Old Jul 09, 2012, 04:16 PM
SteveR is online now
Find More Posts by SteveR
New York
Joined Feb 2002
Thanks Harm, great tips. Did you cut off the nose of the K8 to install the tow release? Did you tie the nose into the rest of the fuse with more reinforcements?
Regarding strengthening the vertical fuselage ribs, did you make up doublers for them, more bracing, etc.?
Steve
SteveR is online now Find More Posts by SteveR
Old Jul 09, 2012, 05:28 PM
flyingfever is offline
Find More Posts by flyingfever
Joined Jul 2009
FEMA or Robbe wheel
Anyone know where to purchase a FEMA or Robbe wheel, preferably in the US? (110-112mm seems about right.) I doubt the larger Dave Brown or Dubro foam ones are stout enough. Thanks. Bob
flyingfever is offline Find More Posts by flyingfever
Old Jul 09, 2012, 05:45 PM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
Try the big sullivan with the alloy hub, having said that my alloy one that came with the model is already 150+ flights old now and working well.
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Jul 09, 2012, 05:58 PM
iflytailies is offline
Find More Posts by iflytailies
aka Schleppmeister
PA
Joined Feb 2006
I have two 150mm FEMA in stock. Please send PM if interested
iflytailies is offline Find More Posts by iflytailies
Old Jul 09, 2012, 06:07 PM
Mark Anderson is offline
Find More Posts by Mark Anderson
Mark Anderson's Avatar
United States, WA, Tumwater
Joined May 2010
One thing that I am adding tonight. Olythom thought of it. We are putting the clear mylar used by rc car guys to protect the bottom of their chassis on the skid areas. This is very tough stuff.
Mark
Mark Anderson is offline Find More Posts by Mark Anderson
Old Jul 09, 2012, 06:58 PM
Joined Jul 2009
Thanks. The 112-114 mm ones (4.5 ") are close to scale, and just fit with a little clearance. The 150mm would require cutting out the supports & opening, and re-building the receiver box. Love the pilot I got from you a while back, tho. Thanks, Bob.
Old Jul 09, 2012, 11:45 PM
Joined May 2010
here is a link to video of our first tows.On first one we learned our tow line was not strong enough. We switched to a stronger line and got several flights in. The second and third flights on the video were the maidens of each of our planes. The tows were short to get the gliders trimmed.
RC Video: Phoenix K8b Glider & Piper Pawnee Tow Plane (4 min 10 sec)
Mark
Old Jul 10, 2012, 05:11 AM
Joined Jul 2004
Great video Mark, If I may make a couple of observations, during your tow you look to be dragging the glider off the deck beofore the glider has reach flying speed, let it rotate buy itself, the model does this really well and helps to stop wind getting under it on a windy day. Lastly I found that with the 10% down elevator mixed into tow release the model sits at a really nice height above the tug and makes it easier for the tug to climb, 1-1/2 models above the tug looks cool and works best for me as well as helping not to stall the tug and makes the tug pilots job much easier to climb. Please don't take my observations the wrong way, just trying to help out so you guys can get as much fun out of your KA combo we have over the past 8 months.
cheers Rossco.
Old Jul 10, 2012, 08:16 AM
Joined May 2010
Rossco, I am open to any advice. We are very new to this. We are letting it take off on it's own, the only control input is keeping the wings level. These things just want to fly. I will try the down elevator mix.
Mark
Old Jul 10, 2012, 09:31 AM
Joined Jul 2004
No worries Mark as long as your having fun and buy the look of it your doing a good job.
Old Jul 10, 2012, 04:55 PM
New York
Joined Feb 2002
Anyone understand why planes like the K8 and Minimoa benefit from a bit of down elevator on tow? I ask as I used to struggle with my 4.8 meter Mini. It used to wag from side to side until I tried a little down and now it tracks perfectly. Still don't understand the dynamics.
Steve
Old Jul 10, 2012, 05:15 PM
Lbuff1 is offline
Find More Posts by Lbuff1
TEAM HORIZON
Lbuff1's Avatar
Killingworth CT
Joined Nov 2008
Steve, Wagging on tow is a sign of the plane being tail heavy. Which of course would be helped with the down elevator.
Len
Lbuff1 is offline Find More Posts by Lbuff1
Old Jul 10, 2012, 05:40 PM
New York
Joined Feb 2002
Sorry... "wagging" was a bad choice of words. It oscillates and at time almost to the point of doing a barrel roll. I would think if it's tail heavy, the plane would still require a bit of down elevator to fly level once off tow, yet the elevator is quite neutral and the plane pulls out of a dive test in a very predictable gentle arch upwards.
The only reason I tried a bit of down on tow was because someone once commented that the plane appeared to be stalling...maybe a high speed stall?
Well, all of this is a bit academic since the plane was destroyed last fall due to a TX failure...the second for that radio which is now confined to the junk heap.
A new Mini will be ready for SKSS. We'll see how it behaves...along with a different radio!
Steve
Old Jul 10, 2012, 05:53 PM
Joined Jul 2004
hi Steve the closest explination I can come up with is the relation between the tow point, low down relative to the wing up high, kind of like winch launching at higher speed, the other is the higher airspeed in relation to the wing incidence, effectively the model is kiting. I remeber being told the 1-26 schweizer coud be winch launched from the nose hook, not sure if this is true or not but just my thoughts.
Old Jul 10, 2012, 06:30 PM
New York
Joined Feb 2002
I think airspeed has a lot to do with it as the problem seems to get worse the faster the tow.
And now that I think about it, I had the same experience at JR this year with the 5.6 meter Lanyu Minimoa which was balanced per other pilots' experience but needed down trim on tow.
Well, whatever it is, at least we know how to deal with the situation.
Alert Phoenix 6 Meter K8 One Time Special Order SteveR Scale Sailplanes 393 Jul 19, 2012 07:40 PM
Discussion PHOENIX Evolution 2.6 dougind Electric Sailplanes 1 Jun 16, 2012 08:40 AM
For Sale Hitech Eclipse tranmitter and 8 Receivers on 6 meters for sale or trade. model medic Aircraft - General - Radio Equipment (FS/W) 0 Apr 02, 2012 08:06 AM
Alert Last Call for the Phoenix 6 Meter K8 Sailplane SteveR Scale Sailplanes 5 Nov 22, 2011 06:24 AM
