Old Oct 31, 2012, 09:04 AM
Banjo5 is offline
Find More Posts by Banjo5
Canada, ON, Merrickville-Wolford
Joined Jun 2012
Originally Posted by mystman View Post
He's using BASCOM-AVR. You can get a time unlimited demo with a 4K code limit (which is far enough for an ATtiny13) here :
http://www.mcselec.com/index.php?opt...d=14&Itemid=41
This just keeps getting better . I saw "demo" and didn't look any further, figuring, incorrectly of course, that it would be useless.
Just unwrapped a HK 2-4 cell Lipo alarm, wondering what processor it had on. Unfortunately it's an unmarked 14 pin one. Reprogramming one of these would have been a neat solution. As it is, it's a good source of parts for under $2.
cheers,
Andrew
Banjo5 is offline Find More Posts by Banjo5
Old Oct 31, 2012, 02:33 PM
mcmoyer is offline
Find More Posts by mcmoyer
450x, 180CFX
United States, TX, Burleson
Joined Feb 2012
My camera fun has ended prematurely
After my first day of the camera, I realized how bad my props were and replaced all four of them. Then I made a camera mount canopy using the water bottle idea from another thread. I only had a few minutes to play around, but still wanted to see what I'd get video wise. Took off and it handled better than when I had the camcorder mounted below. Flew around for a few minutes before the "flutter death spiral" kicked in.
Everything would have been ok, but a slight wind pushed it towards the pool -- argh! Interestingly enough, the quad floated. I don't know if it floats in general, or because of the inverted water bottle mounted on it. Either way, the electronics in it stayed dry and so did the camera....or so I thought.
I immediately took it inside my house and hooked up the camera to my computer. I watched a few minutes of the video. Much better and no vibrations! Right after that, I had to leave. Got back home a few hours later and was greeted by some error messages from the laptop saying that the drive (the camera) had to be initialized. Ever since then, the camera turns on, but doesn't seem to do much more than that.
I guess I need to order a new one. Wish I would have gotten more than 2 days out of the first one
mcmoyer is offline Find More Posts by mcmoyer
Old Nov 01, 2012, 09:53 AM
siriux is offline
Find More Posts by siriux
Joined Nov 2012
Originally Posted by DoctorSpin View Post
the V929 will often begin its lift a little awkwardly even when initialised correctly
one side will start and come up before the other
this is an artifact of the way the flight controller firmware gets to its stable correctable state
try just a little more throttle and it should come "unstuck" from the ground and sit in the air nicely
I have the same problem, the quad goes forward when I try to lift it. I have increased speed and it lifts, but it is totally uncontrollable. Never stays in the air, always goes forward.
Im very disappointed, wait for a month for this!
Any other idea? Is there any way to compensate this with de RC?
siriux is offline Find More Posts by siriux
Old Nov 01, 2012, 10:01 AM
halfstopper is offline
Find More Posts by halfstopper
Joined Oct 2012
hi, I got the LED port on my v929 receiver board, tried place my voltmeter on the port and trigger the right button on my stock transmitter. It is giving out 3.3v which i am able to place my own LED.
May I know whats the name of the female connector. At least I can make my own cable instead of solder wire on it.
halfstopper is offline Find More Posts by halfstopper
Old Nov 01, 2012, 10:11 AM
mystman is offline
Find More Posts by mystman
Joined Jan 2012
Micro JST 1.25 2-Pin Male , Female Connector plug
Only plugs/sockets :
http://www.ebay.com/itm/Micro-JST-1-...o_Control_Toys
Cables & sockets
http://www.ebay.com/itm/Mini-Micro-J...o_Control_Toys
http://www.ebay.com/itm/10-x-Micro-J...o_Control_Toys
http://www.hobbyking.com/hobbyking/s...idproduct=9727
mystman is offline Find More Posts by mystman
Old Nov 01, 2012, 10:45 AM
BD Murdock is offline
Find More Posts by BD Murdock
Quad guys are 4x the fun :)
BD Murdock's Avatar
United States, CO, Longmont
Joined Mar 2012
929 Halloween Ghost!
Put this together for the wee trick-or-treaters. Flew pretty well actually, got the idea from WOW Hobbies. Pay no attention to the audio...just silly beer laden people.
