Old Nov 06, 2012, 06:42 AM
Joined Jan 2012
Syma X1 Main pcb ( FlySky / 9X compatible)
Banggood ist listing the Syma X1 main pcb for $9.51!
http://www.banggood.com/Wholesale-Sy...2-p-54191.html
As this Syma X1 is similar to the v929 and also using the FlySky protocol (9x compatible), it should be worth a test on a v929 setup.
I already ordered one.
I also ordered the Spacecraft canopy, which should fit on a v929:
http://www.banggood.com/Wholesale-Sy...1-p-54207.html
the Bumble Bee canopy isn't my style:
http://www.banggood.com/Wholesale-Sy...2-p-54210.html
mystman is offline Find More Posts by mystman
Old Nov 06, 2012, 10:57 AM
Sir Crashalot
stonecutter's Avatar
Joined Oct 2011
Hard to tell from the photo, does the Syma board have plugs for the motors, or do they have to be soldered on?
stonecutter is offline Find More Posts by stonecutter
Old Nov 06, 2012, 12:51 PM
Joined Jan 2012
No plugs.
No Problem ror anybody with at leats minimal soldering skills
Get this 10 x Micro JST 1.25 2-Pin Male , Female Connector plug w/.Wire and solder yourself some socket wires
http://www.ebay.com/itm/10-x-Micro-J...o_Control_Toys
Old Nov 06, 2012, 08:01 PM
If It Works, I'll Break It
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
That Syma bug canopy reminds me of the old Outer Limits episode called The Zanti Misfits....
Jake8131 is offline Find More Posts by Jake8131
Old Nov 07, 2012, 04:08 AM
midelic's Avatar
Joined Apr 2012
I've seen many people worried about using Turnigy nano bateries with V929 because of different plug.Too much whining about soldering.
Batery for V929 -turnigy nano modified for JST plug without soldering.Remove the the pins, out of original molex conector ,extend the pin hook out in order to secure it , and insert in a male jst plug.That's it,finished.You can use the battery with V929 board.
midelic is online now Find More Posts by midelic
Old Nov 07, 2012, 04:13 AM
Joined Jul 2012
or buy correct 600mAh nanotech that already have jst plug
Soul Reaver is offline Find More Posts by Soul Reaver
Old Nov 07, 2012, 05:17 AM
Joined Jan 2012
But he wants to use a "light-weight" (8g instead of 12g) 300mah 45-70c lipo...
Old Nov 07, 2012, 05:20 AM
Joined Jul 2012
Ops...
In that case I would think about building a short jst-losi adapter (should weight very little I think) instead of putting jst on 300mAh batteries, so I can still use them on all other micro quads.
I'm starting to have too many lipos around
Old Nov 07, 2012, 05:23 AM
Gavinxman's Avatar
Joined Aug 2011
Looking for a 929 motor for my boys quad . Please pm me if you have 1 or 2 . Thanks
Gavinxman is offline Find More Posts by Gavinxman
Old Nov 07, 2012, 12:49 PM
Jake8131's Avatar
Joined Dec 2010
Why would you drop down from 600mah to 300mah??????
Old Nov 07, 2012, 01:59 PM
Always flying above the law.
rexless's Avatar
Canada, BC
Joined Apr 2012
I'm considering the same. I find the weight with the 808 camera is a bit annoying and I don't need to fly the camera for more than 3-5m/flight anyway. I have 3 V929's and only one is for video so the other 2 are for long-fun-fast flights.
rexless is offline Find More Posts by rexless
Old Nov 07, 2012, 02:02 PM
RC beginner
New York
Joined Oct 2008
bigger batteries reduce motor life. more weight causes shorter life as does extended operation. the candle that burns brightest....
these pagers need all the help they can get in that department.
dave1993 is offline Find More Posts by dave1993
Old Nov 07, 2012, 02:09 PM
midelic's Avatar
Joined Apr 2012
The new batery is 8 grams versus 12 grams stock batt.
The stock canopy is 3.4 grams versus paper canopy around 0.7-1.2 grams.
--------------------a.s.o.-------------------
You can reduce almost 6 grams weight only from that.This is huge....improvement.
I prefer weight less than weight more.Lol!
Old Nov 07, 2012, 03:52 PM
Sir Crashalot
Joined Oct 2011
My understanding is that for the same C rating, a 600 mAh battery provides twice the current discharge capability as that of a 300 mAh one. So there is a trade that needs to be considered. I just tried both 600 and 300 Nano-Tech's, and with the 300, climb rate is essentially zero, whereas with the 600 it is at least flyable. (Observations are of my old beat up v929, YMMV.)
Old Nov 07, 2012, 03:55 PM
United States, TN, Knoxville
Joined Jun 2012
I finally got mine fully functional again. I thought it was a bad motor but turns out it was the red wire leading right into the motor. It was still connected but ever so slightly broken. A quick soldering job and its like new. I'm thinking the motor cover might have pinched it on a crash.
variantman is offline Find More Posts by variantman
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5137 Yesterday 06:45 PM
New Product WLToys Ladybird Large BRF$30; RTF$39 lao Micro Helis 7 Jun 02, 2012 10:22 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 08:48 AM
