Old Aug 10, 2012, 10:00 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
pretty simple. when cells are connected in parallel they start balancing immediately whether a charger is connected or not. generally takes a matter of minutes for higher charge cells to bring up the lower ones. after a while the lower will be higher and the higher will end up lower. when connected to a charger it sees them as one cell and proceeds to bring them all up to full.
one big misunderstaning is that they all have to be same charge state or capacity. this is not true and, as i mentioned in the other thread, even less of an issue with our small lipos.
dave1993 is offline Find More Posts by dave1993
Old Aug 10, 2012, 10:05 AM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
But the circuit is "open", so the confusion. Does this mean that electrons will flow from one cell to the other in such an open circuit?
FyreSG is offline Find More Posts by FyreSG
Old Aug 10, 2012, 10:28 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
the circuit is definitely not open. as long as there is wire between all the positive (red) and between all negative (black) the circuit is closed. if you are suggesting we should connect + to - in order to charge that is not a good idea:
Old Aug 10, 2012, 10:43 AM
Brandigan is offline
Find More Posts by Brandigan
Joined Jun 2012
Originally Posted by cgpirre View Post
This has been bothering me for a while... How do they 'balance' if only the cables of the same color are connected to each other? Or do you plug in the banana connectors, and start the charging process 10 minutes later?
I'm not convinced of this 'auto balancing' that goes on, and if it worked as explained, it would be a bad idea to connect a full and a flat battery together, as the full one would immediately discharge at 12-15c into the flat one that only likes to be charged at 1c. Bang!
So...pass.
The closest I have seen to something useful is this http://www.ebay.co.uk/itm/180949028840 to charge Walkera batteries using a balance charger. Plug in multiple batteries and the charger will treat them as separate cells of a multi-celled battery - and not overcharge the full ones - and stop when they're all done.
I'm sure it could be modified to stick JST sockets on the end, or maybe someone sells something already, I just haven't found it.
Brandigan is offline Find More Posts by Brandigan
Reply With Quote  (Disabled)
Old Aug 10, 2012, 10:52 AM
erdnuckel2 is online now
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
So...pass.
I am using this for ages now to charge my batteries ... the ones for my walkeras, for the msr, for the mcpx and for the 120SR (in which case I use the charge harness for the msr batteries and some adapters that Horizon Hobby sells)
You can even use two of them and charge 6 batteries at a time as a 6S battery - by using one additional 6S to 2x3S adapter (about another 4$)
I do this because I like to SEE the readouts of the charge data.
(Unfortunately whenever I write that I use this, there is IMMEDIATELY one of the parallelcharging promoters who tells whoever asked that parallel charging is soooo much better and all the stuff about it is a modern myth (the questions and negative ideas some people harbor) and makes my post drown and be forgotten (not that I really care, I am just sad because it tends to zone out information that might actually feel useful to some readers ...
EDIT:
oh, and just to be clear, my "critique" at the "parallelcharging promoters" does NOT in any way refer to a specific person/member !!!
erdnuckel2 is online now Find More Posts by erdnuckel2
Old Aug 10, 2012, 10:53 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
So...pass.
since you believe that connecting 2 batteries together can have different voltages then not too surprising you subscribe to the "must be similar charge" theory.
Old Aug 10, 2012, 10:56 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
EDIT:
lol!
Old Aug 10, 2012, 11:09 AM
shafter is offline
Find More Posts by shafter
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
Maybe wikipedia will help ?
http://en.wikipedia.org/wiki/Series_...rcuits#Voltage
Parallel circuits
If two or more components are connected in parallel they have the same potential difference (voltage) across their ends. The potential differences across the components are the same in magnitude, and they also have identical polarities. The same voltage is applicable to all circuit components connected in parallel. The total current is the sum of the currents through the individual components, in accordance with Kirchhoff’s current law.
Voltage
In a parallel circuit the voltage is the same for all elements.
Originally Posted by Julez View Post
I once connected a fully charged and a fully discharged pack (100% charge difference), and the current was about 2C initially. It became much less after 30s, and after 2 minutes, it was only a couple of hundred mA.
With a max of 50% charge difference, the current should be even lower.
Cheers,
Julian
Regardless of that ... why would you want to connect charged battery to empty one instead of flying it out.
p.s. Sorry for "parallel charging promoting" - this will be my last post ! I promise !
shafter is offline Find More Posts by shafter
Old Aug 10, 2012, 11:11 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
correct-a-mundo!
