Old Nov 15, 2012, 06:58 AM
BleedingHeart is offline
Find More Posts by BleedingHeart
Joined Nov 2012
Received mine today and i have a problem. The ladybird is always flying left if i only want to try to hover. I cannot fix this with trim buttons ...
Anyone an idea?
BleedingHeart is offline Find More Posts by BleedingHeart
Old Nov 15, 2012, 07:08 AM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
Do you have all the trims at their central point before binding your V929?
scotsoft is offline Find More Posts by scotsoft
Old Nov 15, 2012, 07:12 AM
nsa666 is offline
Find More Posts by nsa666
Joined Oct 2012
V929 Quadrocopter mit Cam (2 min 52 sec)
nsa666 is offline Find More Posts by nsa666
Old Nov 15, 2012, 12:06 PM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
I have had Two V929's for over four months now on stock batteries. Both still work fine but have several new nano-tech 600ma. and put one in my bird. Flight went well and feel just a tad more power, but nothing great. Works fine and check these nano techs out. I bought them for these V929's and my S/P 328. New batteries are longer but made no difference in balance.
dankar04 is online now Find More Posts by dankar04
Old Nov 15, 2012, 01:44 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
My experiences with the Nano-tech 600's are similar. Also, I've found that the black end caps (protecting the internal battery leads) come off easily, almost as if they were not glued at all.
stonecutter is offline Find More Posts by stonecutter
Old Nov 15, 2012, 08:37 PM
AUTO_XX is offline
Find More Posts by AUTO_XX
Canada, AB, Division No. 6
Joined May 2012
I have bought 20 of the 929s and one of the 939 (most recent) but the 939 wants to flip regardless of the sensitivity or if the battery gets below 3.6v... It also doesn't have 10% of the stability of the 929
The 929s have all been very stable and I have sold them to friends (at my cost).
Everyone picks them up easily too
My favorite one to fly is still my 2nd one (I wore the bearings out of the 1st) and it is an 8 connector "JR-WL-FD02R-1". I have taught 8 people how to fly with this one, replaced all of he booms at least once (Just use 3mm square CF tube) and it handles CRAZY wind. It flew fine in ~20km/h wind that it would barely make progress in.
I also tried a 1200mah battery in it, it works but was sluggish and a pain to change the battery out.
AUTO_XX is offline Find More Posts by AUTO_XX
Old Nov 15, 2012, 11:16 PM
Sir Crashalot
Joined Oct 2011
The instability of the v939 could be due to inadequate battery. Stock batts are known to be weak right out of the box. I switched to Nano-tech's and it flies much better with those.
Old Nov 16, 2012, 01:50 AM
AUTO_XX is offline
Joined May 2012
Very accurate info, thanks.
I have been using the 600mah tiger batteries (I still have ~15 of them) and it doesn't flip as often now but the thing is still squirrely as hell.
The 929s look like they are tied to something...
I just waterproofed my electronics on the big tricopter so I'm not stuck inside anymore
Old Nov 16, 2012, 02:31 AM
Joined Nov 2012
Yes. I changed the battery and now a new behavior. I only want to fly up with the left stick, but the ladybird is also flying forward, so that he is getting on his head ...
Someone an idea ?
Old Nov 16, 2012, 02:40 AM
Heli Pad is offline
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Someone an idea ?
Welcome to RCG. I read both of your posts, but the descriptions were vague and didn't give us much to go on.
In general, changing a battery should not change the flight characteristics. So, I'm guessing that either your quad is not initialized properly, or there is a mechanical failure. Let's check the easy one first and make sure that it is properly initialized. By that, I mean the on board gyro has to have a good reference. As soon as you connect the battery, you want to quickly set the quad down on a flat surface, so that the gyro could establish what is "level".
If your quad still keep veering to one direction, you may have a bad motor or a bad blade. Check the one in the same direction that the quad veers to.
When you said, "he is getting on his head," did you mean that the quad flipped over? If so, there is a serious problem with 1-2 motors or rotors. Could you share a video of it with us. That would tell us a lot more than words.
Heli Pad is offline Find More Posts by Heli Pad
Old Nov 16, 2012, 02:58 AM
Joined Nov 2012
Thank you - i found the solution after your hints! I have to connect the battery on the ground and then its properly initialized.
Do you know where i can get a new charger ? The EU stock charger doesnt fit in our sockets here in germany, because its too short. There is only a adapter from US to EU which is long enough to fit, but not when you have the EU charger
As you can see on the image this thing is too short for our sockets, because the pins have to fit in a hole in the socket.
Old Nov 16, 2012, 03:23 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Welcome BleedingHeart!
My stock chargers don't fit also - but I never used them anyway.
Do yourself a favour and get a decent third party charger - it will turn out as the best investment in the hobby you ever did. Promised!
To get not too far to off-topic - you can PM me. (In German )
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Nov 16, 2012, 04:11 AM
midelic is online now
Find More Posts by midelic
midelic's Avatar
Joined Apr 2012
Before you buy new charger go to the closest electrical store and buy an adaptor.It is about 10-20 Euro cents in my country
midelic is online now Find More Posts by midelic
Old Nov 16, 2012, 11:07 AM
Jasen40 is online now
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
My one week old quad is already having motor issues, the rear right motor will not spin up unless flick the blade.The connection to the board is solid.Do you guys think the motor is going out.I hope it is not the board.
Jasen40 is online now Find More Posts by Jasen40
Old Nov 16, 2012, 11:30 AM
Sir Crashalot
Joined Oct 2011
So the quad does not lift off at all (without human intervention)? On mine, not all motors spin up evenly when first applying throttle, but eventually does even out by the gyro.
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 01:57 AM
New Product WLToys Ladybird Large BRF$30; RTF$39 lao Micro Helis 7 Jun 02, 2012 10:22 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 08:48 AM
