PM
Bipesexual is offline
Find More Posts by Bipesexual
United States, MN, Elk River
Joined Oct 2011
I was wondering if anyone had done one of these. I was gonna go gas because I already have a DA 50, but I am reconsidering after seeing your post. I was also thinking of converting my 25% pitts to electric.If you are willing to p.m. me , I would really like pointers on my ultimate and to get more info. Thanks
Bipesexual is offline Find More Posts by Bipesexual
Old Sep 23, 2012, 10:12 AM
datazman is offline
Find More Posts by datazman
Just Plane Crazy
datazman's Avatar
United States, NY, McGraw
Joined Apr 2004
Ny-RC-Flyboy76 Flies at NEAT
Ny-RC-Flyboy76 flying at this year's NEAT Fair.
http://www.rcgroups.com/forums/showp...4&postcount=39
Paul
datazman is offline Find More Posts by datazman
Old Mar 22, 2013, 04:56 PM
spadbat is offline
Find More Posts by spadbat
United States, MI, South Haven
Joined Jun 2005
I was so glad to see this conversion. I have an Ultimate the currently has a DA50 in it that I want to convert as it needs more power and this looks like just the ticket.
Did you end up doing something different with your battery tray? I figured they would need to go either in through the bottom of the firewall or up thru that hatch on the bottom.
Also, what 3-Blade did you end up using and how many amps are you pulling at wot?
Thanks, Marty
spadbat is offline Find More Posts by spadbat
Old Apr 01, 2013, 09:37 AM
Ny-RC-Flyboy76 is offline
Find More Posts by Ny-RC-Flyboy76
Ny-RC-Flyboy76's Avatar
United States, NY, Cortland
Joined Mar 2009
The batteries went in through the underside hatch ! The propeller was a 24x12 3 blade wide prop the thin spins too many rpm and shuts off timing ! And wt wot she was about 120 it was a beast !!
Ny-RC-Flyboy76 is offline Find More Posts by Ny-RC-Flyboy76
Old Apr 02, 2013, 09:37 PM
spadbat is offline
Joined Jun 2005
I received my 24-12 3-blade today. It is quite the prop. What is the secret to dealing with the short prop shaft?
With my spinner back plate on, I only have about 1/2 the nut engaged.
I was originally going to try a Vess 25B that I had but it was so thick there was no shaft left to put the nut on.
Old Apr 04, 2013, 11:50 AM
Joined Mar 2009
I had no problems getting mine to fit what spinner are u using ? My propellers were all gas props and the 3 blade was carbon !
Old Apr 04, 2013, 09:38 PM
spadbat is offline
Joined Jun 2005
I have a Biela 24-12 3-blade Carbon Prop and Tru-Turn Ultimate Spinner.
As you can see, there isn't much shaft sticking out of the prop.
Any ideas?
Old Apr 07, 2013, 01:37 PM
Joined Mar 2009
well that perplexes me I used a pete model spinner I dont think it is that much thinner !! mine tightened up to the washer and even with the top of the nut !
that is the rimfire 65 right ?
Old Apr 07, 2013, 02:07 PM
spadbat is offline
Joined Jun 2005
Yep, RimFire 65. Here it is with the Vess 26B on it. Same thing as both props are about the same thickness at the hub.
I'm thinking I will need to make or have made, a special nut that has an extended 13mm end on it to go up inside the prop. I would then have to ream the front part of the prop out to fit over the 13mm part of the nut. The prop washer that came with the motor has a 13mm center hole. The nut would need to go up into the prop about 3/8" or so.
I measured from the face of the drive plate to the end of the shaft is just under 15/8" and the props are 1-1/8" thick. So even with no spinner back plate there is only 1/2" of prop shaft sticking out. The drive plate may move back a bit as things get tightened down, but I don't see it moving much.
Why would they say NOT to run the thin "E" props and then put this short shaft on? It doesn't make any sense.
Old Apr 08, 2013, 10:55 PM
Joined Mar 2009
Wow that perplexes me like I said mine fit fine and so did Dan landis's at the neat fair he used my 26x 12 on the fw190 ! Is your shaft sticking out the back some ?? It might have been tightened wrong ! I no longer have my ultimate or I would take a pic but it fit my belia just fine !
Old Jul 23, 2013, 05:54 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Nice build and great look`er.. whats your thoughts on the RF65 so far ? How many Watts are you pulling with the 26x12 ? I have one on my Sbach 89` but have not flown it yet as my field is WAY to small..
OzparkPilot is offline Find More Posts by OzparkPilot
Old Jul 24, 2013, 01:05 PM
Joined Oct 2011
My props all fit however I have a Biela 18x10 and that is a fat pig of center hub. They are really thick. I have that on a different plane but I dont think it would fit. I am running a 24x10 on the rimfire and am not all that impressed compared to the Turnigy CA-80 I am running on my pitts with a 24x10. The CA-80 is pretty violent.
Old Jul 24, 2013, 09:05 PM
Watts up ?
Joined Nov 2006
any performance numbers ? Im keen to get mine in the air soon but have to wait till I move my planes up to my country property as there is no where to fly them in Sydney anymore !
Old Jul 25, 2013, 12:50 PM
Joined Oct 2011
I just downloaded the Castle log and it explains why my 87inch yak performs boringly. Its only pulling 71.5 amps at 3157 watts on a 24x10 prop. Thats on 12s. I think it could handle a much larger prop but you would then have a gyroscopic problem from the large prop torque. Thats if a larger prop would clear the ground. Maybe the 3 blade is the only option.
Old Jul 26, 2013, 02:08 AM
Watts up ?
Joined Nov 2006
Thats pitiful isn't it ! Testing on the RF65 with a 26x12 shows me over 6000 watts. Do you have the clearance for that ?
Sold Nitroplanes Ultimate 50cc Biplane - 71" helifree Aircraft - Fuel - Airplanes (FS/W) 1 Jul 09, 2012 12:25 PM
Sold Aeroworks 50cc Ultimate Rx Ready, DLE 55 gllucero Aircraft - Fuel - Airplanes (FS/W) 4 May 15, 2012 09:46 PM
Sold 27% Ultimate ARF (50cc) LPU $250 scones007 Aircraft - Fuel - Airplanes (FS/W) 9 May 06, 2012 12:13 AM
For Sale Aeroworks 50cc Ultimate 20 - 300 koppterX Aircraft - Fuel - Airplanes (FS/W) 0 May 05, 2012 10:48 PM
Sold Ultimate 50CC Giant Scale RC Bi-Plane ARF Go4it Aircraft - Fuel - Airplanes (FS/W) 1 Apr 28, 2012 10:36 PM
