Old Jun 30, 2012, 07:34 AM
SARCFAN is offline
Find More Posts by SARCFAN
Joined Dec 2010
70 amps is quite a lot allready. My BJ26 ran happily with only a 45 amp esc using its standard powerfull 540 class motor with a 45mm prop.
Looking at that props, they surely can go bigger for this hull.
SARCFAN is offline Find More Posts by SARCFAN
Old Sep 20, 2012, 02:23 AM
stalyoni is offline
Find More Posts by stalyoni
high flyer
stalyoni's Avatar
Australia, WA, Geraldton
Joined May 2008
i know this is an old thread but i thought i would post an update of how my boat performs now.
Apparition twin on a 4cell with 2 x S2858-2630kv motors (5 min 40 sec)
2 x S2858-2630 Brushless Inrunner (2630kv)
2 x Turnigy 3000mAh 4S 20C Lipo Pack
2 x 38mm counter rotating props
1 x 190-200amp hobbyking water cooled esc
1 x 5a turnigy ubec
1 x 3000 hkr rx
1 x hk 300 tx
2 x cooling intakes and 4 outakes
i have some better c rating lipos now and i will put dads old phone in it as use a speed app next time to get the speed.
I still have to add another pickup into it as it stops every now and then and im pretty sure its due to overheating. I have only flipped this boat once and when I did I got the esc wet and it malfunctioned so I replaced it and it works fine again.
I have been thinking about going to 6s with different motors but its almost flipping now and top speed and I dont want to add more weight to the nose to stop it from flipping. Im also limited to the space I have here. On a 6s it would chew it up very quickly.
I will stick in my old phone with a gps speed app in it soon and get a prop speed reading with my better c rating lipos and we will see what we get.
All I know is that its quicker then my dads boat and im happy with the way it runs now.
stalyoni is offline Find More Posts by stalyoni
Old Oct 05, 2012, 01:32 PM
cosey321 is offline
Find More Posts by cosey321
Joined Sep 2012
Hey, if there are straight shaft for an flexshaft, theres not the same power. It should be bend a little.
cosey321 is offline Find More Posts by cosey321
Old Oct 05, 2012, 03:15 PM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
You're running a single ESC on the twin motors?
wparsons is offline Find More Posts by wparsons
Old Oct 06, 2012, 12:47 AM
stalyoni is offline
high flyer
stalyoni's Avatar
Joined May 2008
yes its a 190-200amp hobbyking esc. We just made y leads to go out to each motor. It works well.
Why whats wrong with this?
Old Oct 06, 2012, 07:22 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Sensorless brushless ESC's (like what you have) use EMF feedback from the motor to determine where it is in the rotation and to adjust timing. Having two on the same ESC will give less than optimal performance since the motors aren't perfectly in sync (especially in a twin cat, the outside motor in a turn will want to unload more) the feedback will be confusing to the ESC. You would get better performance from two smaller ones than a single one y'd like this.
Old Oct 08, 2012, 04:44 AM
stalyoni is offline
high flyer
stalyoni's Avatar
Joined May 2008
runs fine the way it is and goes very fast so im happy
Discussion Apparition Twin Hull, Twin motor offshore boat Oblivion Racing Boats - Electric 107 Dec 30, 2014 09:53 AM
Question Twin motor Startup issues rcav8r2 Power Systems 11 Jun 26, 2012 07:37 AM
Discussion Mounting my lipos in a Apparition-II stalyoni Racing Boats - Electric 7 Jun 25, 2012 07:46 AM
Discussion need new motors for apparition twin drive Oblivion Racing Boats - Electric 26 Oct 22, 2011 05:14 AM
Discussion Apparition Twin motor ramtornado Racing Boats - Electric 0 Jul 17, 2010 09:12 AM
