Old Oct 23, 2012, 03:55 PM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
Thanks Bill, greatly appreciate Hobbico's outstanding product support!
Regards,
Steve
SteveR is offline Find More Posts by SteveR
Old Oct 23, 2012, 05:18 PM
kjkavaney is offline
Find More Posts by kjkavaney
Joined Jan 2003
Wonderful...
I nearly bought one of these and until just now was very happy that I had NOT done so...but I am relieved for all my friends who have these are being supported by the Dealers and suppliers of this plane...
how refreshing of a story..
Kevin
kjkavaney is offline Find More Posts by kjkavaney
Old Oct 23, 2012, 06:19 PM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
So......has anyone seen the new wing panels? And are they the same as the pictures that I linked to on the German forums?
SZD16 is offline Find More Posts by SZD16
Old Oct 23, 2012, 08:45 PM
tewatson is offline
Find More Posts by tewatson
Riddle me this...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Are they giving Pat a whole new plane?
Tom
tewatson is offline Find More Posts by tewatson
Old Oct 23, 2012, 09:31 PM
k2k is offline
k2k
Find More Posts by k2k
k2k
k2k's Avatar
United States, CA, Oceanside
Joined May 2003
Steve –
First how I did it and then how I should have done it.
The lower portion of the fuselage was covered with left and right sided pieces which extended the full length, up to the canopy cut out, middle level of the wing root, and upper longeron extending to the tail. A third piece covered the top rear and forward to include the triangular fairing of the center section. This piece of fabric was trimmed along the bottom of the top longeron. Not as much overlap as I would have liked, but enough. The forth piece covered the top of the center section and extended down over the wing roots with some overlap forward of the center of the wing root with the bottom piece. It is amazing what you can do with some heat and tension on the fabric. The last piece covered the nose top half. Tapes were applied over all the straight seams except along the bottom of the wing root.
It would have been interesting to have sewn an envelope, but since I lack that skill that was not in the cards.
I think a better approach would have been to glass the top center section up to the canopy opening and down to the level of the bottom of the wing root to avoid putting fabric on all those nasty compound curves. Although the fabric can be worked around the wing root and stuck down with the Poly Tak, it’s not easy and it came out a little bumpy at the forward intersection of the root and fuselage. When doing concave curves like that, the underlying surface needs to be prepped with a couple coats of glue, then the fabric is glued down by rubbing diluted Poly Tak through the fabric and bonding to the underlying glue.
At the forward wing root – fuselage intersection they painted the wood with a gummy yellow adhesive to keep the Ultracote stuck down. I managed to get this adhesive off with toluol. Toluene or xylene should also work.
k2k is offline Find More Posts by k2k
Old Oct 23, 2012, 09:40 PM
AllanK1 is offline
Find More Posts by AllanK1
Blenheim, NZ
Joined Dec 2007
Well done Steve
Nice effort Steve, great to see a reworked model flying well and safely. I congratulate you on making the effort.
Loved the video
Allan
AllanK1 is offline Find More Posts by AllanK1
Old Oct 23, 2012, 09:44 PM
pmccleave is online now
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
Tom,
I can tell you this, they are taking goog care of me.
See Ya,
Pat
Tom
pmccleave is online now Find More Posts by pmccleave
Old Oct 24, 2012, 03:29 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
For the aussi guys who bought from the first batch of ka8's like myself here is the official word from Our importer
http://www.modelengines.com.au/News_.../487-news.html
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Oct 24, 2012, 07:00 AM
SteveR is offline
New York
Joined Feb 2002
Ken, thanks very much for all the covering details, greatly appreciated. I like your idea about glassing around those nasty compound curves.
