Old Jul 02, 2012, 01:23 AM
the pope is offline
Find More Posts by the pope
Australia, SA, Adelaide
Joined Sep 2007
Originally Posted by Gary Cee View Post
BTW Cees
Earlwb is one of the finest people that makes contributions here . The badgering you put him through here was mindless and un-called for .
People who wear wooden shoes should avoid flaming .
and dancing, running and playing football . Cheers the pope
the pope is offline Find More Posts by the pope
Old Jul 02, 2012, 02:47 AM
turk1 is offline
Find More Posts by turk1
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
Gents I dont need any academic knowledge to adjust advance/timing on a model plane gas engine.Simply run it to WOT,begin to play hall sensor position and a friend holds a tach for me.Max. tach. shows sensor should stay there.Then tighten the screws and fly.If you consider on an unloaded prop case,then one can give a very little more advance, simply.
turk1 is offline Find More Posts by turk1
Old Jul 02, 2012, 03:30 AM
Taurus Flyer is offline
Find More Posts by Taurus Flyer
The Netherlands, OV, Almelo
Joined Nov 2010
Last step, I knock on the shoulder of my friend, he opens his eyes and I can read the ignition advance curve in the pupil of one of these.
But, I have to admit you need a special friend for that!
WOW
turk 1, I did read your story before, you don't know where I am talking about!
Have fun,
Cees
Taurus Flyer is offline Find More Posts by Taurus Flyer
Reply With Quote  (Disabled)
Old Jul 02, 2012, 08:15 AM
Gary Cee is offline
Find More Posts by Gary Cee
Nitromethane and Castor Oil
Gary Cee's Avatar
Joined Apr 2010
Right on.
With these engines the initial , static timing is set and the running timing is easily set empirically , under actual running conditions . In the real world , very few find the need to actually measure it ..The scope can measure relative timing , trigger pulse levels and widths , firing voltages , the offsets or lags between primary trigger pulses and the secondary firing , display rise times dwells etc . Without a TDC or crank shaft rotational angle reference however the scope will not give you the actual firing point in relationship to crank angle.
In the real world the oscilloscope is very rarely used or needed by hobbyists as a tool to set timing on our engines . Repair shops that service small weed whips , leaf blowers chainsaws etc are virtually devoid of oscilloscopes as there is little application in that field.
Sure , there are those of us that understand the application and may choose to experiment/study the systems , at times using a scope . (Not really an advanced concept, we learned the principle in high school).
For years and years Turk , motorized modelers have employed the method you describe with perfect success . Thank you
Gary Cee is offline Find More Posts by Gary Cee
Old Jul 02, 2012, 09:04 AM
Joined Nov 2010
Gents,
I did take a look and find an example of a system with predefined ignition advance curves.
Did we see this already somewhere in the model gasser world?
Have attention. because this will be the next step and if so we have to analyse the systems, especially when there can be a lack of quality or buying second hand!.
TF
Old Jul 02, 2012, 09:09 AM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
Recoil
For those living in Australia or Europe and not beeing familiar with the system
here is what I use : Recoil made in Australia and similar to the Helicoil brand.
As Gary already explained both systems do have a tap that is used to make the glowplug hole ready to take the wire (actually this looks like a spring) On the box is indicated the correct drill to be used before you put the tap to work.
In this case size 6,5mm. One side of the spring/wire does have a lateral lip into which one does fit the special tool so one can turn-in the spring. After that you simply push out that lip, there is also a rod to do so included in the kit but not shown here. One problem does occur with OS engines that do have a size reduction at the glowplug hole bottom but experience has shown this not to be a problem. I have repaired dozens of engines with stripped out plug holes. Really worth it's money. I seem to remember that it was Clarence Lee who pointed the Helicoil system out to me. I used to correspond alot with him in the past. He's an engine-guru to me and has taught me quite a few tricks.
Reginald is offline Find More Posts by Reginald
Old Jul 02, 2012, 09:26 AM
Reginald is offline
Reginald's Avatar
Belgium
Joined Aug 2004
Right on.
Gary, are you familiar with this little device ? I bought it recently from some Hong Kong firm, have'nt tried it yet because I had not need for it yet. It has a led and sound warning. Still have a large protractor somewhere in my workshop that I used on the V-twin Jap of my (ex)Morgan 3-wheeler.
Old Jul 02, 2012, 09:37 AM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
WHAT !? HOW dare you !? you can only do it properly with an oscilleraiouscope,or what ever it is !!
My race cars,with automatic transmissions get Power braked ,WOT,and advanced 'till it clatters.....back off aboot 2 degrees,and WIN! another race...
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Jul 02, 2012, 09:42 AM
turk1 is offline
turk1's Avatar
Istanbul, Turkey
Joined Aug 2004
WOW
Have fun,
Cees
Hi humoresque modeller.Whatever you may do,I dont need on my RCEXL unit except my style or wheel type adjustment. We need adjustment sure but no need any curve knowledge since we cant change anything inside.Good luck for your experiments.
Old Jul 02, 2012, 10:03 AM
epoxyearl's Avatar
Joined Oct 2011
It's beginning to make sense to me now.....I wasn't aware you needed a "special" friend. Is that an Ostrich ?and isn't his eye just the most outrageous thing you've EVER seen?
Old Jul 02, 2012, 10:07 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I shrink fit magnet rings onto the hub or loctite them. The sensor ring is mounted with set screws. This requires the proper equipment, but the result is very nice.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Jul 02, 2012, 10:10 AM
GeetarJoe is offline
Find More Posts by GeetarJoe
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
Greg
greg, thats a very elegant solution that answers a question i PM'd you about regarding a saito 91 gas conversion. that would be the way to go for sure.
GeetarJoe is offline Find More Posts by GeetarJoe
Old Jul 02, 2012, 10:24 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I machine the OD of the nose of the crankcase to achieve a good fit to the sensor ring. This isn't practical on the Saito, nor required with those two cam cover screws handy. Also on the Saito, the slip over magnet ring can't cover the groove in the drive hub, or it won't be possible to grip with a puller to remove the hub.
Greg
Old Jul 02, 2012, 11:15 AM
I TOBOR is offline
Find More Posts by I TOBOR
I TOBOR's Avatar
Joined Feb 2007
Greg, it sounds as if you like my simple fix. The sensor is a hard push and twist into the bracket, the drop of red LocTite is for, well, what should we call it?
I TOBOR is offline Find More Posts by I TOBOR
Old Jul 02, 2012, 12:18 PM
Joined Nov 2010
No epoxyearl, not an Ostrich, cannot be used for that, that friend has the wrong policy to categorize problems. We don't need exuces when something happens unexpected, we need a critical friend for that, also not a trivialiser!
Give it a try, who is this friend?
"Outrageous thing" you said!
Forget your criticism for one short moment and try to make some fun with us, it's a hobby you know!
I think you are "curious thing"!!!!
Now????
Cees
Discussion OFFICIAL KDS 450s /sv THREAD / HELP - DISCUSSION - GENERAL - #for all kds needs d1cky_kds Electric Heli Talk 20 Mar 27, 2014 08:28 AM
Build Log J-Power A-10 build, mods, general discussion thread gunracer Foamy EDFs 199 Jul 29, 2012 12:49 PM
Discussion Aero Titan Discussion Thread PinkYakRC 3D Foamies 4 Apr 13, 2012 10:14 PM
Discussion OPEN discussion thread DLGjunkyard Hand Launch 62 Mar 18, 2012 11:09 PM
Discussion "Attention LSF members" - discussion thread Miami Mike Thermal 16 Mar 14, 2012 08:24 PM
