Joined Aug 2009
would a sealer be recommended anyway? also with a regular wax? i have used a semi permanent yesterday on a testpiece , i waxed and buffed the mold with partall#2 let it set for a bit and then sprayed on and whiped of the semi permanent like you describe , 3 layer's of it . the release was very good but the mold was very rough , i sprayed clear coat in the mould and i could do it in 1 layer , no ,fisheye's and i was able to spray a much thinner layer then i could do on pva.. i guess the semi permanent released from the mold cause it was waxed ... |
United States, MD, Lusby
Joined Nov 2003
Kristof,
Have you done releases with just Partall #2 and no paint? Or just the wax and a clear coat? I've been using Partalll #2+PVA+lacquer+MGS or Resin Research in my corian wing molds without release issues. To my knowledge this is the same process Phil uses. If I could skip the PVA step it would be really nice as I typically re-wax every 2nd-3rd pull anyway. It would be nice to know your particular epoxy and pain combination, in addition to the release system you are using. I won't claim to speak for Tom S., but last I remember he wasn't too happy with Frekote on a corian mold with his molding process, but we both use resin research occasionally so that may be the primary issue. I've looked into using McLube's products for release and have a sample here that I still need to try, problem is I don't have a mold sealer. Adam, Do you have a preferred mold sealer? I'm looking at ordering the "TR-301 Sealer Glaze" from http://sweetcomposites.com/Misc.html#PVA Thanks, Sam |
Resin Research resin and any semi-permanent is bad news. I've tried Zyvax, McLube, and Frekote with Resin Research and had sticking issues. The first release will release o.k. but the second and third will be very difficult. I should state that 90% of my Frekote experience is with in mold paint processes. Paint, in the right combination, makes everything go faster and easier. Faster layups, fewer pinholes, better releases, easier mold clean-up, and more mold longevity. |
Joined Aug 2009
you said you have a corian mold ? did you used the sealer and 770 on it? thanks for your'e help -kristof- |
| Thread Tools | |
| Discussion What's your favorite indoor heli? | PCaola | Micro Helis | 33 | May 14, 2012 08:09 PM |
| Discussion Tricopter motors what's your favorite? | mssmison | Multirotor Talk | 1 | May 02, 2012 08:32 PM |
| Discussion Your Favorite TX For MultiCopters & Why | zuby1 | Multirotor Talk | 22 | Mar 11, 2012 09:33 PM |
| What Vehicle Is Your Favorite to Transport Your Planes (and why)? | JDCochran | Electric Plane Talk | 91 | Jan 11, 2005 04:30 PM |
| What's your favorite large sailplane (8-12' wingspan), and why? | DocMac | Electric Sailplanes | 22 | Jun 12, 2001 07:35 AM |
