Old Nov 07, 2012, 05:19 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
Originally Posted by stonecutter View Post
My understanding is that for the same C rating, a 600 mAh battery provides twice the current discharge capability as that of a 300 mAh one. So there is a trade that needs to be considered. I just tried both 600 and 300 Nano-Tech's, and with the 300, climb rate is essentially zero, whereas with the 600 it is at least flyable. (Observations are of my old beat up v929, YMMV.)
true higher capacity supplies more current for same c rating by definition. i also get noticeably better performance with 600mah on my v929 but it does fly with 300mah. my v939 size quad flies better with 300mah than it does with 600mah or 138mah but it does fly with both. 138mah is not big enough for the v929 though.
i guess designers chose best battery for a given size. if the quad actually wont lift with half size battery then i suspect either the battery or the motors are on their way out. or maybe im just lucky to get unusually strong cells. they are hk cheapies though so idk.
or maybe our definition of "fly" is different. im pretty happy if i can hover and move from one place to another (easy to please. lol).
dave1993 is offline Find More Posts by dave1993
Old Nov 07, 2012, 08:17 PM
FyreSG is online now
Find More Posts by FyreSG
新加坡的飞儿
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
I found the 600mAh batteries to have more capacity than I what needed. I'm used to swapping batteries at the end of a 5-minute session, and when I check the remaining voltage, it's usually 3.85V or 3.9V. I could enjoy a more agile quad with lighter batteries but not sacrificing on flight time.
As for the possible lower discharge rate i.e. "punch" of the craft when coupled with lower capacity batteries, I'd have to try to find out if it will be an issue.
FyreSG is online now Find More Posts by FyreSG
Old Nov 07, 2012, 08:25 PM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
My MQX will fly for 12 mins..with the 600mah.
Jake8131 is online now Find More Posts by Jake8131
Old Nov 07, 2012, 08:30 PM
新加坡的飞儿
FyreSG's Avatar
Joined Apr 2012
I suppose my V949 will have similar flight times, as at 5 minutes, it still has 3.85V left. But I'm satisfied with 5-minute sessions with some breaks in-between.
Old Nov 07, 2012, 08:37 PM
rocco is offline
Find More Posts by rocco
User?
México, DF, Ciudad de México
Joined Dec 2004
Originally Posted by rexless View Post
I'm considering the same. I find the weight with the 808 camera is a bit annoying and I don't need to fly the camera for more than 3-5m/flight anyway. I have 3 V929's and only one is for video so the other 2 are for long-fun-fast flights.
If you use a 808 keychain camera naked without the hard cover it weights around 9 grams (against 17 with the cover) so the total quad(with foam canopy)+300mah battery+camera weight would be just around 2 to 3 grams more than the original V929 configuration.
rocco is offline Find More Posts by rocco
Old Nov 07, 2012, 08:41 PM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Right now I have one with a cover glued right onto the bottom. It flies ok but like you say there's some extra weight there. I'll probably do one without the cover at some point. Thanks for the measurements!!!
rexless is offline Find More Posts by rexless
Old Nov 08, 2012, 03:07 AM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Indoors, outdoors? Aggressive ore moderate flying ?
I only get 7min if I fly outdoors most the time fff.
mystman is offline Find More Posts by mystman
Old Nov 08, 2012, 01:34 PM
ty_horn is offline
Find More Posts by ty_horn
Philippians 4:13
Seward, NE
Joined Nov 2006
Hey everyone. Is there a link to a cheap FPV system that will work with the 929?
ty_horn is offline Find More Posts by ty_horn
Old Nov 08, 2012, 01:38 PM
skitchen8 is offline
Find More Posts by skitchen8
Addict.
United States, NY, Binghamton
Joined Jul 2010
Afaik everyone that has one has pieced it together from components
skitchen8 is offline Find More Posts by skitchen8
Old Nov 08, 2012, 01:48 PM
mystman is offline
Joined Jan 2012
Haven't tried it myself, but could this be interesting ? http://www.crazyshoppingcart.com/58g...os-p-5615.html
Old Nov 08, 2012, 02:08 PM
ArchillesElbow is offline
Find More Posts by ArchillesElbow
South Africa, GP, Johannesburg
Joined Dec 2011
This is a really low powered system, that can work but will require more work than the component based ones.
On the plus side, the 10mw transmitter here is well filtered and usually with a proper regulator attached u can get away with using just one battery for flight and for video...(which you can't do in the more high powered systems).
I recently posted on my fpv system working on the v929, which is working quite well with flight times up to 5 mins...
ArchillesElbow is offline Find More Posts by ArchillesElbow
Old Nov 08, 2012, 02:36 PM
Addict.
Joined Jul 2010
Well they don't post component weights, but they do say 250 grams as the weight so I don't see that coming even close to working unless you want a first person video of the ground not moving
Old Nov 08, 2012, 03:06 PM
mystman is offline
Joined Jan 2012
250g is shipping weight. The camera+tx should be between 5-10g
Old Nov 08, 2012, 03:20 PM
Addict.
Joined Jul 2010
Source?
Old Nov 08, 2012, 03:32 PM
mystman is offline
Joined Jan 2012
Source?
I "suppose" as you can read "should be between..." I read it anywhere but don't know where anymore...
But I can be totally wrong...maybe it's up to 20g but can be stripped down
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 02:57 AM
New Product WLToys Ladybird Large BRF$30; RTF$39 lao Micro Helis 7 Jun 02, 2012 11:22 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 09:48 AM
