Old Jun 28, 2012, 06:07 AM
PrimalV is offline
Find More Posts by PrimalV
United States, FL, Tampa
Joined May 2012
Help!
Converting degrees to mm or inches
Anyone know a conversion on degrees to mm or inches. Trying to setup throws on a couple of my planes and don't have a protractor handy. Have my great planes throw meter but t only reads in inches and millimeters.Usually just use a builders protractor but mine seems to be lost. By the way, the plane is a 3DHS 72 Extra. I know you need the surface measurement (ie...aileron,elevator for an accurate measurement) but looking for a formula
PrimalV is offline Find More Posts by PrimalV
Old Jun 28, 2012, 06:14 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
SOH CAH TOA
The most relevant one here would be angle = sin^-1(throw/chord)
The windows calculator does the inverse sin function.
pmackenzie is online now Find More Posts by pmackenzie
Old Jun 28, 2012, 08:10 AM
rjstrickjr is offline
Find More Posts by rjstrickjr
rjstrickjr's Avatar
United States, NC, Faison
Joined Jan 2011
Metric converter
I like this one. It's free and will do more than just leanths.
http://www.worldwidemetric.com/measurements.html
rjstrickjr is offline Find More Posts by rjstrickjr
Old Jun 28, 2012, 08:52 AM
mikmerl is offline
Find More Posts by mikmerl
mikmerl's Avatar
Athens, Greece
Joined Apr 2010
Try doing it this way
Degrees are increments of a circle or arc.
To simplify the exercise treat your control surface as something that will make full 360 degree motion.
Using the following formula:
Diameter x Pi, (3.14159), divided by 360 for 1 degree.
The diameter of the circle in our case will be the width of your control surface x2.
Then multiply the degrees travel with the above result to get travel in mm.
Eg: Let us say that we need a elevator deflection of 40 degrees for the example
width of elevator=50mm (that is the radius of your travel circle)
multiply that by 2 to get your diameter.
result is 100mm.
multiply 100 by 3.14= 314
divide 314 by 360 = 0.8722mm
multiply 0.8722 x 40 degrees
34.88 is your travel distance in mm
hope this helps
mike
mikmerl is offline Find More Posts by mikmerl
Old Jun 28, 2012, 09:15 AM
pmackenzie's Avatar
Joined Dec 2002
result is 100mm.
hope this helps
mike
Since we can't measure arc length that is the basically the small angle approximation, x = sinx. (X in radians of course)
40 degrees is not a small angle , so you should have said ~35 degrees. (Makes no sense to do 4 digits when the answer is out by ~8%)
True answer for 40 degrees is 50*sin(40) = 32.14
Close enough I suspect, but since everyone has a calculator on the PC, why not just do the sin?
Personally I usually just eyeball it anyway
Pat MacKenzie
Old Jun 28, 2012, 10:42 AM
rjstrickjr's Avatar
Joined Jan 2011
I am LMAO!
You fellas just went so far over my little brain that I did'nt even see you go over!
Well said by all and I think I will just use the eyeball technique!
Max out the control surfface and only use what you need by the input of the gimble is what I do.
Old Jun 28, 2012, 11:25 AM
dgliderguy is offline
Find More Posts by dgliderguy
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
Pat MacKenzie
NO KIDDING!!! I never measure my control throws, I just stand behind my model when programming and eyeball my throws, and I get comfortably within the ballpark just about every time. Maybe I will fuss with dual rates sometimes, but it is always through experimentation (flight test) rather than with physical measurements.
Soapbox speech: In all my years (and I have had nearly 200 models over the years-- check my blog, they're all listed there), I have never once measured my control throws. First of all, we really should be measuring angles, not inches (or mm's), as control surfaces don't always have a constant chord. Second of all, why should I accept someone else's values, when my personal preferences may be different? Thirdly, control sensitivity is a function of airspeed, so what may work at cruise speed may not be enough on approach, or in a thermal at minimum sink speed. Flight testing is still the best way to determine control throws, and eyeballing the throws in preparation for the first flight has always worked out just fine for me.
dgliderguy is offline Find More Posts by dgliderguy
Old Jun 28, 2012, 10:10 PM
PrimalV is offline
Joined May 2012
Thank you for all the replies. I usually set the control surfaces as a starting point an go from there. I have gotten some good ideas.
Old Jun 29, 2012, 03:19 AM
mikmerl is offline
mikmerl's Avatar
Athens, Greece
Joined Apr 2010
Gentlemen
The man asked for a way to measure control surface deflection and you’re describing your bionic eyeballs to him.
mike
Old Jun 29, 2012, 06:42 AM
PrimalV is offline
Joined May 2012
Guess if I want it easy and exact I should order the throw meter from aero works. It is in degrees. Lol.
Old Jun 29, 2012, 06:45 AM
PrimalV is offline
Joined May 2012
Mike thank you for your replies. I think your method will be the easiest.
Old Jun 29, 2012, 07:52 AM
rjstrickjr's Avatar
Joined Jan 2011
Mik, you are absolutley right.
I will share this, the only RC plane that I have needed to actualy measure deflection of a control surfface on was a Tocanno .60 by World Models. I had used the ole eyeball technique as discribed above and almost lost the plane on landing. The Tocanno is very pitch sensitive and requires very little elevator to move it up or or down. Once I got it back on the ground I adjusted to the recommended throws with a Great Planes throw meter, and she flew fast and straight! The GP throw meter has inches and MM on it so it can be used for bothe SAE and Metric.
Old Jun 14, 2015, 01:24 PM
Razmo is offline
Find More Posts by Razmo
United States, IL, Chgo
Joined Jul 2004
Hey guys, just coming across this thread.. Helpful, thanks to Mike and Pmack..
Question.. I've noticed my iPhone calc offers a sin function. Using the 50mm example, I'm assuming I cannot simply input 50*sin= Doing so gives me 38.30 etc .. but figuring the calculator would need to understand the 40 degree variable somehow..?
If anyone can help me understand how to use the sin function would be helpful..
Raz
Razmo is offline Find More Posts by Razmo
Old Jun 14, 2015, 03:00 PM
pmackenzie's Avatar
Joined Dec 2002
I don't have an iPhone, but if you wanted to calculate x * Sin(y) on most calculators the order would be:
enter y { the angle}
hit Sin
hit *
enter x { the length}
So for the example above of 40 degrees deflection of a 50mm elevator
enter 40
hit Sin display should read 0.6427....
enter *
enter 50
hit = and it should display 32.139
Old Jun 15, 2015, 10:55 AM
Razmo is offline
Joined Jul 2004
Thank You Pmack! The iphone calc comes out at exactly 32.13938048432696
Raz
For Sale Convertable frame (tri.quad or hex) actionplus Aircraft - Electric - Multirotor (FS/W) 4 Jul 07, 2012 01:30 PM
Wanted 50 mm or 2 inch Heat Shrink Wanted Wasteland Aircraft - General - Miscellaneous (FS/W) 6 Dec 31, 2011 06:41 PM
Wanted Spinner 3.25 inch, 84 mm 2 blade or 3 blade WesternFlyer Aircraft - Electric - Power Systems (FS/W) 0 May 07, 2011 11:04 PM
Discussion Props in mm or inches? nismoron Scale Boats 9 Aug 10, 2010 09:57 AM
