Old Nov 13, 2012, 04:26 PM
stonecutter is offline
Find More Posts by stonecutter
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Originally Posted by Heli Pad View Post
Thank you, Stone. That's very interesting. So your V929 replacement RX, which has the same appearance as the V949 RX, has very different behavior. Daryoon's theory was spot on. I, on the other hand, my brain is scrambled by all these different versions of stuff.
Nonetheless, based on your observation, with this replacement RX, we should be able to flip without using the button, and control the lights with the button. At power on, I think the lights would be off. But if you press on the right light switch, the lights could be toggle on/off. Now V929 owners would not have lights to begin with. But it's likely that they could easily add lights with this replacement board.
Whereas, if people like the button control flips, they should stick with the V949. But if they want button-free flips and button control lights, they could drop a V929 replacement Rx (which has the same Rev and everything) into their V949 and get that!
Or, did I mess up again?
That's my understanding exactly.
stonecutter is offline Find More Posts by stonecutter
Old Nov 13, 2012, 08:30 PM
Jasen40 is offline
Find More Posts by Jasen40
United States, CA, San Jose
Joined Jun 2012
My board is same as Stonecutter's.
Jasen40 is offline Find More Posts by Jasen40
Old Nov 13, 2012, 08:54 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Thnx for confirming. So there are rev02 with 8 plugs, made for the v929.
It flips at rates higher than 60% without needing to hold the top right button. (Which we haven't been able to emulate with the T9x.)
Daryoon is offline Find More Posts by Daryoon
Old Nov 14, 2012, 01:11 AM
kosem is offline
Find More Posts by kosem
Former IAF pilot. Retired
kosem's Avatar
France, IdF, Paris
Joined Apr 2012
That's correct Daryoon.
I was one of the first to get a V929 with LEDs (8 connectors) from Hong Kong that flips perfectly at 100% Tx.
The board was called Rev03 though.
kosem is offline Find More Posts by kosem
Old Nov 14, 2012, 01:30 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Is there already something like an overview which different boards exist and what the respective opinion towards them is (including ALL the 4port and 8port boards)??
Is there a listing over 8port boards at all??
for example: I once ordered a spare 929 board and got an 8port board labelled 07/22/2012 - Rev01
Can anybody tell me what the "opininion" on this particular board is (there is no need for me to install it ...)
Old Nov 14, 2012, 01:49 AM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Right kosem. Your's is a unique board. I refer to it as the missing link.
It was a precursor to the Rev02 8plug board.
On the v929 track, we got:
Rev01 (2012-05-12)
Rev02 (2012-06-08)
Rev03 (2012-07-04) 8plug
>reboot revision number
Rev01 (2012-07-22) 8plug
Rev02 (2012-07-30) 8plug
On the v949 track, we got
Rev01 (supposely Aaron got this sample) 8plug
At the reboot, we got the introduction of the v949. Sharing the same RX board, but the firmware is slightly different for each quad.
Old Nov 14, 2012, 02:51 AM
Heli Pad is online now
Find More Posts by Heli Pad
Against Helicopter Cruelty
Heli Pad's Avatar
Joined Aug 2011
Kosem, as Daryoon was saying, yours is one of a kind. Keep it a safe distance away from trees! Treasure it.
BTW, Reboot revision number is from FD02R to FD02R-1 before the Rev number.
I still trying to understand all the subtle differences between versions. It is mighty helpful when you talk about your board, give us the Rev number and or release dates, so we could follow what's going on, and understand why they behave differently. If you're in this thread, we assume that you're talking about your V929, because V949 has a whole different set of behavior. Thanks.
Heli Pad is online now Find More Posts by Heli Pad
Old Nov 14, 2012, 10:46 AM
Jasen40 is offline
Joined Jun 2012
A sample of my three flights with the V929. First attempt the quad just wants to hover; any stick input has almost no effect. Next attempt it will fly pretty nice, if I land it for any reason, on the next attempt it will turn into uncontrollable beast with extreme FFF.
Old Nov 14, 2012, 10:59 AM
FyreSG is offline
Find More Posts by FyreSG
新加坡的飞儿
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
It's raining here for the past few days and the ground is perpetually wet. The moisture affected the gyros of my V939 and V949. Good thing I brought along some paper towels and fixed the annoying drift on the spot.
FyreSG is offline Find More Posts by FyreSG
Old Nov 14, 2012, 12:02 PM
Heli Pad's Avatar
Joined Aug 2011
I am curious. Can anyone explain to me how moisture affects the gyro?
Old Nov 14, 2012, 12:35 PM
Sir Crashalot
Joined Oct 2011
I think the moisture can get into contact with the gyro chip with exposed pins. The gyro is a chip on the belly side, as pointed out by another member (sorry forgot who). So my theory is that wet grass can get the chip wet and possibly cause a temporary short.
I had funky gyro issues when I first got my v929 and flew during early mornings, then I put a plastic bag over the rx and that issue hadn't re-appeared.
Old Nov 14, 2012, 02:29 PM
Makdaddy is offline
Find More Posts by Makdaddy
Doink-not again :)...aka Greg
Makdaddy's Avatar
United States, MI, Sterling Heights
Joined Jul 2012
I read somewhere if you spray varnish on the board it will seal it from water. Being that varnish has been used for years for copper motor windings I believe it will have no effects whats so ever on the board. However, I have not tried it yet so I could be wrong. There are those who have used it somewhere on this forum though.
Note: WAS WARNED TO NOT USE WATER BASE VARNISH.
Makdaddy is offline Find More Posts by Makdaddy
Old Nov 14, 2012, 02:41 PM
Jasen40 is offline
Joined Jun 2012
A while back on one of the Wltoys threads some one post the brake down of the V939 transmitter rates at each level.I cannot find this post.I wanted to use those setting in hopes to find a sweet spot for my 9116tx.With my the two RC cars,Wltoys and Nine Eagles helicopters my desk has to many Txs on it.
Old Nov 14, 2012, 02:45 PM
Makdaddy is offline
Makdaddy's Avatar
Joined Jul 2012
Not sure exactly what you mean but the stock TX uses 20% - 40% - 60% - 100%.
Hope that is what you are looking for
Old Nov 14, 2012, 03:16 PM
Jasen40 is offline
Joined Jun 2012
Thanks for the reply,the post had the value for throttle,elevator,aileron, and ruder.
Example is at 60% aileron was at 70 and the rudder at 80.My reasoning is set at 60% on the V939tx; the V929 was very controllable for me.I would like to plug those values in to the 9116tx.
Update:
I found good setting; I had EPA at 120%, and lowered it to 100%.
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 02:57 AM
New Product WLToys Ladybird Large BRF$30; RTF$39 lao Micro Helis 7 Jun 02, 2012 11:22 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 09:48 AM