929 Toxic Green Ghost 2 (0 min 28 sec)
BD Murdock is offline Find More Posts by BD Murdock
Old Nov 01, 2012, 10:58 AM
Banjo5 is offline
Joined Jun 2012
Which TX is this? My RTF one, bought a couple of months ago, has the empty ports and came with a TX that doesn't have a working right button and has v929/v939 written on the faceplate. As near as I can tell it's the same TX BG sells separately.
Also haven't heard yet of anyone who's managed to get them to operate from any other TX.
cheers,
Andrew
Old Nov 01, 2012, 11:13 AM
Joined Oct 2012
cheers,
Andrew
MIne also RTF which i bought 1 month ago too, The TX came tgt with the V929. I only tested with multimeter which actually giving out 3.3V. Hvnt tested with LED yet as I don't have the micro JST connector.
Old Nov 01, 2012, 11:14 AM
Joined Oct 2012
Thank you very much!
Old Nov 01, 2012, 11:20 AM
rexless is offline
Find More Posts by rexless
Fly Fast, Fly Hard, Fly Fun
rexless's Avatar
Canada, BC
Joined Apr 2012
Excellent links. I had just received a pack of the wired ones from ebay this week.
One thing I seem to need is a source for light wire. I'd like paired wire for replacing connections to the motors or for adding in lights. Does anyone have a good source for this or know what the correct guage/name for this type of wire is so I can search Ali / Ebay? Thanks!
rexless is offline Find More Posts by rexless
Old Nov 01, 2012, 11:44 AM
mystman is offline
Joined Jan 2012
It's not paired, but I'm using Kynar Wire -Size : 30 AWG, solid.
http://www.ebay.com/sch/i.html?_nkw=...0&LH_PrefLoc=2
Or Teflon Coated Wire 36AWG (but they are very thin)
Red : http://www.hobbyking.com/hobbyking/s...dProduct=11849
Black : http://www.hobbyking.com/hobbyking/s...dProduct=11850
Or Enameled Wire
http://www.ebay.com/sch/i.html?_saca...ed+wire&_frs=1
Or Ribbon Cable 28AWG (Computer)
Old Nov 01, 2012, 02:35 PM
Gavinxman is offline
Find More Posts by Gavinxman
Gavinxman's Avatar
Joined Aug 2011
Does anyone have a motor I could buy for my 929 . My sons 929 needs 1 or 2 if I could get them. I have pay pal ready . I know I could get them from BG but trying to find one in the USA . don't mind paying more to have it sooner thanks !
Gavinxman is offline Find More Posts by Gavinxman
Old Nov 01, 2012, 02:52 PM
mystman is offline
Joined Jan 2012
Get mQX motors if you don't mind soldering.
For example :
http://www.ebay.com/itm/Blade-mQX-BL...ts_Accessories
http://www.ebay.com/itm/Blade-MQX-BL...o_Control_Toys
Mabe you can get them at a LHS nearby.
Old Nov 01, 2012, 03:22 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
what are the 4 extra jst conectors for, the ones next to the jst plugs that the motors plug into?
i dont know if i circled the right ones i but i think you wil know what i mean
Im asking because im using the 9x and wanna know if its a 5ch
chester2240 is offline Find More Posts by chester2240
Old Nov 01, 2012, 03:25 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Those are probably for the LEDS
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Mini-Review WLToys Beetle quad review jameschen072 Mini Multirotors 5149 Oct 29, 2014 01:57 AM
New Product WLToys Ladybird Large BRF$30; RTF$39 lao Micro Helis 7 Jun 02, 2012 10:22 PM
ladybird beetle/gws easybug nebuchadnezzar Foamies (Kits) 1 Aug 14, 2004 08:48 AM
