Old Jun 30, 2012, 08:53 PM
josh18 is offline
Find More Posts by josh18
608 km/h!
josh18's Avatar
Australia, QLD, Toowoomba
Joined Jan 2010
Sorry guys, what is Longditudinal dihedral? Is this decalage or something different?
josh18 is offline Find More Posts by josh18
Old Jun 30, 2012, 09:41 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Decalage traditionally refers to angle difference between the two wings on a bi-plane. Longitudinal dihedral is the angle difference between the wing and the tail plane.
So if the wing was +0.5 degrees to the datum line of the fuse and the stab is at -0.25 degrees the longitudinal dihedral would +0.75 degrees.
The word "decalage" has become widely used in place of longitudinal dihedral....so use whatever you want.
wyowindworks is offline Find More Posts by wyowindworks
Old Jun 30, 2012, 09:47 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
i'll change the wings Dihedral to 1 degree and leave it at that....
Posted from the Dreamfactory
Keenan
Keenan smith is offline Find More Posts by Keenan smith
Old Jun 30, 2012, 10:12 PM
Just fly it!
Cody, WY
Joined Nov 2007
Keenan
For a DS plane you are better off putting the wing and zero and the tail plane at -1*.
Many people put them at 0 - 0......0 degrees longitudinal dihedral and then use elevator trim to trim the plane.
To optimize the rigging you want to first calculate the planned DS speed objective, then calculate the circle circumference for your site. Using this you can calculate the g-load on the wing for your approximated glider mass. Using this you can calculate the required CL (lift coefficient) of the wing. Then using your air foil and planform you calculate what AoA the wing must be at to generate the required CL. The wing would be put at this angle compared to the zero lift line of the fuse. The pitching moment of the wing at this CL would be calculated and the stab would be positioned at the correct AoA to counter the pitching moment of the wing (this is variable depending on the CG).
In the end the whole calculation is an approximation because changing the CG or ballast would change the optimum rigging.
Old Jul 01, 2012, 12:10 AM
Aerogance is offline
Find More Posts by Aerogance
Anyone can build! It's fun!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
You will most likely have to shim your stab after a few test flights to get it perfect, unless of course your calculations are perfect!
Aerogance is offline Find More Posts by Aerogance
Old Jul 01, 2012, 01:48 AM
josh18 is offline
608 km/h!
josh18's Avatar
Joined Jan 2010
Was going to say the same thing!
Thanks Adam
Old Jul 01, 2012, 08:28 AM
Joined Dec 2010
Okey doke ...
Old Sep 20, 2012, 09:53 AM
Joined Dec 2010
Well ive been away from this project a While.. and now im finally getting back to work on the Raptor
i have attached some images of the fuse plug... (not completed yet.. )
I will Continue work on the Raptor On Saturday When i will Be hotwiring the Wings
K
Old Oct 08, 2012, 04:30 PM
alfa166 is offline
Find More Posts by alfa166
100% crasher
Sverige, Skåne Län, Hässleholm
Joined Sep 2011
progress??
alfa166 is offline Find More Posts by alfa166
Old Oct 10, 2012, 05:22 AM
Joined Dec 2010
Not currently as I have been busy ....
Build Log Build log PIK-12 Gabriel, 1:3,2 (5m) tuootal Scale Sailplanes 18 Jun 11, 2012 03:47 PM
Mini-Review Soaring USA bag for Explorer 4.0 Hoot Multi Task F3X 7 Jun 21, 2011 01:48 PM
Build Log Raptor GS Version 2 Build log metroidrc Scratchbuilt Indoor and Micro Models 8 Apr 14, 2010 11:10 AM
