Old Sep 04, 2012, 07:10 AM
axl* is offline
Find More Posts by axl*
Germany, Berlin
Joined May 2005
Hi Steve.
The joke is, there is no extraweight. All the usual lead in the nose was replaced by the electric components. Only 30 lb over all.
axl* is offline Find More Posts by axl*
Old Sep 04, 2012, 07:33 AM
SteveR is offline
Find More Posts by SteveR
New York
Joined Feb 2002
Hi Axl*
Excellent!
Do you recall what brand of electric motor you are using and the model number. Any vibration issues with the prop extension?
Also, have you heard of any wing failures from the German pilots?
Regards,
Steve
SteveR is offline Find More Posts by SteveR
Old Sep 04, 2012, 09:39 AM
SZD16 is offline
Find More Posts by SZD16
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
30lbs. ?? Mine non-electric one is 35 lbs......how in the heck did you lose 5 lbs?
SZD16 is offline Find More Posts by SZD16
Old Sep 04, 2012, 11:37 AM
k2k is offline
k2k
Find More Posts by k2k
k2k
k2k's Avatar
United States, CA, Oceanside
Joined May 2003
Here is the Mikey load test on Dans Ka-8 yesterday. There is a small spot of Ultracote that will never be the same. Dan put about six flights on it which included multiple loops with no problems. Dan decided to beef up the aluminum tubes with a 3/4 diameter chrome-moly steel tube full length insert with 1/16 wall thickness. Each tube was about 2.5# which brings the flying weight up to about 37#. It flew very nicely.
The outer panels seem to be ok. Im going over all of the glue joints in the inner third of the sub spar with some Titebond and inspecting carefully for any flaws. Hopefully any serious problems will show up on the load test.
k2k is offline Find More Posts by k2k
Old Sep 04, 2012, 12:46 PM
SZD16 is offline
TEAM GORGEOUS
SZD16's Avatar
In a house
Joined Sep 2002
So Dan's is unmodified except for the addition of the steel in the joiners?
Old Sep 04, 2012, 01:50 PM
PT Glider is offline
Find More Posts by PT Glider
United States, CA, Carlsbad
Joined Jan 2007
I was a witness to History.
The load test that is......
Mark
PT Glider is offline Find More Posts by PT Glider
Old Sep 04, 2012, 01:53 PM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
Load Test
I don't see them really pulling up too hard on the wings. Funny picture but not a whole lot solace for a guy that is minus his K8B due to wing failure.
See Ya,
Pat
pmccleave is offline Find More Posts by pmccleave
Old Sep 04, 2012, 01:55 PM
AirBornOne is online now
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
Looks like they were a little confused with the 'load' part of the test.
J
AirBornOne is online now Find More Posts by AirBornOne
Old Sep 04, 2012, 02:55 PM
k2k is offline
k2k
k2k
k2k's Avatar
Joined May 2003
Don't take the Mikey load test too seriously.
Dan's wings are unmodified with the exception of sliding the steel tubes inside of the existing aluminum tubes. I suspect that they are not needed for his plane. There was no evidence of main or sub spar damage after his flights. His thought process was that the steel tube might bend but not let go if the spars started to let go. I don't know how well this would really work.
Dan had a nice idea for the nose skid. He bent a piece of 3/16" music wire to shape and fitted it into a groove he cut in the bottom, then glued it into place. It worked very well on the tarmac.
Old Sep 04, 2012, 03:27 PM
SteveR is offline
New York
Joined Feb 2002
K2K, on your mods, did you rework both the top and bottom main spars of the inner wing panels only?
Also, just to be clear, did you start with the 1/32" plywood shear webs at the tip end of the inner panel and worked your way to the root switching over to balsa as you approached the root or was it the other way round?
TIA,
Stefve
Old Sep 04, 2012, 03:28 PM
axl* is offline
Germany, Berlin
Joined May 2005
Originally Posted by SteveR View Post
Hi Axl*
Excellent!
Regards,
Steve
Hi Steve.
Its a Torcman TM430-40 Triton F3A
http://torcman.de/motoren/tm430/NT430-40_h.jpg
Here is my special manufacturing
Good cooling is necessary!
No vibrations with this very good shaft and the ball bearing in the nose. Well balanced prop too.
One guy crashed his Ka 8 but I think he has done some aerobatics. ARF always has some risk of bad finish.
Regards
Axel
Old Sep 04, 2012, 03:31 PM
axl* is offline
Germany, Berlin
Joined May 2005
I think 13,8KG are 30lbs?
No probs with the structure here:
Ka 8 Tragfläche Test.mp4 (0 min 21 sec)
Old Sep 04, 2012, 04:30 PM
flyingfever is offline
Find More Posts by flyingfever
Joined Jul 2009
steel tubes
Did the steel tubes extend past the stock alum. ones, full length? How did he join or secure the 3/4" tubes inside the 1 1/4 alum ones? Thanks.
flyingfever is offline Find More Posts by flyingfever
Old Sep 04, 2012, 05:59 PM
Sailhigh is offline
Find More Posts by Sailhigh
High Lift Coefficient
Sailhigh's Avatar
SF Bay Area, USA
Joined Feb 2003
Nice mount for that motor axl*.
Sailhigh is offline Find More Posts by Sailhigh
Old Sep 04, 2012, 09:19 PM
Joined Jul 2009
Hopefully here are some pictures of my electric install and other mods. Wanted ample power to launch from short fields, so installed a 160 series (63mm dia) outrunner, 2700 watt, 70 amp, 10 cell, 24 lbs. static thrust with Graupner 20x11 folding prop. Also wanted the installation, along with spruce & ply stiffeners, to add considerable strengh to handle the power.
Alert Phoenix 6 Meter K8 One Time Special Order SteveR Scale Sailplanes 393 Jul 19, 2012 07:40 PM
Discussion PHOENIX Evolution 2.6 dougind Electric Sailplanes 1 Jun 16, 2012 08:40 AM
For Sale Hitech Eclipse tranmitter and 8 Receivers on 6 meters for sale or trade. model medic Aircraft - General - Radio Equipment (FS/W) 0 Apr 02, 2012 08:06 AM
Alert Last Call for the Phoenix 6 Meter K8 Sailplane SteveR Scale Sailplanes 5 Nov 22, 2011 06:24 AM