Steve
Old Oct 24, 2012, 10:10 AM
stephen Damon is offline
Find More Posts by stephen Damon
USA, TX, Waco
Joined Nov 2010
Hobbico service told me this am that there would not be any available until January, Steve can you check on that if at all possible, Thanks
stephen Damon is offline Find More Posts by stephen Damon
Old Oct 24, 2012, 10:22 AM
vangrafhorst is offline
Find More Posts by vangrafhorst
The Netherlands, OV, Haaksbergen
Joined Jun 2009
In Germany, wings are being inspected at the dealer(Hillenbrand Modellbau). If it is not the new wing, no shipping will go. New wings are expected to leave the factory, delivery in december.
Joris
vangrafhorst is offline Find More Posts by vangrafhorst
Old Oct 24, 2012, 12:51 PM
k2k is offline
k2k
k2k
k2k's Avatar
Joined May 2003
Here is a method to make the stab removable without taking off the vertical fin. A ply hold down tab is added to the rear of the stab and keys into a slot in the vertical fin stub. The cut out in the bottom of the stab needs to have parallel sides as the existing wedge shape will not allow it to be slid forward. The sheeting was cut back and new lite ply sides installed. The stab incidence was changed by 8 mm by routing down the stab saddle. The saddle was then raised about 3/16” to get the front edge of the stab cut out to the same level as the top of the center longeron. A wedge was added to the bottom of the vertical fin to tighten up the gap.
The incidence change is working out to be about right. The elevators have a little bit of up trim but the plane is still nose heavy. I started the cg at 145 mm and have subsequently removed all 8 oz of the loose nose weight and added 3 oz to the tail. I guessing 8 oz or more still needs to come out of the nose which will bring the elevators down into a neutral postion.
Old Oct 24, 2012, 02:38 PM
AllanK1 is offline
Blenheim, NZ
Joined Dec 2007
Shabby!, Model Engines should be lobbying the Manufacturer for the same deal on all your behalves.
Allan
Old Oct 24, 2012, 02:52 PM
k2k is offline
k2k
k2k
k2k's Avatar
Joined May 2003
Wheels
Modifying the mail wheel. A wheel box was made from 6 mm Finnish ply sized for a CB Associates 4.5” wheel. The stainless steel brackets were attached to the side plates with flat head 6-32 screws and blind nuts. The angle on the bottom of the fuselage is 120 degrees. A router template guide was made from hardboard and 30 degree wedges. Some additional chisel work was needed to extend the cut and provide clearance for the blind nuts. After fitting the box, it was glued in with a generous amount of polyurethane glue.
I decided to add a tail wheel because our main flying site is tarmac and makes short work of skids. The tail skid was cut off and hollowed out. An 1/8” ply plate was glued into the bottom and 1/16” G10 added to the sides for load bearing. The outside was glassed with two layers of 6 oz glass and the interior with multiple layers of 2 oz glass. The 2” wheel has an 1/8” music wire axle retained with E-clips.
Old Oct 24, 2012, 03:07 PM
k2k is offline
k2k
k2k
k2k's Avatar
Joined May 2003
Skid
Adding a skid. The existing V-shaped skid was planed down to a flat about 5/8” wide. Two strips of 1/16’’ plywood were laminated onto the flat. An additional short piece of 1/8” ply was added to nose and was tapered down to meet the nose piece. A strip of 1/8” aluminum was screwed to the plywood. I will add a short piece of steel in the contact area of the skid as the aluminum will get chewed to bits by the tarmac.
Alert Phoenix 6 Meter K8 One Time Special Order SteveR Scale Sailplanes 393 Jul 19, 2012 07:40 PM
Discussion PHOENIX Evolution 2.6 dougind Electric Sailplanes 1 Jun 16, 2012 08:40 AM
For Sale Hitech Eclipse tranmitter and 8 Receivers on 6 meters for sale or trade. model medic Aircraft - General - Radio Equipment (FS/W) 0 Apr 02, 2012 08:06 AM
Alert Last Call for the Phoenix 6 Meter K8 Sailplane SteveR Scale Sailplanes 5 Nov 22, 2011 06:24 AM
