Old Jun 27, 2012, 09:44 AM
joseico90 is online now
Find More Posts by joseico90
Lets break some props :D
joseico90's Avatar
United Kingdom, Liverpool
Joined Jun 2008
Build Log
28" Twin Prop Nutball with Photos and Videos
I got motivated to build a Twin Nutball after making a 10" version with the guts of a toy plane. I got it to fly good, then decided to build a "proper" bigger version with full control.
Maiden Flight
Twin Nutball 1st Flight (3 min 2 sec)
Folowing flight with new motors
28" Twin Pusher Nutball (4 min 4 sec)
Best flights, (almost finished model)
Twin Nutball take 2 (2 min 42 sec)
28" Twin Nutball 27/04/13 (8 min 41 sec)
This is the little one that started it all
Mini Nutball.wmv (2 min 7 sec)
On Board Camera (HD)
28" Twin NB doing some high alpha flying (1 min 2 sec)
Check my YouTube channel for more clips.
joseico90 is online now Find More Posts by joseico90
Old Jun 27, 2012, 09:58 AM
joseico90's Avatar
Joined Jun 2008
The project
More than anything, really, the reason to start this log is to keep me motivated and finish the project, as well as sharing with the RC community here.
-Basic info;
-28 inches diameter
-2x 2050KV motors on 8" Contra Rotary props
-Differential throttle control (mixes done on the TX)
-Will have landing gear,
-I'm using 6mm Depron and some 3mm ply to reinforce certain areas.
-Here are some pics of the project so far,
Old Jun 27, 2012, 10:09 AM
joseico90's Avatar
Joined Jun 2008
diff throttle test
In this clip I'm testing the mix for the first time, I've done some more fine tuning since to the rudder to throttles mix, (applying some Expo and reducing rate)
I'm using Channels 3 and 5 for throttle outputs, Ch3 mixed with 5 100% and then both have a mix with rudder.
My TX is a much modified Fly sky FS-TH9X, (Mode 2), running the awesome ER9X firmware, with an internal FrSky DHT 8ch DIY Telemetry Compatible Transmitter Module, and a FrSky D6FR RX.
28" Twin NB motors first test. (0 min 47 sec)
Old Jun 27, 2012, 10:27 AM
fuzzydog is offline
Find More Posts by fuzzydog
Canada, BC, Williams Lake
Joined Jan 2011
Thanks for posting this thread. I also am looking to build a twin engine nutball, but I don't think I can do throttle differential with my Futaba 7cap so I was going with rudder control
Looking forward to the rest of your build and flights.
fuzzydog is offline Find More Posts by fuzzydog
Old Jun 27, 2012, 10:32 AM
joseico90's Avatar
Joined Jun 2008
Thank you
I've seen some people using V tail mixers for diff throttle, see here,
http://www.rcgroups.com/forums/showthread.php?t=1124466
Old Jun 27, 2012, 11:14 AM
fuzzydog is offline
Joined Jan 2011
thanks for that link - I'm pretty sure my 7CAP can do vtail - will have to look into it when I have some time
Old Jun 27, 2012, 02:36 PM
joseico90's Avatar
Joined Jun 2008
Cool
Old Jun 28, 2012, 10:03 AM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
OK, I won't make any jokes about short propellers. This thing is way cool! Fun to watch it develop.
potshot is offline Find More Posts by potshot
Old Jun 28, 2012, 10:15 AM
joseico90's Avatar
Joined Jun 2008
Nah John, they're a new type..invisible props haha..
Old Jun 28, 2012, 10:21 AM
joseico90's Avatar
Joined Jun 2008
Compared with the 22" the new 28" one doesn't seem that much bigger.
Old Jun 28, 2012, 11:29 AM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
Those twin rudders look great with the twin motors, I'm going to have to do a micro version of this.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Jun 28, 2012, 11:53 AM
joseico90's Avatar
Joined Jun 2008
fabricating the landing gear (10AWG piano wire and 70mm wheels)
Old Jun 28, 2012, 01:14 PM
joseico90's Avatar
Joined Jun 2008
TODD
go on then! or i might beat you to it.. I'm waiting for some 5gr motors!
Old Jun 28, 2012, 04:53 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
I have some 3gr motors, but I'll have to wait till I destroy a plane first for the electrics.
It took a lot of searching till I finally found some 3'' and 4'' CR-props. I have a few 5gr motors and they seem to run best on a 5'' prop.(2000kv)
TODD
For Sale 4 -New NTM Prop Drive Series 28-26A 1200kv Chad2323 Aircraft - Electric - Multirotor (FS/W) 1 Nov 29, 2012 11:12 AM
Discussion UM T-28 prop hard to turn after flight only Justin325 Scratchbuilt Indoor and Micro Models 11 Jun 20, 2012 05:58 PM
Discussion Photos & Video - including a Midair - SEFF 2012 - add your SEFF photos & videos kevinhines SEFF 2012 16 May 09, 2012 09:56 PM
Discussion Photo cam with video vs dedicated video cam tumad Aerial Photography 0 Feb 18, 2012 08:08 AM
28" Scout with "Little Twins" Warren Jones Scale Kit/Scratch Built 2 Feb 06, 2003 09:27 PM
