Old Jun 28, 2012, 08:02 PM
Tyler103 is offline
Find More Posts by Tyler103
Joined Jun 2012
Help!
LiPo battery taking too long to charge
I have the stock battery for the E-sky Lama V4 and was charging it with the stock charger and it took about 5 hours to charge (the stock battery is rated for 800mAh, 10C discharge rate, 7.4V) I have not used the battery since and have it in a LiPo Safe.
Any help would be appreciated.
Tyler103 is offline Find More Posts by Tyler103
Old Jun 28, 2012, 09:19 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Is a stock charger one of those that just has a light?
Get a real charger so you can set the charge rate and you can see what is happening.
What is the voltage of the pack?
Are the 2 cells the same voltage?
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jun 29, 2012, 02:43 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
From what Google can turn up it's a little ac/dc brick charger that you plug the balance connector into. Probably a pretty low charge rate, I could see it taking 2-3 hrs but I can't find the exact charge rate. However if it took that long it probably was having trouble balancing it. I would get a voltage meter that you can plug into the balance port and check the voltage of the individual cells. Something like this:
http://www.allerc.com/hyperion-eos-s...on-p-5701.html
Edit: Sounds like should be about an hour to charge. So either the battery is going bad or you over discharged it and it had a lot of trouble recharging it, in which case it's going bad as well.
grimbeaver is offline Find More Posts by grimbeaver
Old Jun 29, 2012, 05:43 PM
Tyler103 is offline
Joined Jun 2012
Not balanced
I used a voltmeter to check if the cells were balanced and found that one of the cells was only 4 volts while the other one was 7.4 volts. The cell that had the 4 volt reading was slowly discharging on the small amount of current the voltmeter used to measure it. What should I do with the battery
Old Jun 29, 2012, 07:09 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
You have measured the battery incorrectly. You measured the first cell OK but then you measured the pack voltage.
However if you got the correct voltage for one cell (4V) then the other cell is 3.4V. That difference is too great. I suspect your charger realized this and severely reduced the charge rate.
I would discharge the pack to zero volts. Use a power resistor or an automobile tail light for that. Then remove the mail connector and solder or twist the leads together. The pack is then OK to trash.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old Jun 30, 2012, 04:50 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Those non-balance chargers are extremely dangerous and can cause fires. You should get a good balance charger before you burn the house down!
RC Man is online now Find More Posts by RC Man
Old Jun 30, 2012, 08:02 AM
traxx de maxx is offline
Find More Posts by traxx de maxx
traxx de maxx's Avatar
uk
Joined Nov 2010
the charger has an output of 750mA or 800mA and charges through the balance wires. For it to take 5 hours to charge there is something wrong, as it has a 2hour cut off timer. Thats the part number ek2-0851.
1000mA for the newer type ek2-0852 Don't know if it has timer cut off.
traxx de maxx is offline Find More Posts by traxx de maxx
Old Jun 30, 2012, 08:12 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Do yourself a favour and get a better charger .... I had similar with my RTF supplied chargers and gave up.... bought an Imax B6 of Ebay .... despite prophets of doom on forums - it works very well and even got those packs back working that the RTF charger had failed on ...
There's no need to trash a pack until all avenues are exhausted ............
Nigel
solentlife is offline Find More Posts by solentlife
Old Jun 30, 2012, 10:18 AM
Tyler103 is offline
Joined Jun 2012
It IS a balance charger...
The battery charger I have is a balance charger. I think the problem is the one of the battery leads is shorted to the other one. Thanks for the help anyway
Old Jun 30, 2012, 10:33 AM
Tyler103 is offline
Joined Jun 2012
I think that the battery is trash and the charger was not able to charge it correctly because the battery has one of the balance plug leads shorted together and only works properly through the JST port and when the charger tried to discharge one cell it also discharged the other one making the charging take much longer than usual and potentially damaging the battery. I have a upgrade battery that is working much better than the stock battery so I will probably just discharge the battery to 0 volts and throw it away because I can get new one for only $4
Last edited by Tyler103; Jun 30, 2012 at 10:36 AM. Reason: Accidentally hit the enter button
Old Jun 30, 2012, 10:44 AM
RC Helicopter Pilot
Joined Mar 2010
Good decision with the battery, now make the same one about the charger.
Save the rest of your LiPo, get a real charger.
Discussion How long is too long to keep lipos fully charged? electricrc68 Batteries and Chargers 4 Jun 19, 2012 04:15 PM
Discussion How long 2s lipo battery charging takes? lcarrasc Batteries and Chargers 4 Oct 23, 2008 07:05 PM
Discussion Takes too long to charge skate5290 Batteries and Chargers 4 Jun 05, 2008 03:57 PM
First time LiPO charging taking too long on Schulz drabunich Batteries and Chargers 4 Mar 27, 2004 05:07 PM
8 cell 800Mah battery charging takes too long? try2fly Power Systems 12 Feb 04, 2002 06:40 PM
