Old Jul 17, 2012, 03:48 PM
Joined May 2010
Pat
As a temporary deal I put a piece of 5mm ply About 3/8 wide across the tail saddle in line with the leading edge. I carefully tightened the bolts so I would not warp or damage the unsupported horizontal. Now that I know that is good I will make shims that go from 5mm to 0 the length of the saddle and glue them on. I will tack two sticks of 1/4 spruce the right length together then use a razor plane and sanding block to make a matched set of shims.
Mark
Mark Anderson is offline Find More Posts by Mark Anderson
Old Jul 17, 2012, 07:10 PM
Vintage wood is the best!
SZD16's Avatar
In a house
Joined Sep 2002
Hard balsa will work just as good and be easier to sand to shape also.
SZD16 is offline Find More Posts by SZD16
Old Jul 17, 2012, 07:15 PM
SZD16's Avatar
In a house
Joined Sep 2002
Originally Posted by pmccleave View Post
Guys,
Where exactly are you putting the shims on the stab and can somebody shoot a picture of what they did and share with us?
Pat
Pat......either put them on top of the existing saddle....one on each side 3/16" at the front tapering to 0" at the back....or.....you could also put them on the elevator/stab itself.
Old Jul 17, 2012, 07:44 PM
Corner Ketch, DE
Joined Sep 2005
Guys I have the upper and lower bays done the question is does the spoiler have to open towards the root ?
This would require two servos
If I put the spoilers in the other way I can do one servo in the door at the attachment point
This would pull the spoiler open towards the tip
creeve is offline Find More Posts by creeve
Old Jul 17, 2012, 09:10 PM
SZD16's Avatar
In a house
Joined Sep 2002
Doesn't really matter....it's not the like the plane is true to scale anyway......put them in the way it works best. Then.....when you land we can rib you about your spoilers being wrong!!
Old Jul 17, 2012, 09:22 PM
SZD16's Avatar
In a house
Joined Sep 2002
Well here are my pictures of the damage that I did to mine......after watching a crappy video of the landing what happened is that with out spoilers it came in fast and went further down the runway which is grass then I thought it would and there is a paved section of runway that cuts across where I landed and the plane hit that edge of paving and it bumped it back into the air...that is when I think it broke.
What I did was take the covering off of one side and CA'd all the parts back together and then cut scabs to go front and back of each former on both sides....even the ones that didn't break got reinforced...I used 1/8" ply for those around the wheel box and 1/16" everyplace else......I did them all.
Old Jul 17, 2012, 09:24 PM
Corner Ketch, DE
Joined Sep 2005
Scale!
Old Jul 17, 2012, 09:27 PM
SZD16's Avatar
In a house
Joined Sep 2002
Scale!
Not so much....there was a full size at Elmira....ours are not "scale"
Old Jul 17, 2012, 10:15 PM
Joined Jul 2009
Spoiler direction
I think Ross (BN) & some of the scale-inclined guys on the German build put them opening opposite direction. The top ones towards the fuse ,and the bottom ones opening toward the tips. Isn't that the way the full scale ones were? For me, it's probably top only for a while, and then, whatever is easiest.
flyingfever is offline Find More Posts by flyingfever
Old Jul 18, 2012, 03:23 AM
Big Nuts 181's Avatar
Joined Jul 2004
Hi guys for scale top side opens outward bottom inward.
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Jul 18, 2012, 08:25 AM
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I was interested in this model until I heard all the issues ... it's a great deal but it's still a lot of $$$ for something you have to re-engineer to make right.
Back to drooling over the glass slippers, I guess.
tkallev is offline Find More Posts by tkallev
Old Jul 18, 2012, 09:36 AM
Joined Jul 2004
Touch wood mine is still intact..... I havnt adjusted the incidents I don't carry down elevator and I havnt broken any formers in landing accidents, not sure why everyone else is having so many dramas.......
Old Jul 18, 2012, 08:59 PM
United States, WA, Olympia
Joined Oct 2009
Tikall. The plane is a great value and flies very well. It is majestic in the air. This is especially true during an approach for landing. It is COOL!
Reinforcing the formers is not a big deal at all - maybe 1 hour worth of work. Playing with decallage and moving cg around is no more than normal trimming and tuning.
Don't be swayed by the forum. Negative remarks almost always look worse in open forums than they are in reality.
If you review this thread, you'll see shipping problems, problems caused by hard landings, tuning concerns, and one weakness in the design. There is nothing there that you wouldn't find in any new 40-sized airplane release. If you want a 6meter scale airplane that goes together very quickly, looks great in the air, and flies well, I would recommend this one.
olythom is offline Find More Posts by olythom
Old Jul 18, 2012, 09:13 PM
USA, KS, Wichita
Joined Sep 2002
Guys,
I am trying to figure servo torque calculations for selecting servos for the K8B mainly so I can see if servos I already have will work. Can anyone tell me what kind of air speeds I should be using in the calculator and also appropriate deflection angles for the surfaces? I am trying to figure out if the JR DS821's which have 88 in/oz of torque at 6 volts will work for the ailerons and elevators. I for sure have to buy at least one new servo for the rudder and maybe one for the tow release but I would love to be able to use the DS821's if they will work. They fit fine but not sure if they have enough poop to them.
Pat
pmccleave is offline Find More Posts by pmccleave
Old Jul 19, 2012, 01:21 AM
Joined Jul 2004
Hi Patt I've been flying my Ka from day one with Hitech 645 mg servos on aileron elevator HS 705bb on rudder HS 422 on each airbrake and HS 805bb on tow release. 150 flights+ and still going strong. If you use these as a guide for torque @ 6 volts you'll be fine.
Alert Phoenix 6 Meter K8 One Time Special Order SteveR Scale Sailplanes 393 Jul 19, 2012 07:40 PM
Discussion PHOENIX Evolution 2.6 dougind Electric Sailplanes 1 Jun 16, 2012 08:40 AM
For Sale Hitech Eclipse tranmitter and 8 Receivers on 6 meters for sale or trade. model medic Aircraft - General - Radio Equipment (FS/W) 0 Apr 02, 2012 08:06 AM
Alert Last Call for the Phoenix 6 Meter K8 Sailplane SteveR Scale Sailplanes 5 Nov 22, 2011 06:24 AM
