Old Jun 27, 2012, 12:36 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Build Log
Raptor 2.0 A real Dyna-Soar...... 2M bagged DS'er build Log
Hi im currently in the Process of Designing a 2m DS Ship in Cad For light to medium DS ...called the Raptor 2.0
You may notice the Trileronss on the Ailerons to Reduce Tip Vortices...
it Uses A Thinned RG-14 Foil and i am aiming for an AUW of 1.5-3Kg...RTF With Full ballast and 800g no ballast
i Plan to Use a T-tail ... Though i am unsure on Rudder size?
any Help?
Let me know your Thoughts?
Posted from the Dreamfactory...
Keenan
Keenan smith is offline Find More Posts by Keenan smith
Old Jun 27, 2012, 02:22 PM
Aerogance is offline
Find More Posts by Aerogance
I can't fly .55
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
Keenan,
Looks like a fun project, all the best. As for thinning the RG14, I would say that for DS at medium speed it would not be necessary and may be detrimental in some respects. Since you have CAD software, I would suggest test fitting your spar/shear and servos of choice to make sure your T/C will fit them where desired. You may end up rethinking how thin you go with the wing based on the need for improved servos for DS.
T-Tails are easy to build and have fewer parts to mould/build, so that is a no brainer. As for a rudder, its not needed for DS, so if you add one it won't help your DSing.
Aerogance is offline Find More Posts by Aerogance
Old Jun 27, 2012, 05:01 PM
Joined Dec 2010
More Cad Work Done..
I Have Designed The Fuselage, the Vert stab and the Horizontal stab ... also i have drawn in the Servo pockets....
My List Goes ....
Order parts and Composites (1K Carbon Cloth,Medium Wieght Glass Cloth and Some Depron For Servo Pockets And Wire Channels...
Draw Top view of fuselage so i can Generate the Cross sections..
Loft the Fuselage and Wing In 3D
Build up moulds in 3D
Build the Damn Thing
And Hope this Thing Goes like the Clappers...
BTW anybody Got any advice on Wing Fillets or Should i just leave those out...?
Posted From the Dreamfactory...
Keenan
Old Jun 27, 2012, 05:41 PM
Rhys Porter is offline
Find More Posts by Rhys Porter
Planes dress doors...
Rhys Porter's Avatar
Australia, QLD, Kippa-Ring
Joined Mar 2011
That thing's going to pull up QUICK with those flaps haha. I don't know of any DS models with the flaps that big (or ailerons that small for that matter)
Can't wait to see the elevator with trilerons (Or should it be called a trilevator)
Rhys Porter is offline Find More Posts by Rhys Porter
Old Jun 27, 2012, 05:50 PM
Joined Dec 2010
Thanks Rhys... Lol
ill only mix a Lil snap Flaps
and for Roll Control the Flaps Will Act as Ailerons Also .. To Aid Rolling about that Axis...
Im Planning For A Carbon D-box Kinda Thing and If all Goes Well i'll Build A few and Sell them... What Do you think of the Looks?
little Surface + Big Movements = High Drag!
Bigger Surface + SMall movements - Low Drag!
Well I'm A Big! Fan of concepts and Designing the Rought Shape of a Model By how Cool It Looks.. Lol
im aall about Reducing Induced Drag And Knowing How trilerons Reduce Vortices Coming off of Ailerons Then Why Should'nt it Work for an Elevator...? Well Theres only One WayTo Find out ....
Posted From The Dreamfactory
Keenan
Old Jun 27, 2012, 10:20 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Nice. subscribed.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jun 28, 2012, 08:13 AM
Joined Dec 2010
Thanks Rich
Keenan
Old Jun 28, 2012, 09:36 AM
Joined Dec 2010
and more work done
This Thing s Gonna Pull up Real Quick! Look at the Tail Moment! (call for Expo....)
any Ideas on an Easily Visible Mean Paint-job...?
Old Jun 28, 2012, 12:18 PM
Crash Prone is offline
Find More Posts by Crash Prone
Crash Prone's Avatar
United States, WA, Port Orchard
Joined Feb 2011
Keenan, have you ever finished a plane?
Crash Prone is offline Find More Posts by Crash Prone
Old Jun 28, 2012, 12:35 PM
Joined Dec 2010
Yeah my ISIS
Old Jun 28, 2012, 01:15 PM
dsman is offline
Find More Posts by dsman
More like crunchman....
dsman's Avatar
United Kingdom, Cheshire East
Joined Mar 2007
Keenan,
Great to see another DS project starting in UK.
But before committing, why not have a word with a few other UK DSers currently involved in design/build?
It might shift your priorities.
Aerogance has already drawn attention to rudder & profile issues.
Perhaps speak with e.g. Hobster & Will Deighton.
Just my 2p.
dsman is offline Find More Posts by dsman
Old Jun 28, 2012, 02:28 PM
Joined Dec 2010
Thanks DS man ... Ive looked up those Fella's And i found this thread....http://www.rcgroups.com/forums/showt...7893&page=4.so also im gonna try and get in touch with E'm i probably going to mould the proto and make some Solid core Mouldies... in Bias layed 3k Carbon Yay!
PPs when i said rudder I Meant the Vertical stabilizer.....
Posted Form the Dreamfactory.....
Keenan
Old Jun 28, 2012, 02:45 PM
Joined Dec 2010
Today i check out the Sailplane Calc and i got these results
The CG is at 103.36mm from the LE
and the Wing area id 36dm2
the wingloading is at 3Kg AUW 97.49gr/dm2
what do you guys think? (i think ill need to lighten this baby up...)
Old Jun 28, 2012, 02:50 PM
dsman is offline
dsman's Avatar
Joined Mar 2007
[QUOTE......
Posted Form the Dramfactory.....
Keenan[/QUOTE]
Perhaps give the whisky a miss at the design stage?
Old Jun 28, 2012, 02:55 PM
Joined Dec 2010
Originally Posted by dsman View Post
......Posted Form the Dramfactory.....
Keenan
Lol im Only 14..... But build is what i do .. and the Dreamfactory is the name of my Company
Posted from the Dreamfactory.....
Keenan
Btw do you think i should thinout the Top profile of The Rear fuselage ?
Maybe i'll MAiden this Thing at your Spot...
Build Log Build log PIK-12 Gabriel, 1:3,2 (5m) tuootal Scale Sailplanes 18 Jun 11, 2012 03:47 PM
Mini-Review Soaring USA bag for Explorer 4.0 Hoot Multi Task F3X 7 Jun 21, 2011 01:48 PM
Build Log Raptor GS Version 2 Build log metroidrc Scratchbuilt Indoor and Micro Models 8 Apr 14, 2010 11:10 AM