Old Aug 10, 2012, 11:18 AM
Joined Jun 2012
No, I believe that different batteries connected with different voltages will immediately try and equalise the voltage difference with potentially explosive results.
I also believe that with a proper, balanced charging harness, all the batteries only share the Black lead and the Red leads are separate and each cell is handled individually by the charger.
Old Aug 10, 2012, 11:24 AM
Joined Jun 2012
That was an extreme example to illustrate the potential danger. You could easily have a selection of batteries with 1, 2 or 3 minutes flight still in them, but you don't want to 'fly them out' because it's not worth the effort, so you fly with a full one and put them in the 'to be charged later' pile.
Any difference between the batteries will immediately be equalised according to the link you supplied above (which doesn't apply to batteries, by the way, because they are supplying the voltage, but will attempt to make the voltages the same) and unless they are very close in voltage, the speed of equalisation could easily exceed the 1C they want to be charged at.
It's like putting 5A into one instead of 0.5A if that makes it any easier to understand.
OK, try this thought experiment.
One flat battery is connected to one full battery as described previously.
How quickly do they "equalise" to half charge?
If it takes 1 hour for one battery to be charged from flat to full, how many seconds to go from flat or full to half charged is too fast?
Old Aug 10, 2012, 11:25 AM
cgpirre is offline
Find More Posts by cgpirre
cgpirre's Avatar
Belgium
Joined Dec 2011
Sorry Dave, but I still don't get it...
So you're saying that if I were to connect 5 batteries to a JST charging harness, which just bundles all red together, and all black together, they would balance each other out, even though the 'charging' end is still open? Like in the attached picture.
How/why?
cgpirre is offline Find More Posts by cgpirre
Old Aug 10, 2012, 11:33 AM
shafter is offline
Joined Jan 2012
Originally Posted by Brandigan;22409958
[I
Any[/I] difference between the batteries will immediately be equalised according to the link you supplied above (which doesn't apply to batteries, by the way, because they are supplying the voltage, but will attempt to make the voltages the same) and unless they are very close in voltage, the speed of equalisation could easily exceed the 1C they want to be charged at.
Read Julez post i quoted in above, current flowing between empty and fully charged pack was only 2C !
If you want to charge using series harness and multiplied voltage (that's how bigger 2S-6S packs are built):
Beware of that: (source: https://sites.google.com/site/tjingu...erial-charging)
All the packs you charge in series must be the same capacity. For example you could charge a 3s 2200mAh lipo, a 2s 2200mAh lipo and a 4s 2200 mAh lipo in series together, but you can not charge a 3s 2200mAh lipo in series with a 3s 3200mAh lipo.
All the packs to be charged in series together need to be very close to the same voltage per cell. If I had to put a number on it I would say within .05V per cell.
Serial charging is best suited for someone looking to charge flight packs made up of pairs of packs like 2x 3s 2200mAh packs used in a 500 sized heli.
It's just not the correct solution for our small 1S cells
Old Aug 10, 2012, 11:44 AM
Joined Jun 2012
That 2C cannot be correct unless it took 1/2 the time to equalise that it would have taken to charge at 1C.
So if a 1C charge takes 1 hour, a 2C discharge takes 1/2 hour. How is that even useful to wait for half an hour to equalise the batteries before you can start charging them?
The proper harness is exactly the solution to the problem with similar 1 cell batteries, as is explained in the quote.
Just don't mix a 500mAH with a 600mAH in the same charging harness because the charging current needs to be correct for all of them to be @1C.
I have 3s batteries where some of the cells are slower to charge than others as they've got older. So the charger quickly charges up the faster cells then the last one is a bit slower, but it stops charging the full ones. This is exactly the same as if you have a selection of single celled batteries of different ages but identical specs (600mAH, 500mAh etc), where they only share Black, and Red is individual for each battery in the harness.
Old Aug 10, 2012, 11:52 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
How/why?
i see where the confusion arises. youre looking at it like there is a difference between charger and cell when in fact for parallel there is no difference. some of the batteries becomes the charger. in other words high voltage cells are chargers and low voltage ones are "chargees". you always connect charger positive to battery positive. never the othe way around (i hope). so a parallel pack (+ to +, - to -) equializes because high voltage cells are the chargers for the low voltage ones.
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 01:57 AM
New Product WLToys Ladybird Large BRF$30; RTF$39 lao Micro Helis 7 Jun 02, 2012 10:22 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 08:48 AM
