Old Feb 04, 2013, 03:37 PM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
Great solution, Harm. Looks like I'm going with your approach! Eager to hear your flight report.
Steve
SteveR is offline Find More Posts by SteveR
Old Feb 08, 2013, 07:55 PM
flyingfever is offline
Find More Posts by flyingfever
Joined Jul 2009
Lower spoiler location
Hi KA8 guys, I need some help. Since I got the wing fix cf tubes AllenK suggested before the replacement wings came out, and my replacements aren't as nice cosmetically as my originals, I'm in the midle of doing the AllanK fix to the originals. I plan to install 440 electric spoilers top and bottom. The top spoiler box has a space of about 1 1/4" between it and the back of the d-box & spar webs. Question: Would it pose any problems if I locate the bottom ones right behind the d-box instead of leaving the space? It would be easier and maybe stronger than the top one with the space. If it is a toss-up, I'll mount them behind the spar, and post pictures of the upgrades. Oh, one more thing--is it worth the effort and weight (mine is really heavy with all the mods) to intall the lower ones, or just use the top ones? I've got ample landing space. Thanks, Bob.
flyingfever is offline Find More Posts by flyingfever
Old Feb 08, 2013, 10:52 PM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
I have just the top spoilers and mine stops just fine.
SZD16 is offline Find More Posts by SZD16
Old Feb 13, 2013, 11:13 AM
selleri is offline
Find More Posts by selleri
On a small rock in a big pond
Iceland
Joined Dec 2004
So what's the smallest plane you've used to tow the K8 up so far?
selleri is offline Find More Posts by selleri
Old Feb 14, 2013, 08:47 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
100cc 3 meter Pawnee but you don't need that much.
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Feb 14, 2013, 03:15 PM
Harm is offline
Find More Posts by Harm
Holland
Joined Jan 2004
I have a possible canditate for trying this, the MPX FunCub
http://www.youtube.com/watch?feature...&v=B7TWg5yQ6NI
Harm is offline Find More Posts by Harm
Old Feb 14, 2013, 05:01 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Only in very cold weather where the air is really dense.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Feb 16, 2013, 04:55 AM
bananaman is offline
Find More Posts by bananaman
bananaman's Avatar
Brisbane Australia
Joined Oct 2000
I did mine this way for the lower surface (after building mechanical brakes, I went with off the shelf). Simple and strong box once glued in.
The 2nd box to be fitted to the other wing is shown.
The Alan mod but the carbon tube and shipping would have cost as much as I got the kit for! I'm using 2 carbon wing joiner tubes per side that cost wayyy less. The tubes are just sitting there in the image and will be bonded to each rib with plates and be glued to existing joiners by a method I've yet to devise. But it will happen.
The tubes slide into each other, firm fit and will be glued and kevlar thread wrapped around join.
bananaman is offline Find More Posts by bananaman
Old Feb 16, 2013, 03:24 PM
Joined Jul 2009
wing mods
B- Thanks for the reply and pictures. Looks the same as my fix. By removing some rib matrial behind the end of the joiner tube, the cf tube nestled up against the inner end of the front joner. Regarding the bottom spoiler, I was concerned, since the rib doublers (tube mounting plates) transfer the forces to the spars, the cutout for the bottom spoiler box would reduce the strength. If the spar tube is well anchored to the joiner tubes, it'll probably be fine. Also, the inner wing sheeting covering the 1st 2 bays and joiner tubes was quite easily removed, exposing the 2 inner bays, allowing adequate reinforcent and joining of the cf spar tube and cardboard joiner tubes and webs. The sheeting seemed glued solid at first, but due to spotty glue application, I scored the sheeting joints at the spars, reached in underneath the sheeting, and popped it free in 1 piece. It took a little prying, but well worth it for access to inner tubes and webs. I intend to glass the cb tube to the front joiner tube & spar. Is it necessary to add spar web doublers to cover the > cutouts on the rear spar? I'll get some pictures posted soon. Thaks again to all. Bob.
Old Feb 16, 2013, 06:08 PM
bananaman's Avatar
Brisbane Australia
Joined Oct 2000
If the new spar tube ended at the spoiler cut out I'd be worried about the load transferred through the ribs in that area, but it carries through to the end. The ribs are ply and flimsy and are more like shape holders for the covering and spacers between the D box and rear spar than structural elements, the box adds rigidity in that area so I'm not as concerned about that spot as I am about the rest of the wing. I am going to add shear webs to the rear spar (if it can be called that) as I have access and I don't like the look of it. e.g. Look at the first image, I think they missed one behind the spoiler box?
Old Feb 16, 2013, 10:32 PM
SteveR is offline
New York
Joined Feb 2002
Bananaman, how much overlap between the nesting carbon tubes?
TIA,
Steve
Old Feb 17, 2013, 04:42 PM
bananaman's Avatar
Brisbane Australia
Joined Oct 2000
I have enough material to do 18" but I'll overlap by 8". The tubes are a very good fit. No slop.
Old Feb 17, 2013, 09:13 PM
Mark Anderson is offline
Find More Posts by Mark Anderson
Mark Anderson's Avatar
United States, WA, Tumwater
Joined May 2010
We've towed behind a 1/3 scale cub with a Zenoah 80. Long, scale tow. Did see the cub yanked out of the air by one of these planes on maiden, But our tug pilot just righted things and continued on like nothing happened. Our regular tow plane is 1/3 Pawnee with a 3w 106
Mark
Mark Anderson is offline Find More Posts by Mark Anderson
Old Feb 18, 2013, 09:57 PM
selleri is offline
Iceland
Joined Dec 2004
Cheers, our normal tug is also a Zenoah 80 powered 1/3 Cub so good to know it's doable.
Old Mar 05, 2013, 04:28 PM
SZD16 is offline
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
Alright.....I have my new panels all done....swapped over the spoilers and wiring harnesses.....ready for Cumberland in three weeks!
The new wings also did not come with the reg letters on the bottom.....I just put large 4 - 10"x10" diamonds of red on both wing bottoms to help with viability in the air....its not like these are scale anyways!
Alert Phoenix 6 Meter K8 One Time Special Order SteveR Scale Sailplanes 393 Jul 19, 2012 08:40 PM
Discussion PHOENIX Evolution 2.6 dougind Electric Sailplanes 1 Jun 16, 2012 09:40 AM
For Sale Hitech Eclipse tranmitter and 8 Receivers on 6 meters for sale or trade. model medic Aircraft - General - Radio Equipment (FS/W) 0 Apr 02, 2012 09:06 AM
Alert Last Call for the Phoenix 6 Meter K8 Sailplane SteveR Scale Sailplanes 5 Nov 22, 2011 07:24 AM
