Old Nov 21, 2012, 11:39 AM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
replace cheapo fc with Zero YS-X4. and $2 pagers with d70 brushless. lol! actually my stock v929 will go out to limit of the radio and eyesight and back. about 1200'. i didnt time it though.
dave1993 is offline Find More Posts by dave1993
Old Nov 21, 2012, 02:23 PM
ArchillesElbow is offline
Find More Posts by ArchillesElbow
South Africa, GP, Johannesburg
Joined Dec 2011
If I can fly this 400m and back I would be very happy
ArchillesElbow is offline Find More Posts by ArchillesElbow
Old Nov 21, 2012, 02:55 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
the biggest problem is keeping it from flipping when you race forward and then figuring out orientation when turning around. i have a v911 radio with er9x firmware that can be set just below the flip point which helps a lot.
Old Nov 21, 2012, 03:59 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
You mean you can see the quad well enough at 1200 feet (that's 4 football fields stacked back to back) to bring it back? (Did you have binoculars?)
stonecutter is offline Find More Posts by stonecutter
Old Nov 21, 2012, 05:27 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
easy with fpv like archilles mentioned in his post. video range becomes the issue. those tiny vtx dont excel in that area but have been known to go 2km on 10mw. and i did bring up the issue of orientation. turns out not that hard with leds after sun sets though.
Old Nov 21, 2012, 07:54 PM
Joined Dec 2011
Im not too worried about flipping,, as I am using a 9x
I also am not too worried about the video link as I am using a 200mw vtx with specially designed antennas (good for more than 2kms on my plane)..
Funnily enough I'm more worried about altitude (not getting too low but getting too high).. I noticed in the v9292 when flying fpv it can get high very quickly and u can't see it until its too late... Makes it hard to come down...
Old Nov 22, 2012, 01:43 AM
Soul Reaver is offline
Find More Posts by Soul Reaver
Joined Jul 2012
Hi Achilles.
I saw your project when you were still trying to keep weight low.
Did you post anywhere details on it now that it's finished and working?
I'm starting to do the same.
Thanks.
Soul Reaver is offline Find More Posts by Soul Reaver
Old Nov 22, 2012, 12:19 PM
Joined Dec 2011
The current configuration is as follows:
V929 v1r2 08/06
Gws props
600mah turnigy battery
200mw vtx from foxtech
10g CMOS camera
Custom long range antenna
Custom connectors
150mah 1s fpv battery.
Auw is 83g including all batteries and mounts. Flight time is 8:30, of stable hands free flight. This was the objective..
When I started the auw was 106g! It did not fly well.
I started shaving weight off the quad and the fpv system, and ended up bringing it down to 83g. I can probably pull of another gram or so.
I managed to pull of close 15 or 16 grams of the quad and the rest off the fpv system.
I pulled of weight from the quad as follows:
No canopy
No motor holding mounts
No landing gear, replaced with lighter plastic stilts
Removed 2 screws of the board
Removed all plastic plugs on the board
Removed heavier wiring and replaced with lighter gauge wire soldered directly on the board.
Removed battery holder and replaced with Velcro
Removed bracing struts from the main frame.
Removed the circular plastic in the main frame on two sides (the other sides are used to mount camera and vtx)
Shaved motor arms of all excess plastic.
I'll post pics as soon as I can get them off my phone
Old Nov 22, 2012, 01:32 PM
Joined Jul 2012
Thanks. I look forward to see pictures. I have to choose between 929 and 949 for fpv. 949 looks more stable and has less wobbling.
How long does the 150 battery last? I was thinking about a 100mAh battery.
Old Nov 22, 2012, 01:40 PM
Sir Crashalot
Joined Oct 2011
Archilles, you flying with goggles? Or a monitor you bring to the field?
Old Nov 22, 2012, 01:44 PM
Joined Dec 2011
Both... Actually.. The monitor for others to watch
Old Nov 22, 2012, 01:46 PM
Joined Dec 2011
From the reviews.. It seems the v949 is better than the equivalent 8plug board... Not sure how the older boards compare to the v949 tho... The v929 does not wobble now... Especially with the gws props..
The 150mah lasts long enough .. Around 15mins... A 100mah would do fine
Old Nov 22, 2012, 04:29 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Dave,
Am I understanding correctly that you loaded some modified er9x firmware on a V911 Tx?
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Nov 22, 2012, 04:31 PM
Sir Crashalot
Joined Oct 2011
Archilles do you have a sample of the video output from your fpv for us to look at? What is the approx. cost of the fpv set up? (Sorry if that's been answered previously.)
Old Nov 22, 2012, 04:43 PM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Originally Posted by jesolins View Post
Hi Dave,
Cheers,
Jim
That's what David did : http://www.rcgroups.com/forums/showthread.php?t=1631369
mystman is offline Find More Posts by mystman
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 01:57 AM
New Product WLToys Ladybird Large BRF$30; RTF$39 lao Micro Helis 7 Jun 02, 2012 10:22 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 08:48 AM
