Old Dec 08, 2012, 02:44 PM
United States, TN, Knoxville
Joined Jun 2012
Carry on, good quadonaut.
variantman is offline Find More Posts by variantman
Old Dec 08, 2012, 02:46 PM
South Africa, GP, Johannesburg
Joined Dec 2011
Haha.... At some point I may loose it..
ArchillesElbow is offline Find More Posts by ArchillesElbow
Old Dec 08, 2012, 03:46 PM
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
All is needed now is a machine gun and its Call of duty time!!!
chester2240 is offline Find More Posts by chester2240
Old Dec 08, 2012, 03:50 PM
Joined Dec 2011
Chester that was with the 90deg fov camera
Old Dec 08, 2012, 03:52 PM
I = V/R
Tw34k's Avatar
United States, FL, Jacksonville
Joined Aug 2012
Hello all, I recently purchased a 929 board from a member of the forum here with intentions of building a DIY micro. Today I received the board in the mail and proceeded attempt at binding it to my 9X transmitter using the following procedure.
Power up 929 board using 3.8v from adjustable bench supply.
Power on 9X TX while holding bind button.
Power cycle both devices.
Upon powering up the 929 board it seems to turn on the motor outputs for ~4-5 seconds then once 'connected' to the radio the motors turn off and the light becomes solid. After this strange boot up pattern I can no longer get any of the motors to spin via throttle from the TX.
I have my channel setup with the throttle reversed and in AETR assignment as instructed by this thread
http://www.rcgroups.com/forums/showthread.php?t=1707525
And here is a short clip to describe my problem, any ideas on what I'm doing wrong or is this a faulty board?
929 w er9x troubleshooting (0 min 31 sec)
Tw34k is offline Find More Posts by Tw34k
Old Dec 08, 2012, 03:59 PM
Joined Dec 2011
I can't see clearly.. I that a 4plug or 8plug version?
Old Dec 08, 2012, 04:03 PM
I = V/R
Tw34k's Avatar
Joined Aug 2012
8 plug
JR-WL-FD02R-1 Rev 02 2012/07/30
Edit: I'm having a hard time finding any sort of instructions for these boards.
Old Dec 08, 2012, 04:04 PM
Ain't crashing often anymore
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
8 plug
-mike-
Edit: too slow...
mikefromgermany is offline Find More Posts by mikefromgermany
Old Dec 08, 2012, 04:20 PM
Joined Dec 2011
U probably have the motor plugged into the wrong plug.. Move it to the plug furthest away from the edge where two plugs are in parallel
In your pic.. Each of the plugs with a black rim is the motor plugs.. The other ones are for led lights
Old Dec 08, 2012, 04:32 PM
I = V/R
Tw34k's Avatar
Joined Aug 2012
LOL, I feel silly, I was just coming back to post these findings myself.
I wound up finding the channels with common poles with my multimeter as you can see from the black marks on the connectors. Obviously at first I thought the outer channels were for the motors and inner for led but after hooking my oscilloscope to a connector from each channel I found it to be the opposite.
Thanks for the help guys, sorry for the silly mistake.
Tested and working!
Old Dec 08, 2012, 06:06 PM
Singapore, Singapore
Joined Dec 2012
This is really awesome! How much has the set up cost you so far? (Including the goggles?) Are you using FatShark Goggles?
perdification is offline Find More Posts by perdification
Old Dec 08, 2012, 08:47 PM
Joined Jul 2011
O 90degree that would be nice my camera is a 40 or 60degree any ways its way to small thats why i was thinking the 110 but if i can find a 90degree lens thats lighter then the 110 ill go that way. So do you know where i can get a 90degree lens?
heres my FPV Transmitter i named it Frankenstein. Im still need to get the frsky telementry screen and shorter cords other then that and a green paint job it will be finished!
Old Dec 08, 2012, 10:38 PM
Joined Dec 2011
What camera are you using? Depending on the camera u will need a differ type of lens...
Just a few things on the transmitter...
I would separate the video ground station from the transmitter for a few reasons...
1) the way the screen is placed right now, you may not have enough space to move your tx antenna to 90 degrees (free of ground reflections) for max tx range.
2) the screen is not shielded from the glare of the sun, and it maybe hard to see the screen.
3) the video rx u are using the 805,has a shortfall In terms of how the board is constructed and there is interference between the video out and the antenna.. The way to solve this is to put the antenna of a short lead... And then connect it to the 805.
4) having the video rx on the transmitter might not allow optimal anetenna placement ...
5) it will make using any other antenna eg a helical much more difficult....
Old Dec 08, 2012, 10:57 PM
Joined Dec 2011
Well as I mentioned before.. The costs are a bit complex since my goal here was to re use the fpv system from my bigger planes.. Without having to buy a micro fpv system.. So the costs can't be attributed just to the v929 fpv quad
However when I bought it:
1) camera ~$29
2) vtx 200mw $20
3) vrx $29
4) goggles - home made from old pair of video goggles..
5). Vtx Antenna custom made
6) vrx antenna home made
U can make up a system for much less btw..
Old Dec 08, 2012, 11:15 PM
Joined Jul 2011
Thanks for the advice i plan on getting FPV googles after christmas, ive tried this setup a few times and liked it but ill take your advice about making a screen to block out the sun glare and the shortfall of the 805. About the rx what do you mean about a sortfall and putting the antenna off a short lead (im new to the FPV talk)?
I stand instead of sit when i fly FPV and i tilt the monitor slightly forward so the tx antena is around 70dergees and the rx antenna is around 50degrees.
The camera im using is this http://fpvhobby.com/94-8ghz-10mw-camera.html it has a decent range about an american football field 300feet
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5130 May 16, 2013 07:52 AM
New Product WLToys Ladybird Large BRF$30; RTF$39 lao Micro Helis 7 Jun 02, 2012 10:22 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 08:48 AM
