Old Nov 12, 2012, 04:59 PM
thsoft is offline
Find More Posts by thsoft
Joined Aug 2008
Hi guys do not know where the connector is plugged rpm out?
Thanks, Tom
thsoft is offline Find More Posts by thsoft
Old Nov 13, 2012, 02:38 AM
bogbeagle is online now
Find More Posts by bogbeagle
Joined Mar 2007
What would be the ignition coil in that circuit?
bogbeagle is online now Find More Posts by bogbeagle
Old Nov 13, 2012, 09:03 AM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
The RPM connector is paralleled to the hall sensor.
The ignition coil is likely a custom component. There are few to no suitable off the shelf coils.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Nov 13, 2012, 01:22 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
It is the labeled component at the right end of the drawing next to the spark plug. The coil is the largest part inside the module. But in this case it is pretty small though. The higher the driving voltage you can use to drive the coil with means you can make the ignition coil ever smaller and smaller. It has its roots in how the Coil on Plug (COP) ignition systems work in the modern automobile engine. They literally put a small coil right on top of each spark plug and use a microprocessor to control each one, thus eliminating a distributor and providing for custom tuning and timing on a cylinder to cylinder basis.
Yeah they usually parallel the signal wires from the timing hall effect sensor. But some modules could run a separate line off the microprocessor output pin driving the high voltage circuit too.
earlwb is offline Find More Posts by earlwb
Discussion OFFICIAL KDS 450s /sv THREAD / HELP - DISCUSSION - GENERAL - #for all kds needs d1cky_kds Electric Heli Talk 20 Mar 27, 2014 08:28 AM
Build Log J-Power A-10 build, mods, general discussion thread gunracer Foamy EDFs 199 Jul 29, 2012 12:49 PM
Discussion Aero Titan Discussion Thread PinkYakRC 3D Foamies 4 Apr 13, 2012 10:14 PM
Discussion OPEN discussion thread DLGjunkyard Hand Launch 62 Mar 18, 2012 11:09 PM
Discussion "Attention LSF members" - discussion thread Miami Mike Thermal 16 Mar 14, 2012 08:24 PM
